06-25-2020, 11:40 AM | #2817 | |
Rep 15
06-25-2020, 11:55 AM | #2818 |
Rep 1,217
06-25-2020, 12:14 PM | #2820 | |
Rep 28
I am trying to recreate the bin with the correct isp script. |
06-25-2020, 12:50 PM | #2821 | |
Rep 280
Took them from the original .bin. You have to look for start and end of each partition and extract them with dd. //Edit: Only xboot. Uboot2 comes from the extract function and is identical with uboot0 and uboot1, so just make copies. xboot1 and xboot2 are also identical, so just extract that with dd from the original .bin and you should be fine. |
x-m4n148.00 touchmynappa58.50 |
06-25-2020, 03:23 PM | #2822 |
Rep 22
Just installed my box, so far everything is working well. But I still have to test phone calls.
Does anybody know if the sequence of the apps in CarPlay can be changed? |
06-25-2020, 03:39 PM | #2824 | |
Rep 42
Only WAZE has his own app volume setting... Also WhatsApp and telegram need separate volume Controls 🤷🏻*♂️ |
06-25-2020, 05:26 PM | #2825 |
Rep 42
Just updated to latest system and mcu for Carlinkit. All of a sudden, Waze is over-modulating/clipping in volume. I don't see any settings other than main volume, and Volume assist on the Carlinkit settings/audio/, and in Waze app on my iPhone- I turned the volume to 19% in the Waze settings. That did nothing to the scortching volume when listening to music, for example from Spotify. Anyone else notice this since updating? Anyone find a solution to this?
06-25-2020, 06:13 PM | #2826 |
Rep 1,217
I've been fiddling with binwalk with the hope of eventually disabling bluetooth on my Carlinkit unit. I'm far from being even close to doing this (still learning), but I am able to dd the partitions so let me know if you need help.
06-25-2020, 06:42 PM | #2827 | |
Rep 21
As for voice calls: I think the issue is there is a conflict between the carplay box and the car's bluetooth. Do you or anyone know the best way to set this up for voice calls? I sometimes listen to the radio so completely removing my phone won't work. Also, is there a way to increase the volume with google maps independent of the rest of the audio? I'm using the carlinkit Thanks
2016 F82 MW/SO 6MT
06-26-2020, 05:05 AM | #2829 |
Rep 143
1. In the settings of audio you have two volume settings. One if for general and the other is for voice over like navigation. Also, in google maps click on the cog-wheel for setting and you can test the volume you set in carlink settings. It's back and forth process but you only have to set it once.
06-26-2020, 07:50 AM | #2830 | |
Rep 256
06-26-2020, 08:14 AM | #2831 | |
Rep 350
Id like to turn call volume and nav up a bit Does anyone have full screen reverse camera working? For me, the parking lines go full screen but the image does not. It also doesn't show parking sensors full screen. All works ok on the smaller screen (although camera 'jults' once or twice in use)
Current - BMW 320D LCI M SPORT
Previous - BMW 320i XDrive M SPORT Last edited by darylrese; 06-26-2020 at 08:22 AM.. |
06-26-2020, 10:13 AM | #2833 | |
Rep 21
Would it open carplay automatically so I can answer the call? Thanks
2016 F82 MW/SO 6MT
06-26-2020, 11:02 AM | #2834 | |
Rep 78
06-26-2020, 11:15 AM | #2835 |
Rep 78
06-26-2020, 11:37 AM | #2836 |
Rep 28
I got them. Only problem I see with the newly created ISPBOOOT.BIN is the scripts are different. I will try to inject the scripts from the original .bin
06-26-2020, 11:47 AM | #2837 |
Rep 1,217
06-26-2020, 11:49 AM | #2838 |
Rep 280
I have good and bad news.
Good news first: I heavily modified the isp.c script and am successfully able to flash customized .bin files. Even the ones where I changed the squashfs partition to have 720p Android Auto. The bad news: Since I wiped off my device key, I can't use it anymore :/ Only Settings and Camera are working. The WirelessDev, AA, Carplay etc menus are not responsive. Shit |
andream, android, android auto, apple, carplay, mmi, retrofit |
