07-13-2017, 07:24 AM | #45 | ||
Rep 3,926
I've included BMW labor estimates for each part of the procedure. You can use that for talking about the labor charges with shops. |
07-18-2017, 11:48 AM | #46 |
Rep 36
Getting the stock front struts out of the knuckle (Swivel bearing)and my new Koni yellows back in was a real bitch. Get the spreader tool if you are collecting tools to do the job. Also just want verify that the swivel bearing only gets torqued to 32 ft pounds? It seems not very tight.
07-18-2017, 12:26 PM | #47 | |
Rep 3,926
If you're talking about the strut to top hat nu on the front, check the ISTA documents posted on the first page. If I had to guess it's somewhere between 35-45 ft lbs. |
07-18-2017, 01:48 PM | #48 | |
Rep 36
07-21-2017, 04:20 AM | #49 |
Rep 3,926
08-18-2017, 12:28 AM | #50 |
Rep 145
Drives: 2016 F30 340i
Subscribed!
08-22-2017, 12:08 PM | #51 |
Rep 1,467
I still cant decide if I want coilovers or spring/struts!! I have an x drive. I seem to get mixed signals on the forum for what is better.
09-08-2017, 11:44 AM | #52 |
Rep 482
Drives: 2014 Glacier Silver F30 328i
09-15-2017, 10:17 AM | #53 |
Sustinendum Victoriam
80
Rep 349
Polo08816 Excellent write up! Didn't know APG did BMW DIY events. I wonder if Meade has them as well. Honestly living between the two, I wouldn't mind heading up to APG for some help.
09-15-2017, 03:08 PM | #54 | |
Rep 3,926
Fort Meade has an Auto Skills Center but it's smaller and not nearly as good as APG's. |
01-20-2018, 09:55 AM | #55 |
Rep 891
Subbed. Great info, will be using to install B14's on my car.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
Polo088161593.50 |
02-26-2018, 04:04 AM | #58 |
Rep 3,926
I used the BMW tool listed in the FSM - https://www.newtis.info/tisv2/a/en/f...struts/5H29GxL.
The BMW part number conversion is: 83300494541 |
02-26-2018, 07:44 AM | #59 | |
Rep 1,467
Would this work as well? ECS lists it as working on all BMWs. https://www.ecstuning.com/b-autotech.../10012411~aut/
02-26-2018, 07:48 AM | #60 | |
Rep 3,926
Insane435476.50 |
02-26-2018, 07:51 AM | #61 |
Rep 1,467
gotcha, look like a tool that fits into a 10mm (guessing) socket? Is that how your was or was it an actual socket.
02-26-2018, 07:54 AM | #62 |
Rep 3,926
03-01-2018, 07:58 AM | #63 |
Rep 1,467
Has anyone swapped out to the Meyle HD sway bar links? Think it would make any difference?
03-04-2018, 07:19 AM | #64 | |
Rep 227
Drives: 2000 BMW E39 M5
OP's post mentions a DIY for rear sway bar install, but I don't see one posted yet. Probably because it's a huge PITA to install and was likely the most difficult DIY I've ever done. That being said, it's worth the effort! The car still understeers at the turning limit, but way less than before. |
03-04-2018, 07:30 AM | #65 | ||
Rep 5,451
Drives: F30
What about the front bar? |
03-11-2018, 07:41 PM | #66 |
Rep 1,467
Im going to install the coilovers in the next few weeks. Is it possible to install the rear suspension and then drive to a shop with a lift so I can install the front? Or is that not a good idea?
diy |
