04-09-2019, 04:19 AM | #23 | |
Rep 724
10-24-2019, 02:02 PM | #25 |
Rep 8
Hi, Did you install the emtronika rear view camera on your F36 GC? I have a 2015 F36 and also purchased this unit. Can you please share some installation thoughts on how to remove the tailgate trim and wire the system. I will appreciate the help and thank you in advance.
10-26-2019, 11:50 AM | #26 | |
Rep 724
10-26-2019, 01:56 PM | #27 |
Regular user
224
Rep 965
Drives: F30 330D M-Sport Auto
I've just ordered the Emtronika kit for my F30 with NBT Pro Nav.
Did anyone get anywhere with coding via Bimmercode as that's all I have?
10-26-2019, 03:55 PM | #28 |
Rep 724
There are two parts to the coding, one which can be done by Bimmercode, but with the other you need to add a file, so you do need to use esys. Just ask on the forum, there will be someone from your area that will be happy to help, someone did for me.
muffking224.00 |
10-28-2019, 11:11 AM | #29 |
Regular user
224
Rep 965
Thanks.
Mine arrived today and I plan to install it on Wednesday. My only concerns are how much of the coding I can get away with using Bimmercode and what the DIP switches are for as there are absolutely no instructions.
10-29-2019, 06:36 AM | #30 |
Rep 8,636
Ping them and they will send you links to the files and pics around the dip switches. In fact found the old ones I was sent, here you go:
https://1drv.ms/u/s!ApzL9ShB1vU_1ijp...Sh-2t?e=qvnfWp Last edited by SkyJawa; 10-29-2019 at 07:02 AM.. |
muffking224.00 |
10-29-2019, 02:27 PM | #31 |
Regular user
224
Rep 965
Thanks for that. I'm not sure if they're the same as my box is slightly different, but this is now a job for the weekend as I'll now be working tomorrow.
10-29-2019, 02:37 PM | #32 |
Rep 724
From memory, the dip switches were just the first one and the last one. I know the last one was missed at time, which is one of the problems of fitting without coding. Mind you it only takes 5/10 minutes to strip the dash.
10-29-2019, 02:38 PM | #33 | |
Rep 724
SkyJawa3718.50 |
10-29-2019, 03:08 PM | #34 |
Regular user
224
Rep 965
At the moment they are all in the OFF position.
It's not conclusive looking at the attachments, so I'll message them.
10-29-2019, 03:37 PM | #35 |
Regular user
224
Rep 965
Just had a response. Apparently DIP 1 needs to be on if the car has a pma2 module. All others must be OFF.
Makes me wonder why they would send it out with all DIPs OFF and no instructions??? Plus I don't know if I have a pma2 module and that may not reveal itself until coding.
10-29-2019, 08:03 PM | #36 | |
Rep 724
11-01-2019, 01:48 PM | #37 |
Regular user
224
Rep 965
Success.
After setting all dips back to OFF I undid all of the coding left the car for a while so everything shut down. I went back a few hours later and did the coding all over again. Now it works You can tell that it's not original BMW as my previous F31 was spec'd with a parking cam, but this is a very good copy. I also added the coding for the tow bar zoom which was mentioned on here. This extra option on the camera side menu allows the line to tell you where the trailer will go when reversing, just like the parking guide lines. And to top it off I coded the rear cam to stay on up to 50kph so I can keep an eye on my trailer
11-01-2019, 01:52 PM | #38 |
Regular user
224
Rep 965
For reference, anyone wanting to code using Bimmercode, the lines for the NBT head unit are:-
REM_01 > PdcParkMasterVar 3203 > RVC = wert_02 HU_NBT > EXBOX 3001 > AUX1_IN_HU = wert_255 [Default] HU_NBT > EXBOX 3001 > CAMERA_SYSTEM = trsvc HU_NBT > EXBOX 3001 > MACRO_RV_C = aktiv HU_NBT > EXBOX 3001 > TRSVC = wert_81 and somewhere in HU_NBT > MACRO_TRAILER_COUPLING for the trailer zoom option.
APJ245.00 |
11-01-2019, 02:13 PM | #39 | |
Rep 724
11-01-2019, 03:22 PM | #40 |
Regular user
224
Rep 965
Yep. I'm really pleased with myself. Even gonna celebrate with a beer
11-01-2019, 07:44 PM | #41 | |
Rep 724
For future reference though, think you can find the trailer zoom a little easier and not have to go in to expert mode, its in Headunit under 'Rear view camera zoom'. Wish you'd have done this before me, had to get one of the local chaps round to do it with esys |
11-02-2019, 03:40 AM | #42 | |
Regular user
224
Rep 965
11-02-2019, 03:44 AM | #43 | |
Regular user
224
Rep 965
11-02-2019, 02:23 PM | #44 |
Rep 724
