01-01-2019, 01:05 PM | #243 |
Rep 1,079
I don't think I felt any difference in Eco mode but Comfort got more responsive, yet smooth, felt a big difference in Sport mode, much more aggressive shifts. After the coding, I liked switching to Sport mode by sliding the gear lever to left, felt like it was somewhere between the Comfort mode and Sport mode(by hitting the Sport mode button). But as I mentioned earlier it did kinda act strangely in the beginning in lower gears.
01-02-2019, 05:38 AM | #244 |
Rep 64
01-02-2019, 12:59 PM | #245 |
Rep 962
01-02-2019, 02:05 PM | #246 | |
Rep 765
02-01-2019, 03:40 AM | #247 |
Rep 1
SAT coding w/ BimmerCode
Hi,
I coded SAT and Sport+ mode to my 2017 F30 318d (2.0 diesel) using BimmerCode app yesterday. Sport+ mode works fine but I have a few questions about the SAT maybe someone here has the answer to: 1. My car doesn't have the 2TB option from the factory, it has the 205 regular 8-speed automatic transmission. Regular shift knob (not the sport), no paddle shifters. I also checked the VIN to make sure and again, no 2TB, just 205 automatic. But, my car'd showed "S1, S2, S3, ..." before the SAT coding from the factory. Maybe all cars have it after a certain model year? 2. I don't feel much of a difference in shift speeds after the coding. I still see the same "S1, S2, ..." so no change there. So to make sure SAT was coded correctly, I checked if it upshifts automatically at redline in Sport+ and Manual mode, and yes it still does upshift. Anybody experienced this? Maybe because my car is a diesel? The BimmerCode app codes FDL, and for SAT coding, it codes EGS: sportschalter_alt = active sportschalter = active It said coding was completed successfully. No error messages. Any ideas? Maybe some cars don't support SAT? |
02-04-2019, 04:45 AM | #248 |
Rep 16
Does the sport transmission change the manual mode behaviour? I dont have paddles in my car but when I use the stick in manual mode I think there is a rather long delay after I have pushed lever forwards or backwards before the gear is actually changed. I am not sure should I activate sport auto or not.
02-05-2019, 06:42 PM | #249 | |||
Rep 376
However, now that you can code sport auto with BimmerCode, does that still hold true?
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
02-05-2019, 07:40 PM | #250 | ||||
Rep 479
chuckles01188.50 sspade2464.50 |
08-03-2019, 03:20 PM | #251 |
Rep 20
Hello guys,
Today i tried to enabled Sport + on my car, And Codes as following: Kombi => 300C ECO_FDS =>Function FDS_MENUE_TEXT_1=> menue_3 FDS_MENUE_SIGNAL_1=> menue_3 FDS_MENUE_TEXT_2=> menue_3 FDS_MENUE_SIGNAL_2=> menue_3 FDS_MENUE_TEXT_3=> menue_3 FDS_MENUE_SIGNAL_3=> menue_3 FDS_MENUE_TEXT_4=> menue_3 FDS_MENUE_SIGNAL_4=> menue_3 ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut EGS/3000 Applikation -> Sportschalter_alt -> aktiv EGS/3000 Applikation -> Sportschalter -> aktiv ICM/IcmKod_B_S2TBA -> verbaut Add 2TB option and delete 205 in salapa element, But didn’t working What i’m missing? My car is F30 LCI whitout paddle |
08-03-2019, 08:42 PM | #252 | |
Rep 8,364
Editing FA alone does nothing, you have to VO code car. |
08-03-2019, 11:48 PM | #253 |
Rep 20
08-04-2019, 12:11 AM | #254 |
Rep 8,364
08-04-2019, 12:38 AM | #255 |
Rep 20
08-05-2019, 11:06 PM | #257 |
Rep 8,364
08-18-2019, 02:34 PM | #258 | |
Rep 1
I also really need to get better shift-response on my 2018 F30 330e ! Can you please get in touch and let me know your experiance up until niw after your mod to 2TB sport automatic transmission. Is the gearbox / elektromotor drivetrain still working as it should ? Does the gearbox shift faster when downshifting and does it rev the engine up (throttle blip) for downshift ? Can you tell me what exactly you did to make this happen ? I was thinking on using the bimmercode-app to code this into the transmission-ecu. Does the dealership know you did this change ? Does it void warranty ? Hope to hear from you. Thanks in advance ! Hybrid-driver Europe |
08-25-2019, 02:30 AM | #259 |
Rep 56
08-25-2019, 03:26 AM | #260 | |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
It was never a option as far as I know. |
08-26-2019, 12:06 AM | #261 | |
Rep 8,364
HU is for the sport menus on IDrive. DSC may not be needed. To compare files to determine if any changes are made: 1. Read Coding Data 2. VO code or use E-sys coding Verification to generate files 3. Open each in FDL-Editor 4. Save as FWL 5. Compare with program of choice (eg, Beyond Compare) Hybrids get 2TE rather the 2TB. |
chr12.00 |
08-30-2019, 05:31 PM | #262 |
Rep 25
Hi,
Weird issue coding 2TB. I have a 2019 F20 118i with 205. I first of all FDL coded this: EGS/3000 Applikation -> Sportschalter_alt -> aktiv EGS/3000 Applikation -> Sportschalter -> aktiv I didn't really notice any difference at all. The car already has Sport+ and it already shows S1, S2, S3 etc when the gearbox is in manual mode and it already has the Sports Display on iDrive, so none of these methods can tell me if it's working. The driving feel is the same. So I tried to VO code it instead. I changed 205 to 2TB, then coded EGS, ICM, KOMBI as instructed. But then going into FEM_BODY to turn off the paddles, the paddles are already off because FEM_BODY isn't coded. But when I code FEM_BODY my 2TB reverts back to 205. I have triple checked that the 205 to 2TB change has correctly taken place by reading it from the ECU after writing it. It is definitely changed, but then when coding FEM it changes back. How can this happen and why is it happening? |
08-31-2019, 01:55 AM | #263 |
Rep 2,302
08-31-2019, 02:58 PM | #264 | |
Rep 25
Are you saying if I already had been in expert mode, coding, and had already read the FA before I changed to 2TB, that causes this problem? So I should change to 2TB, write FA FP, expert mode coding, then read, activate fa, code ecus. I'm pretty sure this is how I did it already anyway. |
