08-12-2016, 10:32 AM | #23 |
Rep 265
Sorry for the bump, but has anyone actually tried to do this with a base stereo (no amp)?
If so, please share your thoughts. I want to do this, but it is pretty scary to cut all the cables on the head unit. |
09-13-2016, 05:15 AM | #24 | ||
Rep 265
Don't understand how it should be connected. And what do they mean with 4-Turer and 2-Turer? Also, according to this, many of the connections are supposed to go to the AMP, which I don't have: Quote:
Also, last thing to figure out, are both KCAN2 wires connected to the existing HU_ENTRY? Can I route them to the ASD? |
09-13-2016, 11:24 AM | #25 | |
Rep 2,302
The F120 seems to be a write mistake by me. I think i meant F126 like in the circuit diagram. 4 Türer means 4 doors car and 2 Türer means 2 doors car - Tür=door. In this circuit diagram you can see the connections without an amp (Post No. 8 from me). http://f30.bimmerpost.com/forums/sho....php?t=1234349 The 2 KCAN2 wires are normally connected to the FEM Pin 10+11 at A173*10B. But they can taken from where you want. |
joq3105.00 |
01-13-2017, 01:27 AM | #26 | |
Rep 265
But when you check the diagram where it says 4 Türer, pinout 32+31 and 21+13 mentions 41+40 lower down the same diagram. Does this mean I should connect 41+40 to pin 32+31 and 21+13 or is this already connected as it is? About K_CAN2, I read somewhere that only newer F30 has Kcan2 and older (before 2013) has K_can1. Is this true? Mine is produced in 2012-7. You say I can connect K-CAN2 to FEM Pin 10+11 at A173*10B, which pin is K_CAN2_H and which is K_CAN2_L? By the way is it OK to just tap these wires with a simple POSI TAP? From what I understand the FEM box is located in the drivers footwell, and everything else I need is behind the Head Unit, except 12V and Ground. Ground I guess I can take from anywhere on the chassi? And you said earlier that 12V should be taken from F126 in the trunk. Is it possible to get this 12V anywhere in the front so I don't need to wire it to the front of the car? Which gauge of wire should I use for the different pins? Thank you, you have been very helpful! |
01-13-2017, 04:17 AM | #27 | |
Rep 2,302
Pin 31/31 have connector X8*1B and 21/13 have connector X9*1B. Connector X8*1B should be found in the B-pillar on the left side. Connector X9*1B should be found in the B-pillar on the right side. But there's no need to use these connectors. You can also connect the wires direct from ASD to speakers. Pin32->Pin1 middle speaker left and so on. About K_CAN2 i don't know when it was introduced. K-CAN2_H is Pin 10 K-CAN2_L is Pin 11 And yes you can tap these wires with a simple POSI TAP. Ground you can take from anywhere. 12V you can theoretically take from the Fuse box in the engine compartment. There are some free fuses connected with clamp 30B. The fuses 21-37 should be used with clamp 30B. If there is one free place you can take it. The gauge of wire you can see in the circuit diagram. Directly above the cable color is a small number (for example 0,75). This is the gauge of wire. |
joq3105.00 |
01-13-2017, 04:30 AM | #28 | |
Rep 265
If I search my VIN-number on realoem ASD is diplayed (but it was introduced after my car was built, 2012-7). I have found an ASD with this part no: 65129287265 http://www.realoem.com/bmw/enUS/partxref?q=65129287265 It says it is "Bilaterally exchangeable" with this one 65129289971. So from what I understand it will work? "Connector X8*1B should be found in the B-pillar on the left side. Connector X9*1B should be found in the B-pillar on the right side." About this part, can't I just take this from the rear of my head unit? 32 - Brown/white 31 - Red/white 21 - Brown/grey 13 - Red/grey So the KCAN2_H always use Yellow/red cables and KCAN2_L uses Yellow/brown, that way I know which is which? I will check the fuse box, do you mean if there is an empty space in the fuse box? I can attach a fuse and connect a cable to this? Great about the gauges, didn't notice that. Thank you once again, without your help I wouldn't even try this! |
01-13-2017, 04:57 PM | #29 |
Rep 2,302
OK, the question about K_CAN2 was already answered in the other thread.
I think all ASD are interchangeable. Connect the speakers directly with the ASD. And yes, you can take the wires from the rear of the HU. Again yes, if there is an empty space in the fuse box numbers 21-37 (ONLY this numbers) you can attach a fuse and connect a cable to this. |
01-16-2017, 12:49 AM | #30 | |
Rep 265
RAD_ON on the image you posten has a arrow pointing to the right X70*1V. Does this mean this wire can't be cut, but it should be tapped, so it runs to its original destination + runs to the ASD? I guess X70*1V is the original destination. I will check if there is any empty space in the fuse box. What Amp fuse should I purchase and put in? And is it easy to connect a wire to the fuse? Haven't did anything with fuseboxes before, so I don't know how it is built or how to connect a wire. Don't know if I asked this before, but I can take Ground from anywhere right? Like somewhere behind the glove box (where I will mount this ASD). Thanks again! |
01-16-2017, 10:49 AM | #31 | |
Rep 2,302
I think the arrow pointing means that there is another connection in another direction (like a crossroad). The fuse should be 10A. It is easy to connect a wire. But you still need one "double leaf spring contact" (0,5-1,0mm²) with the part number 61131378906. The fuse is above the fuse box and the wire has to be inserted from below in the plug. Therefore you have to lift up the fuse box. Under the fuse box is a passage into the interior room. Follow the other wires and you will see it. Ground you can take from anywhere. |
01-16-2017, 01:23 PM | #32 | |
Rep 265
Cant I use this? https://www.amazon.com/Bussmann-BP-H.../dp/B000GKEXK2 And add a 10A fuse? Heres my fuse box, there are a few places to add a fuse View post on imgur.com |
01-16-2017, 02:08 PM | #33 |
Rep 2,302
Now i understand.
Yes, this connection should not be cutted. You have to split this wire and branch this connection. This thing (Sorry, don't know the name for this) from amazon should work. But think of the different size of the fuses and like i said only use the fuse places 21-37! Nr. 30 and 35 are free at your fuse box. It's also possible that there are fuses in but not occupied. And also it is possible to branch a fuse with this thing from amazon. |
01-16-2017, 02:33 PM | #34 | |
Rep 265
Last thing i am not sure of is to flash the ASD when everything is connected. I have done some coding, but nothing like this, can you help me with a guide? Is Esys everything that is needed? Or do i need ISTA/Rheingold too? |
01-16-2017, 02:58 PM | #35 |
Rep 2,302
The above part of the fuse box is locked at the bottom part.
The latch mechanism has to be released like the cover on 2 or 4 places. I'm not sure if the ASD has to be flashed. I think it only has to be VO coded. Therefore the ASD must be visible in Esys. Then press "detect caf for swe" and select the CAFD according to your i-Step (or select the newest CAFD, at this point you cannot select anything wrong). After that select the ASD and hit the button "code". This will code the ASD for your car. It's always a good idea to have Esys + Rheingold. Esys for coding and Rheingold for delete errors. |
01-17-2017, 03:12 AM | #36 | |
Rep 265
I'm not at all sure as I have only followed guides (step by step) to do all my coding before. According to this: http://f30.bimmerpost.com/forums/sho....php?t=1102274 "After this I flashed the ASD module. I used a modified FA where I changed the production code typekey to 3C17 to ensure it is a production code that included ASD." I don't know if by "flash" he means the same thing as you do. Do you know if there is a more complete step by step guide explaining the things you said in more detail? Thank you! |
01-17-2017, 08:22 AM | #37 |
Rep 2,302
He means something different with "flash".
Flashing is updating with new software. At coding the software is retained and only values will be changed. I have never dared to update (flash) an ecu, so i can't tell you the way to do this. I'm not sure if it's needed to flash the ASD. At first i would try only to code the ASD to your car. But before you can code the ASD you have to inject a CAFD. Here is an instruction (replace the word "FEM_Body" with "ASD"): http://www.bmwesys.com/guides/How%20...into%20SVT.pdf And here is a good instruction how to VO code: http://www.bmwesys.com/guides/VO%20C...ep%20Guide.pdf If you VO code an ecu, all FDL codings will be lost. |
01-17-2017, 08:39 AM | #38 | |
Rep 265
Is the latest I-level always recommended? This is included in Esys and not a file which I provide right? The part I don't really understand is the VO coding guide. "Right click on SALAPA element and click the Edit option." How do I know what to edit here? Thank you again! EDIT: Do I loose all FDL Coding I have done? |
01-17-2017, 09:05 AM | #39 |
Rep 2,302
Other coding experts recommend the CAFD according to the actually I-Level of the car.
But like i said, at this point you can not select something wrong. All CAFDs should work at this selection. "Right click on SALAPA element and click the Edit option." For your project you don't need this step. You only need step 11 + 12. You only have to activate your VO, select the ASD ecu and hit the button "code". So the ASD will be coded to your car. Sorry for the confusion. If you hit the button "code" you only loose the FDL codings of the selected ecus. It's no problem at the ASD, because there are no FDL codings until now. |
01-17-2017, 09:09 AM | #40 | |
Rep 265
Now I understand, the first part didn't make any sense, sorry for being a total newbie. About this part from the original ASD retrofit: "After this I flashed the ASD module. I used a modified FA where I changed the production code typekey to 3C17 to ensure it is a production code that included ASD." What does he mean by code typekey to 3C17? Is this another way of doing it that I do not need to do? |
01-17-2017, 11:43 AM | #42 | |
Rep 2,302
I don't know if it's possible to downgrade. 3C17 is a typekey of the F30. It describes a specific F30-Model. http://www.bmwarchiv.de/e-code/f30.html I think you only need this if you get problems. |
joq3105.00 |
01-18-2017, 02:25 AM | #43 | |
Rep 265
As I loose all FDL coding, is it possible to backup all this, then do the VO coding and then load the backup? Or do I have to manually code everything again? |
01-18-2017, 07:54 AM | #44 | |
Rep 2,302
You can make a backup, but it doesn't matter, because the VO coding will overwrite all FDL codings. And if you then load your saved backup all changes will also be overwritten with the old values. But don't worry about that. You loose only the codings from the actually selected control unit. |
