BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Horn does not work AGAIN!
proTUNING Freaks
      05-21-2018, 08:32 PM   #45
vooonoo
¯\_(ツ)_/¯
vooonoo's Avatar
537
Drives: f30 328
2014 f30 328i  [0.00]
Can someone post a video of what their horn sounds like? I'm pretty sure one of mine aren't working properly the horn sounds wimpy
      05-22-2018, 07:22 PM   #46
TimberCove
Drives: F30 335i
My horn stopped working. Located the fuse near the passenger foot well and it was not blown. Took it out and waited a minute and plugged a fresh new one back in. Still no sound.
When hitting the horn, there's a "clicking" sound hitting that fuse box so that leads me to believe that the connection is fine.
Likely to be the horn itself? How likely that both the high and low went out at the same time?
      05-22-2018, 09:51 PM   #47
Dirk Diggler
Drives: F30 335i
Pull out a horn and try connecting directly to a 12v source. If it doesn't work, you prob need new horns.
      10-24-2018, 10:46 PM   #48
vooonoo
¯\_(ツ)_/¯
vooonoo's Avatar
537
Drives: f30 328
Jacking the thread. My low tone horn is dead again. Anyone know if you can install these?
https://www.amazon.com/HELLA-Protect...words=car+horn
      10-25-2018, 07:48 AM   #49
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
You can. Get the version that includes a relay. You'd use the existing wiring to the horns as the relay trigger.
      10-25-2018, 07:49 AM   #50
rparnel1
Drives: 2014 328d
My horns stopped working. Put power directly to horn and it worked. Did not measure any output to horn. Fuse was good. Connections were good. Suspected it was in steering wheel, since it had been erratic before it stopped. Had independent mechanic look at steering wheel contacts when I had it in for a transmission fluid change. He didn't see anything really wrong, but made some "adjustment" to the assembly and now it works.
      10-25-2018, 06:40 PM   #51
lkstaack
lkstaack's Avatar
Drives: F30 335i
My horns work fine now. But, they were replaced at 15,000 miles, along with my steering wheel before I bought it. I don't know if there was a link between the horn issue and steering wheel.
      06-09-2020, 02:33 PM   #52
Crowbar
Drives: F-32 convertable front end
Horn issue
I found a little dielectric grease on the fuse pins makes for a much more secure connection. No problems with horn in over a year.
      08-10-2020, 03:50 PM   #53
BimmerHJ
Drives: 2013 328i xDrive
Here's Service Information bulletin for Horn Fails.
https://static.nhtsa.gov/odi/tsbs/20...47721-9999.pdf
      12-03-2021, 03:10 PM   #54
motorwerkeman
Drives: 2012 328i
Originally Posted by motorwerkeman View Post
God damn it. Trying the fuse tonight, but I only have the high-pitched one working at the moment so thinking I need a horn.
Guess what part I need again!!!
BMW Quality. 2nd engine, 3rd set of horns.
