09-29-2017, 05:20 AM | #243 |
Rep 7
Thanks. yeah ive read the post good stuff. I am going to get the guys at Bluespark to fit it for me as it looks a bit Trickey at the back so will also get some advice on best setting while i am there
09-29-2017, 05:54 AM | #244 |
Rep 7,000
09-29-2017, 06:48 AM | #245 |
Rep 7
09-29-2017, 07:08 AM | #247 | |
Rep 7,000
I have had both and the DTUK is better and more refined, also produced more power. Bluespark have a 28 day return policy which I would use if I was in your position. |
09-29-2017, 07:59 AM | #248 | |
Rep 7
09-29-2017, 08:04 AM | #249 | ||
Rep 570
09-29-2017, 08:26 AM | #250 | |
Rep 7,000
DTUK also reprogram the boxes, not difficult to fit once you have done it, I thought DTUK were also in your area? It obviously up to you but you get what you pay for. |
09-29-2017, 08:34 AM | #251 |
Rep 7
if you hadnt tried dtuk would you still recommend bs over the standard factory set up tho.
09-29-2017, 08:53 AM | #252 |
Rep 7,000
That's a bit of an odd thing to say though because you are not comparing apples with apples.
i bought a BS box and it was good it did what it said, however it throws a lot of fuel at the car early on which is a bit crude bit it gives a performance increase it says but the increase in torque is biased towards the early part of the Rev range. Many members on here had the 35D and complained about fuel issues and the car cutting power I then thought about a remap as that's the best option but found out that DTUK had a three channel box so sold the BS and bought the DTUK Immediately upon driving the way the power is delivered is a lot more like a remap you get a constant increase of power across the range rather than a big hit at the beginning The power increase was also stronger on the DTUK box. If I was buying again I would do all of my homework and buy the best box based on people's experiences and my own research. The three channel box is without doubt better. The BS box for me was a pain as to change settings the car had to be switched off then the box removed undo the screws change put it back on etc etc. The DTUK box takes 5 seconds to change. Yes you will notice a difference of the BS box verses standard. To answer your question I would not fit a 2 channel box to my car again knowing what I know As I mentioned you get what you pay for. Either way enjoy the increase in power. |
09-29-2017, 11:51 AM | #253 |
Rep 1,450
Based on all we’ve seen and read over the past few months and the results from different rollers, I would not put a 2ch box on a 35d. The engine simply doesn’t like them and the fuelling issue is apparent when looking at the torque curves versus a properly remapped car.
The 30d seems to respond far better to the tuning boxes but, as JLR says, if you’re going down this route on the 35d make sure you get a triple channel box (DTUK, TDi Tuning, TMC) and you won’t be disappointed. If you’re still not convinced, just look at how many people have come out of the BS boxes from a quick look at the classifieds section! |
09-29-2017, 12:27 PM | #254 | |
Village idiot
750
Rep 1,237
JLR19691882.00 |
09-29-2017, 01:12 PM | #255 |
Rep 7,000
09-29-2017, 02:25 PM | #256 |
Rep 7
You make a strong argument. Did you fit yourself ? Will cost me an extra £140 and they charge more to retune. Couldn't see anything extra to justify the cost over bs. I thought the talk of drop off was just down to peoples choice of settings. I do have time to change my mind. Like I say brought two for the discount. Youve put a cat amount the pigeons
09-29-2017, 03:00 PM | #257 | |
Rep 458
I’m sure if you called Andrew he would sort a deal on 2 boxes. |
09-29-2017, 03:57 PM | #258 | |
Rep 7,000
I don't get any kickbacks I am just giving you my experience of both boxes. The three channel box is better than the two channel. The DTUK boxes are made in Germany by a company called DTE Systems https://www.chiptuning.com/uk/ Cheers Jon |
09-29-2017, 04:09 PM | #259 | ||
Rep 570
09-29-2017, 04:35 PM | #260 | |
Rep 7,000
The one attached is the DTUK v BS both on my car, the DTUK is the top curve |
Darth Helmut1780.00 |
09-29-2017, 04:44 PM | #261 | ||
Rep 570
09-29-2017, 04:45 PM | #262 |
Rep 7,000
09-29-2017, 05:58 PM | #264 |
Rep 7,000
