12-16-2017, 11:10 AM | #111 | ||||||
Rep 1,292
Edit: almost forgot but someone over the 2 series forum fitted these to his m240i so seems to be compatible http://www.2addicts.com/forums/showthread.php?t=1426871
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
12-16-2017, 11:26 AM | #112 | |||||||
Rep 3,622
BMW CCA Member #516012
12-17-2017, 03:15 AM | #113 |
Rep 1,292
You've got it here for instance:
https://www.turnermotorsport.com/p-2...235i-with-edc/ Same part number for 340 and 335 on KW website https://www.kwsuspensions.net/produc...overs/39020018
goj2254.50 |
12-17-2017, 08:10 AM | #114 |
Rep 396
Drives: 2014 335i M Sport, 2004 .:R32T
Interesting option on the KWs. I also saw those coil overs but the description was very misleading. I thought that the dampening on the KW coils were controlled by a separate remote or in this case an app. The turner website description didn't really make it seem like it was plug and play but the KW site did. I may def have to look into the KWs now.
12-17-2017, 02:48 PM | #115 |
Rep 1,292
Well you have both options, the KW DDC ECU comes with an additional ecu that taps the CAN bus, and can be controlled with the app, which is neat if you want suspension that you can control from the phone.
If however like us you have EDC from factory they have the KW DDC Plug and Play that connects to the original harness, which is what I did.
goj2254.50 |
12-18-2017, 03:06 PM | #116 | |
Rep 3,622
12-18-2017, 03:07 PM | #117 | |
Rep 3,622
12-19-2017, 05:18 AM | #118 |
Rep 1,292
I'd say tallest setting is a good 20mm below stock M / adaptive-M suspension, not a very scientific assessment but there you go
KW support told me I could use higher springs and gave me references, but that it wouldn't be warrantied or TÜV-approved, so stayed with tallest settings with original kit, which is 99% fine but a bit low in some circumstances. Check out this thread, mine looks similar to the pictures in the first post: http://f30.bimmerpost.com/forums/sho...d.php?t=845952
goj2254.50 |
12-22-2017, 09:50 AM | #119 |
Rep 1,348
01-03-2018, 06:05 PM | #120 |
Rep 16
B16 Ridecontrol Electronically Adjustable Damping Coilover System
Looks cheaper here:
https://www.carid.com/bilstein/b16-r...lover-kit.html and here: https://www.ecstuning.com/b-bilstein...49-131543~bil/ |
01-04-2018, 04:22 AM | #121 | |
Rep 4,523
AFAIK B16 RC cannot be integrated into a car with OE EDC, hence the difference to the still long awaited OE EDC PnP Billy B16 Damptronic [DT]. KW DDC can be opted either to integrate into OE EDC as PnP or standalone for non EDC cars via smartphone app
Current '22 X3M LCI.. |
01-04-2018, 08:08 AM | #122 | |
Rep 16
01-18-2018, 12:27 PM | #123 |
Rep 3,622
For those of us stateside - Looks like we can get the B6 Damptronic shocks and struts on tire rack.
Seems like a good option for those of us looking for a performance upgrade but not willing to lower the car. https://www.tirerack.com/suspension/...180118181912:s
01-18-2018, 06:18 PM | #125 | |
Rep 396
However, now that someone brought up the KW DDC coils are PnP options for EDC cars that is kinda what i was looking for in these Bilsteins. Just didn't know there were any other options besides the Bilsteins. yes, the B6 damptronic shocks would be a direct replacement for OEM DHP equipped cars. |
01-19-2018, 10:36 AM | #126 |
Rep 1,343
I am hoping the B8 version becomes available soon for the xi with adaptive suspension. I have held off getting lowering springs such as a Dinan or ACS until the B8 or some alternative comes to market. I am afraid the lowered brings on the stock adaptive suspension will wear out the struts to quickly and negatively impact the suspension dynamics. I had B8’s on my n55 with Eibach springs and I loved it! If not, then I may have to look into the KW’s as a direct pnp.
01-24-2018, 03:14 PM | #127 |
Rep 10,282
I called Bilstein USA to learn more about availability of B16 DampTronic coilovers for F36 vehicles. Nothing yet.
The Bilstein site in Germany shows B16 Damptronic status "in preparation". Perhaps soon? http://web1.carparts-cat.com/default...01&14=1&12=130 |
03-12-2018, 10:28 PM | #128 |
Rep 832
Drives: 2019 G01 X3
Still nothing?
03-12-2018, 10:36 PM | #129 |
Rep 10,282
03-13-2018, 05:22 AM | #131 | |
Rep 832
Drives: 2019 G01 X3
Fingers crossed for a true plug and play adjustable coilover (i.e. B16 Damptronic) soon. |
03-13-2018, 09:57 AM | #132 | |
Rep 733
BCforged HB29 - M4 trunk - Bilstein B12 Sportline Damptronic - 435i type exhaust cf Cyba tips - M4 grills - 3D design cf diffuser - Kerscher cf lip |
