11-12-2019, 09:28 AM | #1673 |
NewFinishColumbia/detailer
604
Rep 2,096
Look on the back side of the wheels. It should be on one of the spokes along with the actual sizes of each wheel.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
11-16-2019, 05:28 PM | #1674 |
2015 BMW 428i xDrive Coupe
Rep 9
Yes!!!! I found it. Thank you guys. Here is what it says:
(2) E 9J X 19EH2 IS48 (2) E10J X19EH2 IS45 Does that give me a tire size? Thanks again! Much appreciated. |
11-16-2019, 11:25 PM | #1675 |
Rep 9
From what I found online these are the tires that fit my rims:
(2) E 9J X 19EH2 IS48... 255/50 R19 (2) E10J X19EH2 IS45... 285/45 R19 I don't know if these would actually fit a 2015 428i xDrive coupe though?? |
11-17-2019, 12:49 AM | #1676 |
Cheapskate
4447
Rep 4,993
The tires are way too tall, and probably too wide up front. Those offsets aren't really made for our cars. The front wheels should be et35 or so to fit well. If you run a 10-15mm spacer it'll probably work. Try 245/35/19 and 275/30/19.
11-17-2019, 02:37 AM | #1677 |
Rep 9
Thank you for the response! I was worried about them being too tall. After all, I found out they came off of a 2011 X5. These rims are so sweet... it sucks but I'm sure I can sell them.
Would 245/35/19 and 275/30/19 fit these rims? It would look like this... (2) E 9J X 19EH2 IS48... 245/35/19 (2) E10J X19EH2 IS45... 275/30/19 If that would work I'll get those tires! Sorry for all the newb questions. And I'll Google the spacers you mentioned. Thanks again! |
11-18-2019, 06:36 AM | #1678 | |
Cheapskate
4447
Rep 4,993
Something like this https://x-ph.com/bmw-wheel-spacers-by-bms-sold-by-pair/ Also if you wait a week or so, everything will be going on sale for Black Friday. Otherwise you can get good deals on used spacers in the classifieds. |
11-29-2019, 03:36 PM | #1680 |
Rep 25
No rubbing for far been a couple days. Fronts are 8.5 and rears are 9.5 Niche wheels on stock suspension
Tires are 255/35/19 275/35/19
Amiry
11-30-2019, 01:17 AM | #1681 | |
Rep 500
Drives: BMW 330e F30 M-sport
But you didn't measure the height with the same wheels. Perhaps the diameter of your new wheel setup is lower, then that will add to the drop as well.
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
11-30-2019, 12:20 PM | #1682 |
Cheapskate
4447
Rep 4,993
Springs/stock suspension does not constitute as slammed, fellas.
12-02-2019, 05:14 PM | #1683 |
Rep 22
I think this belongs here...
2013 335i
-BC coilovers -ESR CS15 19x9.5 +22 & 19x10.5 +22 -Nankang NS25 235/35/19 & 255/35/19 Does it rub? on fast turns and turning on a steep driveway, sure. Normal freeway driving, barely. It'll hold a dollar bill between the rear fender and tire when the rear seats are loaded with heavy weights. Going to pull a tiny bit of negative camber once i get it aligned. Waiting on adjustable toe arms and camber arms before it heads to the alignment shop. Oh, and we did pull the the rears out a bit.... Definitely the look I was going for! Not your style? all good. Move along. Ill survive. Diggin it? *FIST BUMP and a HIGH FIVE TO YOU* And a little Before and After.... |
12-02-2019, 05:36 PM | #1684 |
Rep 46
quick question about to order some wheels been going through this thread, cars on KW v3 other then that stock, I am ok with doing a slight roll to all fenders what is the most aggressive fitment I can go without rubbing?
Also trying to decide between 18 and 19". My plan so far was 18x9.5 et42 R and 18x9 et30 F 235-40-18 265-35-18. any input is appreciated!
2012 f30 n55 6 M/T, RWD
VRSF Catless DP/CP, CSF FMIC, BM3 Stage 2, KW V3 |
12-03-2019, 10:44 AM | #1685 | ||
Cheapskate
4447
Rep 4,993
12-03-2019, 11:37 AM | #1686 |
Rep 22
[QUOTE=kern417;25528802]way too much poke. get an alignment asap.
lol. Does it rub? on fast turns and turning on a steep driveway, sure. Normal freeway driving, barely. It'll hold a dollar bill between the rear fender and tire when the rear seats are loaded with heavy weights. Going to pull a tiny bit of negative camber once i get it aligned. Waiting on adjustable toe arms and camber arms before it heads to the alignment shop. Oh, and we did pull the the rears out a bit.... Definitely the look I was going for! |
12-03-2019, 12:09 PM | #1687 | |
Cheapskate
4447
Rep 4,993
12-03-2019, 01:09 PM | #1688 |
Rep 22
kern4174446.50 Alpine-F80200.50 |
12-03-2019, 04:27 PM | #1689 | |
Rep 46
Thanks for the info love the look of your setup, I ended up changing my order to ARC-8 from EC-7. the arc-8 were offered in the face profile 3 concavity where the EC-7 were not. glad I caught this because at first I did not know. my new sizes are 18x9.5 ET35 265 R 18x9 ET30 235 F Its gonna be close but Im prepared to do a minor fender roll. I am worried about the front because I had a from F80 LCA / TS upgrade planned which form what I understood pushes the wheel out even further.
12-04-2019, 05:51 AM | #1690 | |
Cheapskate
4447
Rep 4,993
12-04-2019, 07:58 PM | #1691 | |
Rep 145
rear camber arms lol. |
12-16-2019, 04:29 PM | #1692 | |
Rep 22
01-07-2020, 10:36 AM | #1693 |
Cheapskate
4447
Rep 4,993
bump
Alpine-F80200.50 |
01-10-2020, 12:11 PM | #1694 |
Rep 741
what style is the second one? and also rim size and offset plz and tires
2016 435i xDrive F36 M Sport - ER CP | ER Catless DP | VRSF 5" FMIC | bm3 stage 2 93 oct | black double slotted grill | AWE axle back exhaust w/102mm diamond black tips | 437m wheels
aggressive, f30, low, slammed, stance |
