07-27-2018, 05:43 PM | #45 |
not good, but bad
333
Rep 361
FWIW I made a DIY here on changing it out.
After I installed the new tensioner in my car, the jiggle was gone. See here for the DIY and the video of before and after: http://*************/tensionerdiy/
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
07-27-2018, 05:53 PM | #46 |
Rep 221
Your dampener has a slight wobble which will get worst. This is probably what cause your tensioner to go bad in the first place. Mine is much worse, I plan to replace it soon to avoid another tensioner failure.
08-08-2018, 05:36 PM | #47 |
Rep 799
I was looking at engine the other day and noticed the belt tensioner shaking a little and thought that wasn't normal. Then by chance I stumbled upon this thread. I'm going to order a belt tensioner, belt and a new set of plugs. On the people who replaced the tensioner and belt, how many miles were on your car? I'm just under 30K.
08-09-2018, 09:30 AM | #49 |
Car Hypochondriac
335
Rep 901
Glad I found this thread, made me check my tensioner, was also wiggling. Grabbed a new one and a new idler and belt for shits and giggles. I just hit 50k.
08-14-2018, 12:14 PM | #50 | |
Rep 1,115
My lost to belly pan item count is up to 5. |
badbread332.50 |
08-15-2018, 12:23 AM | #51 |
Rep 1,115
Did mine tonight, oddly enough my 235i tensioner needed a T55 and E14 vs the T50 and E10/12 the F30 folks required. This was probably the easiest thing I've replaced on any BMW. Took 25 mins total and it's dead steady now. A 5/32" R lock pin for a trailer hitch worked perfectly to hold the tension during belt removal. I ordered a new idler pulley but mine seemed fine on inspection. I'll probably replace it next time I do anything else on the car.
08-15-2018, 03:03 PM | #52 | |
Rep 1,467
09-14-2018, 03:02 PM | #53 |
Rep 2,639
Just an update.
I had my car eat through 3 belts and 2 tensioners before we found the actual problem. Front crank seal. If the front of your block has excess oil, or oil on the inside of the belt, runs lean, or the tensioner continues to jiggle even after replacement, I would highly suggest you check your front crank seal. Mine was worn to the point where it would create a vaccum leak causing my car to run lean as shit and stall. It would also spit oil everywhere which caused the belt is slip. After replacing my crank seal, the tensioner is rock solid, and the car runs great now. I am still going to check it now and then to make sure, but I'm pretty sure that was what caused the problem.
badbread332.50 |
09-14-2018, 11:10 PM | #54 |
Rep 2,499
I've seen a few nearly new N55 motors and they all do this jiggle. I don't think it's a sign of impending failure and I think anyone that fixes it is just going to see it happen again after a year or so.
09-14-2018, 11:52 PM | #55 |
Rep 2,639
There's a certain amount, very minimal, but when it starts moving, you'll notice it's not normal at all, and that's when you should be worried.
11-14-2018, 09:49 PM | #56 |
Rep 1
Definitely change it! I just got two recalls done at bmw and one being the OFHG and on my way back home just as I was pulling in to my driveway the battery charging light came on and there was a pool of oil on the floor not sure what happened but I'll be contacting them tomorrow.
04-01-2020, 07:09 PM | #57 |
Rep 754
Drives: 09 //M3 e90 Interlagos Blue
Definitely change the Idler Pulley too, since the bearings inside wear and fail. Need special sockets/tools for this quick job...T55/T60, E12/14, etc. Plus a drill bit or thin philips screwdriver to uses as a pin for the old belt tensioner. Keep the old parts. Cheers |
06-28-2020, 01:51 PM | #58 |
Rep 7,602
Normal amount of wobble?
Bumping a little bit of an older thread here hoping to get input -
TLDR - is the amount of wobble in the video below normal? I was inspecting the engine bay with the car running after installing my MST inlet yesterday and noticed a little bit of wobble on the belt tensioner. If you look closely, the crank pulley also seems to have a slight wobble in it... Not a crazy amount on the crank pulley, and kindof hard to see in the video, but its definitely not rotating perfetly with no side to side or front to back movement. After watching the Kies video, it looks like at a minimum the tensioner might be moving too much. What do you guys think? |
06-28-2020, 09:11 PM | #59 | |
Rep 819
Drives: Bmw 335i f30 N55 ( sold)
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
06-29-2020, 04:28 PM | #60 | |
Rep 7,602
I am mostly wondering if other people can go out and look at their car at idle and see how the wobble of the crank pulley (and tensioner) looks compared to my video. ozymandias435 said his looked just like my video, but looking for a greater sample size lol. |
06-29-2020, 09:36 PM | #61 | ||
Respect My Authoritah
368
Rep 873
The DIY looks easy, so I just bought the parts. Something to do!
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
06-29-2020, 11:10 PM | #62 | |
Rep 55
Drives: 2015 BMW 335i xDrive
06-29-2020, 11:26 PM | #63 | |
Rep 7,602
Yours looks rock solid... both the crank pulley and the tensioner. I am at 46k miles which makes me think mine might be at least starting to have an issue. |
06-30-2020, 01:03 PM | #64 | |
Rep 963
Not sure if this is normal wear and tear over time or if this needs to be resolved asap, but it is in the back of my mind now.
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
06-30-2020, 01:19 PM | #65 |
Car Hypochondriac
335
Rep 901
Mine isn't as apparent as your video, but I've been suspecting my crank pulley is wobbling as well. My tensioner has been replaced multiple times and it always jiggles.
I mostly suspect the crank hub because I have a small amount of oil appearing around it. Not sure if it's coming from the crank seal or a plug that's right next to it. i was planning on removing the hub and cleaning the area under it as well as inspecting the crank seal. Something tells me this is just paranoia though. |
06-30-2020, 01:59 PM | #66 | |
Rep 10,351
IIRC the belt starts to squeak when the tensioner needs replacement, or the belt doesn't track straight, or you hear the bearings making noise.
"Drive more, worry less. "
