09-09-2020, 10:06 AM | #199 | |
Rep 40,666
09-10-2020, 08:00 AM | #201 |
Rep 40,666
09-13-2020, 09:26 AM | #202 |
Rep 2
Hello, I need some help here!
I recently got my firmware car updated at the dealer and lost all my updates. I tried to do set the FDL again and I got an error File for "cafd_ffffffff-255_255_255" not found! Tried to reset Fem_body injecting new cafd, following this steps Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the replacement CAFD from above => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. but after clicking CODE I get the same error File for "cafd_ffffffff-255_255_255" not found! I am using esys 3.30 and v.4.25.12_PSdZData_Full. My I-Step is F020-20-07-530 I-Step (Current) F020-20-07-540 Could anyone help me please? |
09-13-2020, 09:31 AM | #203 | |
Rep 40,666
09-13-2020, 09:50 AM | #204 |
Rep 2
09-13-2020, 09:56 AM | #205 |
Rep 40,666
09-16-2020, 12:38 AM | #206 |
Rep 7
Cafd not found
Hi all,
While trying to code REM and TRSVC after a reverse camera retrofit on a 2012 F30 328i, I get in E-Sys the error cafd not found on REM module. I am trying to achieve installation via coding 3AG option. The HU_NBT module gets coded correctly, and when I put the car in reverse I can see the rear camera menu, but unfortunately no image. iSTA says that the TRSVC module is not coded on the car. I am using Esys 3.27.1. On February this year the dealer updated the software on the car. The I-Level of the car is F-020-19-07-530. I cannot find in the cafd list of the TRSVC module a matching version cafd. As I am complete newbie to coding, I hope that this makes sense. Can you let me know what can be done? Thanks a lot! Last edited by mih222001; 09-16-2020 at 05:55 AM.. |
09-16-2020, 10:26 AM | #207 | |
Rep 40,666
03-16-2021, 06:24 AM | #209 |
Rep 19
hi there ,BMW f30 just tryed to made retrofit from electrical adjusted front seats + memory to electrical adjusted seats+memory with seat heating .Wired up supply by OEM wiring diagram and lin wire from REM to passenger seat heat module. I was added VO (494) and coded all ecu's , after coding process ended got 1 error : file for cafd-0001060-007_001_050 not found [C012] . May somebody has any suggestions what i did wrong ? By the way - passenger seat heating works , 3 of led's works fine, but drivers button won't do any action even the led lights not shows up .
03-16-2021, 06:26 AM | #210 | |
Rep 40,666
03-16-2021, 07:03 AM | #212 |
Rep 40,666
Very old. Use what I sent.
03-16-2021, 07:23 AM | #213 |
Rep 19
Thanks , so while im gonna receive the message , ill do prep jobs - so all what i need to do is to add missing files to psdzdata folder then open up e-sys and just try to recode it again ? Or do the same procedure (adding to VO list and ...) Am i right understand ?
03-16-2021, 10:24 AM | #214 | |
Rep 40,666
03-17-2021, 08:35 AM | #216 |
Rep 40,666
PM sent.
05-30-2021, 03:07 AM | #217 |
Rep 5
Good day. I turn to you for advice: I bought a set of retrofits, a camera through an advertisement. Hook up to the BDC unit. Encoded all blocks with the "3AG" option. But it doesn't work. All icons appeared in the menu but there is no image. Initially, when encoding, an error came out on the ICAM4 block, that there is no CAFD fffffff_255_255_255. I clicked Detect CAF for SWE, selected the last file there, and encoded with it. Now ICAM has been programmed, but there is still no image ... The TRSWC block is displayed in the reinghold and writes that it is incorrectly encoded. Do I understand correctly that I need the correct CAF? Where can you find it?
05-30-2021, 07:38 AM | #218 | |
Rep 40,666
05-30-2021, 12:43 PM | #219 |
Rep 5
Thank you. I checked the wiring again. Everything is correct. And can it be influenced by the fact that my car is an old i-level, 2018, and a donor camera that had a more recent i-level, 2019?
