06-20-2016, 01:05 PM | #243 |
Rep 325
Can someone help me with FDL coding for rear view camera? I have an NBT witch I don't want to VO code it with 3AG, and I have to FDL code it for rear view camera.
Thank you. |
Isaauk20140.00 |
06-20-2016, 01:36 PM | #244 |
Rep 13
06-20-2016, 04:45 PM | #245 |
Rep 2,302
Somewhere in Rheingold there is a service function to calibrate the rear view camera.
You have to search under "vehicle management" or "service plan". You can also search under information for rear view camera. There you find repair instructions, circuit diagrams and also service plans for the rear view camera. Another possibility is that you connect your car with rheingold and make a complete vehicle identification. Then you will see the ecu tree with all ecus. There you click on TRSVC ecu and check what you can do there. I just cannot search for it because i'm on work. |
06-20-2016, 04:50 PM | #246 | |
Rep 13
06-20-2016, 04:52 PM | #247 | |
Rep 2,302
I promise Edit: And here it is... HU_NBT > EXBOX 3001 > AUX1_IN_HU = wert_255 [Default] HU_NBT > EXBOX 3001 > CAMERA_SYSTEM = trsvc HU_NBT > EXBOX 3001 > MACRO_RV_C = aktiv HU_NBT > EXBOX 3001 > TRSVC = wert_81 And maybe you need also the codings in REM... REM_01 > PdcParkMasterVar 3203 > RVC = wert_02 And then as a little bonus you can code the zoom for the trailer coupling. HU_NBT > EXBOX 3001 >MACRO_TRAILER_COUPLING = aktiv Last edited by atzebmw; 06-21-2016 at 12:01 AM.. |
06-21-2016, 01:12 PM | #248 |
Rep 208
Hy, I have a question concerning the CAN Connection: in the Manual for F30 is written that the can should be connected to FEM. In the EBA for F25 is written that it should be connected befind the HU. Can I use Both connections? Because befind the HU I could connect the wires together with the can filter...?
06-21-2016, 01:16 PM | #249 | |
Rep 2,302
You can connect them whereever you want. |
06-21-2016, 04:06 PM | #251 | |
Rep 2,302
Dann schreib ich mal kurz auf deutsch. Also wenn du die Rückfahrkamera am F30 nachrüsten willst, ist es völlig egal, von wo du die beiden CAN-Kabel abgreifst. Es ist nur wichtig, dass du die richtigen beiden nimmst, also ein grünes und ein orange/grünes Kabel. Beim F25 kann es durchaus sein, dass die beiden CAN-Kabel an einem anderen CAN-Bus angeschlossen sind. Es gibt den K-CAN, den K-CAN2 und ich glaube noch ein paar andere. Also die Kabelfarben können beim F25 durchaus anders sein. And now a little bit shortened in (my bad) english. If you retrofit the rear view camera on a F30 it doesn't matter where you connect the two CAN-wires. It's only important that you choose the right 2 CAN-wires, a green and an orange/green wire. On F25 it's possible that the 2 CAN-wires use another CAN-Bus. There ist K-CAN, K-CAN2 and some other. Maybe the cable colors are different on F25 cars. |
06-21-2016, 04:20 PM | #253 |
Rep 2,302
06-25-2016, 07:47 AM | #255 |
Rep 208
06-25-2016, 12:22 PM | #256 | |
Rep 2,302
But it doesn't work only why the green and orange/green wires at the HU are no CAN-wires. They are for other stuff i just checked in Rheingold. That's why i have to take back my statement to use the two wires whereever you want. It's better to be sure that the green and orange/green wires are for K-CAN_High and K-CAN_Low. Preferably to use the Original Installation Instruction. |
06-25-2016, 03:28 PM | #257 |
Rep 208
I ended Up using the two can wires at FEM...
Do you perhaps know how I can Update the Firmware on my HU? For my Business nav it worked with esys; but for the Professional no Update is found.... |
06-25-2016, 03:57 PM | #258 | |
Rep 2,302
I'm very fit in coding but this i don't trust. If you find no update maybe your psdzdata are too old. |
07-03-2016, 04:09 PM | #259 |
Rep 21
I did a retrofit for an aftermarket camera with camera module on top of a retrofitted NBT. I recorded this video for others doing the sameamd think it will help for both OEM and aftermarket as there are common steps in both.
I still have one problem with the dynamic lines. I have been advised in another post to twist the CAN wires so will do that and see if it works. You can also see my other video on my channel for the full NBT retrofit |
07-22-2016, 02:28 PM | #260 | |
Rep 6
sorry for the hijack, but this coding helped me in installing my backup camera on my 2014 F10 thank you. |
07-30-2016, 12:37 PM | #261 |
Rep 196
Hi guys
Just a quick update on my reverse camera install. I also suffered from the grey screen (ie no camera image). The fault was around the power - the ECU had no power and thus we could not see it in rheingold. Therefore anyone with the same issue I'd advise to check the power and grounding. In my case there was no power and we attached the wiring to an alternative spare 5A fuse in the fuse box. In should be noted that even though my camera ECU (TRSV) was not connected to power we could read voltages across the various wires so there must be some voltage in the Kcan's and the 3 lines that run to the CIC/NBT. Thanks |
08-02-2016, 06:18 AM | #262 |
Rep 17
08-09-2016, 01:25 PM | #263 |
Rep 100
anyone knows where to buy the cable from pin 4 ( connector 10 pin) to pin 23 NBT ( video cable ) I 'm doing and I need wiring that cable and connectors
need : https://h-a.d-cd.net/c4057das-960.jpg https://f-a.d-cd.net/e8057das-960.jpg and cable back to alante was passed through the left side or right side? for bmw f21 Last edited by r0b3r; 08-09-2016 at 02:32 PM.. |
08-13-2016, 05:41 PM | #264 |
Rep 235
Hey guys, I completed the retrofit on my 2012 328i and am having no luck getting it to work.
I bought this kit: http://www.ebay.com/itm/262159237970...%3AMEBIDX%3AIT When I reverse, all I see is the PDC screen. I think the module is getting power, because when I go into reverse, the camera icon is now white instead of being grayed out. Clicking on it with the idrive does nothing, however. If I take out the corresponding fuse in the fusebox, it becomes grayed out again. I tapped into the CAN bus at connector A173*8B as follows: OR/GN cable to Pin 52 GN cable to pin 51 I then inserted the yellow (red for most of you guys, but I verified it went into the same pin in the camera module), white, and shield pins into the quadlock as follows: Yellow - FBAS+ -------------------> Pin 21 White - FBAS ----------------------> Pin 24 Tranparent cable - shield--------> Pin 23 Had a guy do the remote coding and he coded the new trsvc module with my VIN and VO coded with the pdc and rear view camera codes. Any idea on what it could be? Do I have the correct camera module (66539393953)? Appreciate any help on this. |
