08-16-2018, 01:55 AM | #1 |
Rep 1,288
Boostane Vs E85
So I thought I start this thread so I'd stop hijacking other threads... lol.. anyways ... E85 isn't readily available for lots of people and since you can get Boostane on Amazon Prime I'd thought I'd start this thread.... Now to start off this is an incredible BMW 335i Dyno chart from Boostane claiming major horsepower on a stock car... how believable I don't know at this point... so here is the chart.... now if this is true I'm looking forward to a tune with this stuff and wondering if I can run this stuff on a E85blend map on MHD ... at this point I don't see why not... thoughts?...
P.s. I emailed Boostane directly to get there feedback... Last edited by FastF30; 08-16-2018 at 02:04 AM.. |
08-16-2018, 08:16 AM | #2 |
Rep 136
i bought a case of this crap in the spring....no comparison to a e85 tune....
it alleviated a bit of knock correction on the mhd stg 1 91oct map.... i don't recommend it....money better spent on pokeman cards.... |
08-16-2018, 10:03 AM | #3 |
Rep 211
I would love to see someone with logging capabilities test some of this stuff. Searches result in mostly Charger/Challenger board posts with many claiming it works wonders. Note from the posts found though, its not cheap.
http://bndautomotive.com/aces-formul...oline-formula/
Mineral Gray - Active Autowerke Stage 2 - MPerformance Suspension - VRSF CP - CTS Turbo IC - Catted Fabspeed - Akrapovic - HRE FF15
FastF30521.00 |
08-16-2018, 02:29 PM | #4 |
Rep 1,115
Boostane isn't meant to be used instead of E85. E85 tunes have a different AFR than gasoline. Ethanol is oxygenated fuel whereas gasoline regardless of octane isn't. Boostane could allow you to run a 100 Octane tune if you used enough, but not an E30 or E85 tune.
08-18-2018, 10:19 AM | #5 | |
Rep 1,105
09-02-2018, 05:50 PM | #6 |
Rep 267
Greetings! I can say from experience that I felt a huge difference with a can of this in my 2014 335i M Sport with just under 50K, FBO and no Cat. In fact, when I set my JB4 to map 7 my clutch started slipping at about 3K after a half dozen hard pulls. Set it back to map 2, had no issues, ran out the rest of the tank and never messed with it again...lol... Don't wanna put the money into upgrading my clutch at the moment.
09-02-2018, 07:49 PM | #7 |
Rep 965
Drives: 2016 F36 435x MSport
helped stabilize the timing with the clearly crap 93 octane near me:
Before http://www.bootmod3.net/log?id=5b7c1edbd10b4333bb1ba538 After 5oz boostane http://www.bootmod3.net/log?id=5b8315d7d10b43295714997c http://www.bootmod3.net/log?id=5b83184bd10b432957149984
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
the dope steez403.00 |
09-02-2018, 08:15 PM | #8 | |
Rep 3,679
09-02-2018, 08:33 PM | #9 |
Rep 1,115
It's the boostane, I've been running it for a half dozen tanks and it's consistently better than the straight 94 I can get.
DreamerJoe240.50 1bad14-F3030.50 |
09-02-2018, 10:11 PM | #10 |
Rep 808
I agree with paimon, I have tried octane boost, logged pulls and it has shown to improve timing nicely. I'll use half a bottle for half a tank of gas before going to the track - the car feels fantastic and timing is spot on.
That said, boostane or any octane booster does not compare to E85 if your car is tuned for it. I just burned through a tank of E30 mix and I feel bad for my poor clutch. The car pulls noticeably harder than on the 93 tune, whereas the boostane offers no perceptible difference in power. |
09-03-2018, 09:05 AM | #11 |
Rep 3,679
I guess it is the boostane then if everybody gets the same results...
09-04-2018, 02:07 AM | #12 | |
Rep 2,357
(A Dane in China) |
akgambino271.50 |
09-04-2018, 10:11 PM | #13 |
IG @bmwF9xG80
3813
Rep 7,593
Boostane on a 93 map might not show big gains or butt dyno (just mix it for a 95 octane instead)
But if you do use Boostane 5gals with 8oz of it to turn into 100oct then the RaceGas OTS from BM3 will be perfectly suited for it. I saw Demonology on Youtube, guy had better Gains on Dynojet on his Demon with 100oct tune than SunocoGT and GT Plus Race Fuels. Also proved it in the 1/4 mile There's 18-20% Sale right now on Boostane's website go grab those 5 gal pails
60-130mph 6.5s X4M #HCP
09-05-2018, 12:26 PM | #14 |
Rep 1,288
So I'm gonna buy a 16oz bottle and mix 2 ounces per 12gallons which should give me 96 octane and then I can run the 95 MHD octane map just to see.... will be good for 8 fill-ups like that...
09-05-2018, 12:30 PM | #15 | |
Rep 301
I think I'll do the same ratio but keep running the 91 map at an upcoming track day and see if it eliminates the timing corrections I'm getting on crappy Cali 91. |
09-05-2018, 12:55 PM | #16 | |
Rep 1,288
Will do... by the way... never ran this car to Empty on the gas gauge... how many gallons does it hold to fill up from empty so I can do some basic calculations... |
09-05-2018, 03:47 PM | #17 | |
Rep 301
My m235i is under 14 (13.7?). . . .wish it was a couple more gallons . . . |
09-07-2018, 02:50 PM | #18 |
BMW Newbie
Rep 17
Dont mean to threadjack.... BUT, has anyone used RACE-GAS ULTRA Race Fuel Concentrate? Its about the same price as Boostane on Amazon, but 110 octane. Same situation with E85 for me.
F30 335i xDrive MSport 8AT | Wagner Catted DP | BMS Intake | VRSF Race IC | FTP Full Charge + Boost pipes | GFB DV+ Diverter | AWE Mid Pipe | Muffler Delete | H&R Sport Springs | UR Strut Bar | Full LCI Conversion | XHP Flash | MHD Backend Flash | BMS JB4 |
instagram: Sunny_TK |
