BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ☛ MHD Flasher F Series (F2x F3x) discussion ☚
proTUNING Freaks
      12-21-2017, 10:12 AM   #1
MHD Tuning
MHD Tuning's Avatar
Drives: M3F80#M5F90#340iF31#SupraA90
As we are announcing today MHD for F series, we would like to use this official thread to gather discussions, updates, user logs, dynos and videos. Community feedback has helped us shape the best tools and maps for E-series, so we're counting on everyone to repeat the same joint effort.
To get things started, here is the product description.
MHD Flasher F-Series (N55/S55/B58/N13)
The MHD tuning team is proud to present its latest product - the MHD Flasher for BMW F-Series. After two years of development, the wait is finally over! The MHD Flasher F-Series is a complete flash tuning app for your BMW. Unlike a piggyback module, it is capable of complete DME remapping while retaining all OEM safety mechanisms. This allows for maximum performance,maximum safety, and unrivaled drivability.
Several thousand customers worldwide have been enjoying the number one flash tuning tool for the E series N54 and N55 platforms (MHD Flasher N54 / N55 E-series) since 2015. Come join us now for the F-series launch and see what all the hype is about!
Product details:
Full OBD Flashing:
You can install MHD right at home and start tuning immediately! There is no need to remove and send out your DME for a costly “unlock.” Simply download the MHD Flasher F-Series app that connects via a K+DCAN cable to your Android device and your vehicle’s OBD-II port, start the app, and within 15-25 minutes the initial installation is complete. Further map changes are much faster - only 1-3 minutes! You can revert your vehicle to the factory OEM flash at any point, and no initial backup is necessary.
Stage 1, Stage 2 und E85 OTS (Off The Shelf) Maps by PureBoost:
We offer a wide selection of OTS maps for the N55 PWG, N55 EWG, S55, B58 and N13 engines suitable for many different vehicle modifications and octane levels. They have been extensively road and dyno tested, just flash and go!:
N55 EWG* (Vehicles built after 07/2013 with electronic wastegate):
  • Stage 1 (up to 360HP/540NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for stock cars. (not available for M2 and X4 M40i)
  • Stage 2 (up to 390HP/580NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with an upgraded intercooler or high-flow downpipe.
  • Stage 2+ (up to 430HP/630NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with an upgraded intercooler and high-flow downpipe.
  • Ethanol Mix Maps: Stage 1, 2 and 2+ E20 Maps for ethanol blends of 20%
N55 PWG* (pneumatic wastegate):
  • Stage 1 (up to 340HP/540NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for stock cars. (not available for M2 and X4 M40i)
  • Stage 2 (up to 370HP/580NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with an upgraded intercooler or high-flow downpipe.
  • Stage 2+ (up to 400HP/630NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with an upgraded intercooler and high-flow downpipe.
  • Ethanol Mix Maps: Stage 1, 2 and 2+ E20 Maps for ethanol blends of 30%
S55 (BMW M2C, M3 / M4 F8x):
  • Stage 0 - C.S Style 460HP & G.T.S Style 500HP (included in the flasher license)
  • Stage 1 (up to 530HP/700NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for stock cars.
  • Stage 2 (up to 560HP/780NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with high-flow downpipes.
  • Stage 2+ (up to 575HP/850NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with high-flow downpipes.
  • Ethanol Mix Maps: Stage 1, 2 and 2+ E30+ Maps for ethanol blends of 30%+
  • DTC (transmission) Maps: Stock, C.S Style & G.T.S Style (included in flasher license)
B58
  • Stage 1 (up to 420HP/580NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for stock cars and cars with gasoline particulate filter.
  • Stage 2 (up to 470HP/630NM) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with high-flow downpipe and no gasoline particulate filter.
  • Ethanol Mix Maps (420-470HP / up to 630NM) - Stage 1, 2 Maps for ethanol blends of 30%
N13
  • Stage 1 (up to 200HP/280NM) - for stock cars.
  • Stage 2 (up to 235HP/350NM) - for cars equipped with high-flow downpipe and upgraded intercooler.
Topspeed limiter removed on all OTS maps.
As an alternative to built-in maps, many local and remote tuners can provide advanced custom mapping for those who have more extensive modifications or unique performance / customization needs.
Monitoring and Logging Module:
Monitor your engine behavior to make sure it is running perfectly using a configurable and very responsive gauge layout. 50+ engine parameters are available at a glance! Activate the logging mode to save the data to a standard CSV file for later analysis using the built in log viewer. Additionally, we will happily provide free logs analysis.
These are some of the available monitors:
  • Boost, Boost Target
  • Lambda (AFR)
  • Intake Air Temp (IAT)
  • Ignition Timing per Cylinder
  • Coolant Temperature
  • Oil Temperature, Oil Pressure
  • Transmission Temperature
  • High Pressure Fuel Pump (HPFP)
  • Throttle Position
  • Wastegate Duty-Cycle (WGDC)
  • RPM
  • Speed
  • EGT
  • And many more…
MHD exclusive advanced monitor:
  • Timing Corrections per Cylinder
  • Boost target EX which can read higher than 22.x psi (the BMW boost target channel can't)
  • Base Compressor Axis: Boost Setpoint, MAF req WGDC.
  • Active Torque Limiters
  • And many more…
Flash-time Options::
These flash options can be applied to any map directly through the app!:
N55/S55 features:
  • Exhaust Burble: Customize your desired exhaust burble (duration & aggressiveness, min speed, min rpm) and enjoy the sporty sound
  • N20 Map Sensor (on N55)
  • Remove top speed limiter (Vmax)
  • Cold start noise reduction
  • Exhaust flap open in sport mode
  • Limit power per gear
  • Precision Raceworks Coil Kit Support
  • XHP TCU flash support (optimized OTS maps)
  • XDI high pressure fuel pump support
  • More options will follow with new updates.
B58 features:
  • Sport cooling mode for increased water / air intercooler cooling
Read DME Codes::
Track issues by reading the error codes and delete them once resolved. Resetting adaptions is also possible (AFR, VANOS, Throttle, Load Control, Idle, Fuel and many more)!
New features and updates::
The MHD Flasher F-series will continue to evolve after the release, which means many exciting new features and map updates will be coming in the future.
What you need:
  • Android device, OTG compatible with Android OS 4.4 and higher.
  • Apple iOS device with iOS 10.2 and higher.
  • MHD WIFI Adapter
  • Or BimmerGeeks ProCable (K+DCan cable - only on Android).
  • Or ENET cable + ethernet to lightning adapter (iOS only, F+G Series only)
Supported vehicles:
MHD Flasher F-Series N55:
  • M135i F2x N55 2012 - 2016
  • M235i F2x N55 2013 - 2016
  • M2 F87 N55 2015 - 2018
  • 335i N55 F3x 2011 - 2015
  • 435i N55 F3x 2013 - 2016
  • 535i / GT N55 Fxx 2010 - 2017
  • 640i N55 F0x 2011 - 2017
  • 740i N55 F0x 2012 - 2015
  • X3 35i N55 F25 2010 - 2017
  • X4 35i / M40i N55 F26 2014 - 2018
  • X5 35i/40i N55 F15 2013 - 2018
  • X6 35i/40i N55 F16 2014 - 2018
  • X-Drive is supported on all cars.
MHD Flasher F-Series S55:
  • M3 S55 F80 2014 - 2019
  • M4 S55 F82 2014 -
  • M4 S55 F83 2014 -
  • M2 Competition S55 F87 2018 -
MHD Flasher F-Series B58:
  • M140i F2x 2012 - 2019
  • M240i F2x 2016 - 2019
  • 340i F3x 2015 - 2018
  • 440i F3x 2016 - 2019
  • 540i G3x 2017 -
  • 640i GT G32 2017 -
  • 740i G1x F0x 2015 -
  • X3 M40i G01 2017 -
  • X4 M40i G02 2018 -
  • X5 40i G05 2018 -
  • Z4 M40i G29 2019 -
  • All performance power kit cars are supported.
MHD Flasher F-Series N13:
  • 114i F2x 2012 - 2015
  • 116i F2x 2011 - 2015
  • 118i F2x 2011 - 2016
  • 120i F2x 2015 - 2017
  • 316i F3x 2012 - 2018
Pricing (In-App purchases):
The (competitive) prices list will be posted once our vendor account is validated in the vendor sub forum. for now see the f30post thread here
http://f30.bimmerpost.com/forums/sho...php?p=22562277
*The Stage 1 map pack contains Stage 1 and Stage 1+ maps with all available octane variants.The Stage 2 map pack contains Stage 2 and Stage 2+ maps with all available octane variants.
FAQ:
Q: Can I test the connection before making a purchase?
A: Yes, simply tap the MHD Store button. The ECU connection is checked before displaying available purchases.
Q: Can I tune different cars with one license?
A:Each vehicle has its own unique license (VIN and google account locked), tuning a different car requires purchasing a new license.
Q: Can I tune multiple cars with one google play account?
A: Yes, you can purchase multiple licenses with one google play account.
Q: Can I transfer my licenses?
A: Licenses are personal and stored by google along the account used at purchase time. The purchases are tied by google to the first account and can’t be transferred to a new google account.
Q: Does my Android device need to be permanently plugged to the OBD port?
A: No. Once a flash is performed you can unplug your device.
Q: Do I need to purchase a new license each time I flash a map?
A: No, you can reflash as many times as needed. MHD maps updates are free.
Q: Is a battery charger required?
A: It is highly recommended for long flashes (install, uninstall). A healthy battery will handle short flashes (map changes) fine but the use of a battery charger remains recommended.
Q: How do I take good data logs?
A: Press the Monitor (auto log) button, stabilize around 2500 rpm / 3rd gear (4th on 8 speed AT) with DSC fully off. Mash the pedal, shift at 6500 and 2-3s after the shift into 4 release the throttle. Slow down, stop the monitor. If you want us to review your log, then upload the log to www.datazap.me and send us the link.
This Product is for Competition/Racing/Off-Road Use Only.
Appreciate 6
      12-21-2017, 10:13 AM   #2
MHD Tuning
MHD Tuning's Avatar
Release schedule
We will start a closed beta period from 1-1-2018. Users willing to actively participate and provide datalogs can drop us an email right now. You can get $5.99 off a bimmergeek cable with the oupon "MHD".
Expected closed beta period is 4-6 weeks, after which we will go public.
Seba77W300.50
wassy479.00
      12-21-2017, 10:41 AM   #3
VT-man
VT-man's Avatar
Drives: 2014 435xi
OH SNAP THANK YOU
This is a great news. Now are those number for xdrive also or just rwd F series?
No IOS aps?
02AccordV6(sold) 03350zMT(sold) 04E46///M3MT(sold) 06RSXauto(sold) 07G35auto(sold) 2014F32bmw435MT 2017MacanGTS
      12-21-2017, 11:09 AM   #4
JaredG_F30
JaredG_F30's Avatar
1043
Drives: 2014 335i, M-Sport, Manual
This looks great. Features, performance and price point are very competitive. This should drive further innovation from PTF if Bootmod3 is to stay ahead of the pack. Competition is a good thing.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      12-21-2017, 11:12 AM   #5
dr.roro
Drives: 2019 G01 X3
Wow $350 all in or $450 with monitoring. Game changer...
badbread309.00
      12-21-2017, 11:17 AM   #6
Driggett
Drives: '14 335i msprt mineral grey AT
2014 BMW 335i  [0.00]
When will it be available in the google play store? I do not see it yet?
Never mind saw the beta period mention.
ianbiz182.50
      12-21-2017, 11:25 AM   #7
afranke
Drives: 2013 ActiveHybrid 3
MHD Tuning Here's one you should add to your FAQs: What if I already have bootmod3? What steps are needed to use MHD instead?
2013 ActiveHybrid 3 (335ih) N55 PWG Meisterschaft GT catback Wagner tuning catless DP and Stage 2 Evo Comp Intercooler ER chargepipes CTS intake io2V3 O2 simulator Pure Stage 2 turbo with high-flow inlet and DV upgrade Fuel-It Stage 2 LPFP JB4 ISO firmware Fuel-It DIY PI Kit bootmod3
FSociety3492.50
      12-21-2017, 11:49 AM   #8
yoandry
yoandry's Avatar
Drives: 13 F30 335i & JGC
Send a message via AIM to yoandry Send a message via MSN to yoandry
^^^^^ Also, what about for MPPK DME flash? Would MHD restore it when need to go back to stock tune? PS2 ETA?
PS2+ WMI + MHD Bef+JB4, VRSF DP, CP, FMIC Race 6, AFE Intake, MP-LSD, MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-interior trim, MP-Alcantara Steering Wheels W/race display, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats. XDI-35 HPFP installation pending....
      12-21-2017, 12:09 PM   #9
dotjonnL
Drives: 335iX M-Performance
+1 on the my stock MPPK flash.
      12-21-2017, 12:13 PM   #10
badbread
not good, but bad
Drives: 2013 335i
I'm curious about the "flash-counter" or whatever it's called I've seen posted on other threads. Could you quickly explain what exactly that means in terms of this flash? I've seen a few posts stating you can only change maps 10 times before you need to reset the ECU with an unlock... Does that apply in this case?
2nd question: Should a car need warranty work at the dealer, flash back to stock does the dealer see the flash or does it look stock to them at that point. Does ISTA or whatever they use raise a flag to see it's been flashed prior?
3rd question: Will this work in conjunction with a JB4 and/or is there any benefit to running this with a JB4 like other flashes?
Thanks!
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube
      12-21-2017, 12:39 PM   #11
SLVRsurfr_32
Drives: 2014 bmw 435
Definitely awesome news, competitive pricing is a good thing as well! Sign me up!
badbread309.00
      12-21-2017, 01:02 PM   #12
Bimmer_pnoy
Bimmer_pnoy's Avatar
Drives: 2015 335i xDrive
Wow excellent price point.
      12-21-2017, 01:11 PM   #13
Lancelot
France
397
Drives: 2014 M Sport ActiveHybrid3
Will the ActiveHybrid3 be supported?
2014 M Sport ActiveHybrid 3 - mods:
M Performance BBK - F80 struts brace - Quaife LSD - Koni Sport & ST sport springs - Millway Camber Plates and monoball - Akrapovic Exhaust - HJS EU6 catted downpipe - Wagner Evo2 Comp IC - BMC air filter - Powerflex Black Subframe Bushings - Bimmertech amp with Focal speakers
afranke193.50
      12-21-2017, 01:53 PM   #14
N0Chill 335i
N0Chill 335i's Avatar
Drives: 13' F30 335i M Sport AW
In for the win.
      12-21-2017, 04:05 PM   #15
MHD Tuning
MHD Tuning's Avatar
Originally Posted by VT-man View Post
OH SNAP THANK YOU
No IOS aps?
xdrive have a little more drivetrain loss indeed. We always state crank HP as measured here in Germany. Dynojet equivalent are around 5% lower than that (but not 15%).
iOS is not possible for now because Apple forbids the user of third party USB cables. Once the wireless adapter is done, we'll be able to port to iOS. Most Apple user tend to get a $50 android tablet at best buy and call it a day.
No step needed. Since MHD will overwrite everything, BM3 or stock doesn't matter. You can even log your BM3 tune with the MHD logger.
Yes it will restore MPPK because your calibration identifier is not modified. Not sure about the PS2 ETA question.
Seba77W300.50
      12-21-2017, 04:13 PM   #16
MHD Tuning
MHD Tuning's Avatar
Thanks!
There is no limit to the number of times you can reflash. The flash counter just keeps track of this number. Later we'll add a feature to freeze it.
By flashing back to stock you flash the exact same state as you would at a dealership. That said, whatever the tunes (piggybacks included), if BMW really want to dig, then can (in Munich).
We prefer flash only tunes. Terry is likely to develop his own backend MHD flash maps for the jb4.
Not sure at this point. Maybe if it shares the same rom as other N55 I need to check but I doubt it.
badbread309.00
      12-21-2017, 04:30 PM   #17
badbread
not good, but bad
Drives: 2013 335i
Awesome info, thank you!
      12-21-2017, 05:03 PM   #18
f32_027
Driver
f32_027's Avatar
Drives: 435i
Whoa, so for n55 EWG, these numbers:
Stage 2+ (up to 430HP/630NM or roughly 464ft/lb tq) - 91oct/95ron, 93oct/98ron, 95oct/102ron, for cars equipped with an upgraded intercooler and high-flow downpipe.
Are at the CRANK (for RWD?)
Any accurate idea for at the WHEELS for x-drive?
Probably 365hp and 395tq, hey? (I just subtracted 15% from the above numbers)
I guess, x-drive is probably -20% so...344whp 370wtq?
Am I correct?
      12-21-2017, 06:04 PM   #19
yoandry
yoandry's Avatar
Pure stage 2 turbo custom map estimate release.
sly1types142.00
      12-21-2017, 07:03 PM   #20
sly1types
Drives: F80M3 and E46M3
I would love to see some dynos. Especially one with a pure Stg2 on 93oct and E40
F80 M3-DCT
MaxPSI CH, BM3 with F80 Paul E85 Tune
AA Mid Pipe & VRSF DPs Signature SV104
E46 M3
F85 X5M
      12-22-2017, 12:12 AM   #21
Mountain_Commando
Mountain_Commando's Avatar
Australia
295
Drives: 435i Gran Coupe M-Sport
Wow, great job MHD Tuning!!!
Can't wait to get mine!
435i Gran Coupe | ///M Sport Pkg | 430hp | MHD Stage 2+ | BMS Intake | Catless Downpipe | FMIC | Black Sapphire exterior | 9H Ceramic Coating | Black Anthracite interior | 19" Black ///M Wheels | Red ///M Brake Calipers | ///M Steering wheel | ///M Metal Pedals | Alcantara dash panel | Carbon Fiber trims and gear knob | Angel Eyes LEDs | Surround Cameras | Spoiler | Coded ///M iDrive, Mirrors, HUD |
      12-22-2017, 06:26 AM   #22
Freestylerfalcon
Australia
46
Drives: 2014 F30 335i
Wow.. this is amazing.
flash, mhd, tune
