02-11-2020, 04:01 PM | #45 |
Rep 928
Their still not installed yet I'm planning on having it all installed in March or April I'll def update everyone. I don't think it will be too harsh as the factory Ohlins rear spring rates are 16k.
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
03-16-2020, 09:02 PM | #46 |
Rep 928
Picked up car Friday and def doesn't feel too stiff. Rides very nice with 14k rear springs. Installed the Megan racing upper stress bar and camber, caster, and toe bars in the rear also. Car is nicely planted now.
03-16-2020, 09:19 PM | #47 |
Rep 3,748
This is dampening adjustable right... what your set to?
03-16-2020, 09:24 PM | #48 |
Rep 928
Yes comp and rebound all in one. I'm starting out soft so the front is set to 12 clicks from full soft and the rear is 6 clicks. I'm gonna drive it like this for awhile then prob go 16-18 clicks front and 14 clicks in the rear. It's pretty comfortable at current settings.
03-16-2020, 10:02 PM | #49 | |
Rep 3,748
I'm asking this cause some knob are on top... then you have to unbolt the shocks to adjust it. Would clear up things if you have photo of the coils before the install but. |
03-16-2020, 10:06 PM | #50 |
Rep 928
Adjustment knob is towards the top you can jack up rear of vehicle and get your hand up in there.
09-01-2020, 03:37 PM | #51 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
09-01-2020, 03:46 PM | #52 |
Rep 928
Car is great these coils are amazing for the price. Wanted Ohlins, but didn’t want to spend 2500 or more just on parts. Loving the 14k rear swift springs too.
09-02-2020, 12:14 PM | #53 | |
Moto Lover
187
Rep 591
How does the car feel? What do you use the car for? Any prior experiences with other coilovers on other vehicles? Just trying to get a good feel for these. |
09-02-2020, 12:39 PM | #54 |
Rep 928
Yes 9k ft 14k rear I use if for aggressive street and a little track. I’ve never owned any other coils, but the ride is great firm but very controlled.
09-02-2020, 01:57 PM | #55 |
Rep 519
FaRKle!
Any thoughts on Fortunes response to your recommended spring rates of 5k/16k?
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
09-02-2020, 02:00 PM | #56 |
Rep 519
OP, do you know if the 1" drop minimum is from the standard or M sport suspension?
I dont want to go 1" lower than the M sport I already have, so it looks like I may still have to go to Ohlins R&T if that's the case
09-02-2020, 03:02 PM | #58 |
Moto Lover
187
Rep 591
So I just got off the phone with Jaze, one of the head engineers. He recommends the Broadway Static setup for what I am looking for. The car is going to be used mainly as a daily driver but the intentions with seeing 4-5 track days a year. He recommended I get the 500s series, with the Swift or Hypercoil spring upgrade and in 10k/16k spring rate.
The coilover kit comes with end links and also have camber plates. 4 week turnaround time. |
09-02-2020, 03:11 PM | #59 | ||
Rep 3,539
Unless the amount of travel in their dampers is extremely limited, you should be fine on stroke length. Also, how can the shock bottom out if they specified the bump stop properly? This would make me seriously wonder how they valve their shocks to match customers' custom rates. The comment about designing the shock (which means the shim stack and hole sizes in the piston head) for 9kg/mm rate don't give me as much confidence they really alter that at all when customers ask for different rates. If you wanted to go stiffer to 6kg/mm (336lbs/in) in front you could too and maintain flat ride, it'll just be a lower ratio, like 5%, which might not be as smooth as a higher ratio. Quote:
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 09-02-2020 at 03:16 PM.. |
09-02-2020, 03:21 PM | #60 | |
Moto Lover
187
Rep 591
I do like how he responds to people on this thread: https://www.bimmerforums.com/forum/s...auto-coilovers His username is "Jaze". |
09-05-2020, 09:48 PM | #61 |
Rep 396
Drives: 2014 335i M Sport, 2004 .:R32T
following as I'm very interested in getting a set of the 500 series coilovers. Used the calculator made by FaRKle! (huge thanks for that!) and see why he is recommending the 5k/16k spring rates. I wonder what they will say about they dampers with these rates when you ask itsrichierich .
09-08-2020, 04:05 PM | #63 |
Rep 396
Came here to post the same replies from them as i also asked about the 5k/16k spring rate option. pauli18c did you follow up with them about their one customer who did the 6k/16k option?
09-08-2020, 07:07 PM | #64 |
Rep 519
no, I feel like he doesn't really care to help or explain anything. I'll probably be going with Ohlin's Road and Track instead. Doesn't seem like they want the business other than selling their pre packaged setup
09-08-2020, 07:15 PM | #65 | |
Rep 1,934
09-08-2020, 07:49 PM | #66 |
Rep 3,539
Whether you intended to or not, you kind of put them though a trick question/test. The F/R frequency numbers you stated for the 5/16k setup are far too low (should be 1.73/1.98Hz). If I had received your email I would've probably asked you to check your numbers or said "Are you sure my coilovers are softer than your M-Sport suspension?" instead of outright dismissing the concern and stating that the frequencies don't apply, which is silly. You can try to maintain body control by over damping the the system, but you give up grip and comfort that way. Twin-tube/monotube has nothing to do with it.
That's just the normal R&T PN.
