08-13-2020, 06:00 PM | #4181 | |
Rep 6,707
08-13-2020, 06:03 PM | #4182 | |
Rep 1,217
x-m4n148.00 |
08-13-2020, 06:47 PM | #4183 |
Rep 57
Thanks for the tips, but before I take apart more of the car, I test-fit all the cables, and... no screen. I can hear music playing, the LVDS cables are in the right place (tested by leaving the LVDS connected to the MMI box as a passthrough, and removing/replacing the Quadlock splice). I have tested with the #3 dip in both the on an off position, still no screen. Cable going to the back of the 8.8 screen was not removed, only disconnected the LVDS from the rear of the main unit and added in the LVDS extension cables.
No other cables have been replaced/swapped. Steering wheel controls (scrolling through song list on armrest USB drive and volume) still work. Not sure what I'm doing wrong here Edit - device I ordered: https://www.amazon.com/gp/product/B084SVKWTW Currently using the DIP switch diagram on the first page of this thread as a guide (RoadTop may be different but have not received installation instructions yet). Last edited by MrSeabass; 08-13-2020 at 07:46 PM.. |
08-13-2020, 07:08 PM | #4184 |
Rep 52
I'm on the same situation as you, I have Andream B version with V.1.0.2 but not sure if I can flash 20.6 MCU. Any chance you've done the update ?
08-13-2020, 08:00 PM | #4185 |
Rep 48
I'm trying to install an andream box, software version 2.1.0.6, and don't have audio while using carplay. My car has the CIC high and it seems that I would have to run the 3.5 mm aux to the center console. However, my box doesn't seem to have that cable anywhere (it's not part of the quadlock cable)? Did all boxes come with the 3.5 mm cable? If not, is there any other way for me to get audio with CIC high?
I have already set the media mode to Aux and have transferred the two green cables so I have audio using the normal iDrive, just not when using CarPlay. |
08-13-2020, 08:10 PM | #4186 | |
Rep 84
435i M Package, VRSF FMIC, VRSF CP, MHD stage 2+, stock cat
08-13-2020, 09:11 PM | #4187 | |
Rep 52
My Andream is now running B_V 1.2 / MCU 20.06.02 I was actually hoping that the MCU update would fix Android Auto Night/Day switch as currently mine is always on night mode. But from what I read looks like the community version is the the only way to go with the fix. But not sure if someone tried it already with those new Andream models. |
wk2100033.00 |
08-13-2020, 10:46 PM | #4188 | |
Rep 57
Okay, exchanged emails with RoadTop, and the instructions had the wrong DIP switch setting. Only turning 3 and 4 on got the screen to work. Now, there's no audio with Android Auto. Yes, I unpaired/deleted the phone from iDrive. Yes, AUX is set as the audio device in iDrive. Yes, Android Auto pairs wirelessly just fine to my Pixel 3a. All I end up getting is the radio showing up at random because the iDrive apparently still navigates the CIC in the background. Google/YT music apps are appearing on the Auto screen, and it is showing the music as playing both on the screen and on the phone... but no sound. Starting to lose my patience with all this. Last edited by MrSeabass; 08-13-2020 at 11:07 PM.. |
08-13-2020, 11:30 PM | #4189 |
Rep 57
Okay, likely final update - turns out I did have to plug in the 3.5mm cord to the center console to get audio despite the instructions to the contrary. The audio sounds like shit, and I still end up with the radio accidentally coming on here and there as I navigate an extremely sluggish menu with iDrive.
Gonna box this up and return it. Huge headache, and I may look into the touchscreen replacement options instead. |
08-14-2020, 07:34 AM | #4190 | ||
Rep 84
wk2100033.00 |
08-14-2020, 09:15 AM | #4191 |
Rep 52
08-14-2020, 11:41 AM | #4192 | |
Rep 1,217
08-14-2020, 03:41 PM | #4193 |
Rep 301
Drives: BMW M235i
With the new custom v2 firmware, most of the time I'm unable to get AA to launch automatically and also can't get it to launch when I click the AA icon with the idrive controller.
This didn't really happen with the Andream firmware. Occasionally when running the Andream firmware, wireless AA would disconnect, but I'd go into the settings and disconnect/reconnect then would be prompted to start AA again. I've tried doing this in the custom firmware with the Bimmertech layout in wireless settings where I see my phone but when I click my phone to disconnect, nothing happens. If I toggle over I can delete my phone but I doubt that I'd want to do that. I'd far prefer to use wireless AA but to do some testing with wired AA, I did find it more reliable, however if my phone bumps around, when connected, AA drops out and sometimes it will relaunch but if it doesn't other than disconnecting my phone and reconnecting, I haven't been able to figure out how to re-initiate AA. I don't know if this MMI unit is particularly finicky but when I've used a rental car that had stock AA, I've never had any issues with AA disconnecting, if my phone was bouncing around due to "spirited" driving. Do others have issues with wired AA disconnecting like this? BTW I'm still having issues with Autolink seeming to conflict with wired AA, so that Autolink is simply unusable. |
08-14-2020, 04:05 PM | #4194 | |
Rep 1,217
I was previously using a Samsung Galaxy S7 and that was slow and unreliable with wireless AA. Which phone are you using? |
08-14-2020, 04:13 PM | #4195 | ||
Rep 301
Drives: BMW M235i
With the stock Andream firmware it was mostly reliable, however for some reason wireless AA would always die within the first 10-15 minutes of driving but once I disconnected in the MMI settings and reconnected, AA wouldn't have any problems after that. |
08-14-2020, 04:41 PM | #4196 | |
Rep 1,683
Drives: 22 X3MC MBB - C-17 Globemaster
Wireless AA is currently fucked because it requires too muich bandwidth and these machines have a hard time cutting it. Theres also patches rolling out from google because AA is fucked up after a recent patch run. If you have no sound in AA its either you didnt move over teh fiber optic to the new harness or settings in phone of some sort. You do not need to plug in the AUX cable because its an inline splice. and yes the aux in is shit quality because of that. Your unit may be defective if this is the case. For about $100 more you can get and android headunit that does all of this just as well and you add touch screen capabilities, its baller and worth it for anyone with out it. Get a 10.25" and enjoy the new hotness. |
08-14-2020, 04:57 PM | #4197 | |
Rep 1,217
But what may help is to begin with a clean slate by clearing cache and data from the AA, Google, and Google Play services apps. Deleting the mmi's wifi and bt connections from your phone. Then going through the proper mmi pairing procedure again. |
grocerylist268.00 |
08-14-2020, 05:19 PM | #4198 | |
Rep 41
Once connected however it is very reliable. |
08-14-2020, 05:26 PM | #4199 | |
Rep 1,217
AA disconnects when the wifi connection to the mmi is not stable. You want to make sure that the mmi wifi antenna is not touching metal. Trying a different wifi channel may also help. Last edited by muniz_ri; 08-14-2020 at 05:33 PM.. |
08-14-2020, 05:29 PM | #4200 | |
Rep 57
Android headunit is an option, but even with the short time I played with AA, BMW's use of map/music splitscreen and snappy steering wheel controls made me feel like maybe I'm not missing out on the experience afterall. |
08-14-2020, 05:53 PM | #4201 |
Rep 84
You might have to wait for a custom firmware for the B units or for a new release from Andream to fix it. I have CarPlay so I dont have that issue
08-14-2020, 07:31 PM | #4202 |
Rep 9
Hello all
I have a big problem with my box that I installed today My car : BMW F20 2016 120D NBT My box : Andream Software used (after update) : v2.1.0.8.multiusb.gpe.b (PIN: 2863) v1.0.A0.mod (PIN: 2863) (Not cross compatible) (based on: v2.1.0.6.gpe.b) When I installed the box, I lost the possibility to show next/previous (music / radio ...) in my extended cluster (before, for exemple, when I wanted to switch the radio station or the music in bluetooth of my iPhone-, using the button of stelrling wheel, I had the info shown in my cluster in the digital screen, now, it's not showing anymore after the box installed), but it works without showing in the screen (with a swipe up, then press, it changed radio for exemple) I also lost the information about my car (maintenance deadlines, control of oil, breaks, average consumption ..), now it's empty, only the historic of maintenance is okay When I am in CarPlay mode, I cannot switch music (iPhone 11 pro max iOS 13.6) with the button of my wheel, when I activate the option in CarPlay setting, it uses my button(scroll up, scroll down) to navigate in the CarPlay menu (like if I turn the dial right or left), and it's not changing any music), when I use the physical buttons left/right on the dash, they switch music next/previous .. The buttons for Siri, phone, volume are working well on my wheel Overall, CarPlay is working good (wifi), I only have those problems, did you noticed those issues ? what can I do please ? (I really like to use the buttons in meh wheel ^^), and the extended display to show the next music/radio and the information about maintenance and consumption on the NBT) Thank you |
andream, android, android auto, apple, carplay, mmi, retrofit |
