06-26-2020, 11:52 AM | #2839 | |
Rep 93
06-26-2020, 11:56 AM | #2840 |
Rep 280
06-26-2020, 12:15 PM | #2842 | |
Rep 1,217
I have a Carlinkit and have a 6.5" screen so I can't test your modded bin but someone else may be willing to test it... I'm more interested in disabling Bluetooth. So if you are willing to disable bt on the latest Carlinkit ispbooot I am willing to test it. |
06-26-2020, 12:15 PM | #2843 | |
Rep 843
Yes might be worth trying the earliest software version and then working your way up, just incase 1 of them has the key in it and flashes it to the unit. Failing that, you will need to work on that nand dump script and then hopefully one of us can send you a key that way. |
06-26-2020, 12:20 PM | #2844 |
Rep 2,590
I have carlinkit and the larger screen (10.25 I think?), I'm willing to give it a try. I'm currently using 9.2.5, if that matters.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
06-26-2020, 12:21 PM | #2845 |
Rep 350
Went for two long drives today. The first drive the andream box was absolutely fine using Waze and Spotify. The second trip, about 40 mins in, everything started to lag massively to the point it became unusable. The album art wouldnt load, skip a song / launch siri was lagging behind by a minute or so and the navigation in waze was jerking forward every 5 seconds or so at about 1fps.
After staying like this for about 20 mins, it then returned to normal for the last part of the trip. Anyone had this before on latest software and MCU? (wireless carplay iPhone XR on a wireless charger in the armrest)
Current - BMW 320D LCI M SPORT
Previous - BMW 320i XDrive M SPORT |
06-26-2020, 12:22 PM | #2846 |
Rep 843
Love the way everyone is queuing up to brick there units now.
Remember guys, this isn't a soft brick like when you put an invalid update on. This is fully bricking the unit now, until we can find a way to dump a working nand and reflash a non working unit with it. |
Mollyran72.00 |
06-26-2020, 12:46 PM | #2847 | |
Rep 28
would you mind sharing the isp.c file? |
06-26-2020, 12:50 PM | #2848 | ||||
Matusov
Rep 43
Could you refresh his nand remote? Similarly how coding was done in the past? |
06-26-2020, 02:00 PM | #2850 | |
Rep 256
darylrese65.00 |
06-26-2020, 02:10 PM | #2851 | |
Rep 289
So the flash doesnt work now because previously you broke it? Would it work on someone else's working unit? |
06-26-2020, 02:15 PM | #2852 | |
Rep 350
It literally slowed down to a non working state but i didnt check the phone at the time as it was in the armrest...will see what its like as weather gets cooler
Previous - BMW 320i XDrive M SPORT Last edited by darylrese; 06-26-2020 at 02:26 PM.. |
06-26-2020, 02:27 PM | #2853 | |
Rep 280
It should work on someone else's unit, yes. I'm confident that it works (the flash script is exactly the same), but we won't know unless someone crazy enough to risk a brick tries it |
x-m4n148.00 touchmynappa58.50 |
06-26-2020, 02:38 PM | #2854 | |
Rep 143
06-26-2020, 02:41 PM | #2855 | |
Rep 289
06-26-2020, 02:44 PM | #2856 | |
Rep 2,590
2015 BMW 535xi
06-26-2020, 02:48 PM | #2858 |
Rep 2,590
Dang. Well, if anyone is willing to make one for carlinkit, I'm willing to be a guinea pig.
2015 BMW 535xi
06-26-2020, 02:49 PM | #2859 |
Rep 1,217
06-26-2020, 02:49 PM | #2860 |
Rep 843
andream, android, android auto, apple, carplay, mmi, retrofit |
