06-07-2017, 01:31 AM | #111 |
Rep 74
Hi there,
Great work with front PDC retrofit. I wonder if there is a way to adjust the rear PDC sensitivity. After NBT retrofit my rear PDC is awkwardly sensitive but laggy as well. I mean there is a time lag when the sensor beeps but the amount of that beep is exaggerated when the actual distance is observed. |
06-08-2017, 07:37 PM | #112 |
Rep 76
I recently had the OEM rear view camera and the rear PDC installed on my F30. I had the front PDC installed today but don't have anyone to code it until Monday. I have zero experience in coding but done lots of reading and am naturally good at this stuff.
Now, the 508 option is already there but the front PDC isn't working. How do i get it to work? Last edited by iFreeStylin; 06-09-2017 at 10:36 AM.. |
06-09-2017, 01:12 PM | #114 |
Rep 76
No I didn't change FA my self. There is no 507 only 508. It seems 508 is already added to FA and the modules seems to coded too. Am just not sure what to do as it seems they should be working unless am missing something.
06-09-2017, 02:00 PM | #115 |
Rep 740
Did you try re-coding the FEM_Body, REM,HU_NBT & ICM?
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
iFreeStylin19.00 |
06-09-2017, 02:12 PM | #116 |
Rep 76
06-09-2017, 02:24 PM | #117 | |
Rep 740
http://www.bmwesys.com/guides/VO%20C...ep%20Guide.pdf
iFreeStylin19.00 |
06-09-2017, 02:28 PM | #118 | |
Rep 76
06-09-2017, 02:46 PM | #119 |
Rep 740
As long the 508 is there, all you have to do is code the affecting ECUs that I listed above. This will overwrite any FDL codings you may have on those ECUs.
iFreeStylin19.00 |
06-09-2017, 03:21 PM | #120 |
Rep 76
Thanks i got the front PDC's working! Lost a bunch of coding i had done tho. Well at least now i get a chance to do them on my own.
06-09-2017, 03:34 PM | #121 |
Rep 740
06-11-2017, 03:44 AM | #123 |
Rep 53
Thanks jkwhar for all the help, managed to plug in the wires and the button is working as it should. Although my hands are pretty scratched up now it's actually not so difficult once you know what you're doing, I could now probably remove the plug in a couple of mins.
06-11-2017, 02:53 PM | #124 | |
Rep 740
07-04-2017, 09:03 AM | #125 |
Rep 53
Still struggling with this upgrade, haven't had much time to work on the car but I finally have the new front bumper fitted with PDC sensors and everything set up EXCEPT that it's impossible to correctly plug in the retrofit kit wires into REM. For some reason the plugs seem to big and they won't plug in unless you use a lot of force, and even then, it looks kind of sketchy (they won't correctly click into place, looks like they may short etc...).
In the end I've now ordered a new REM connector + a bunch of repair wires since the two repair wires I had seemed to plug in just fine. It's weird, the ones in the retrofit kit look correct but I guess they're fractionally too big. |
07-06-2017, 08:42 AM | #126 | |
Rep 740
08-15-2017, 09:21 PM | #127 | |
Rep 47
Hi jkwhar, What about the Centre console control unit retrofit cable that is part of the install kit? Did you make it yourself as well? Thanks |
08-19-2017, 12:14 PM | #128 | ||
Rep 44
08-22-2017, 07:08 AM | #130 |
Rep 740
I made my own. Pretty easy to make. I just made sure the factory wire colors followed thru from the PDC sensor harness(where the PDC sensor connects to) all the way back to the REM.
08-22-2017, 07:10 AM | #131 | |
Rep 740
EDIT: I think it came with the HSD Cable set for the surround view retrofit.
08-22-2017, 07:51 AM | #132 | |
Rep 2,302
part number: 61122334361 It is also included to the PDC front retrofit kit with part number 66202338070 |
