01-29-2018, 11:41 AM | #45 |
Cheapskate
4450
Rep 4,993
You have to read the Dinan website yourself. You'll constantly read claims that Dinan is approved by BMW or BMW will warranty Dinan parts, but that's not the case. Dinan offers a warranty to cover the gaps that BMW will void if you install Dinan parts. No part of that transaction guarantees BMW will warranty anything on your car with Dinan parts on it.
That being said, Dinan operates just like BMW. If you have a failure, you have to prove that it was caused by the Dinan component. And 9 times out of 10, they will fall back on their low failure rates to say that something else was wrong with your car, they've sold 1000s of piggybacks without an issue, etc. |
01-29-2018, 12:09 PM | #46 | |
Rep 5,372
I would ask about the coolant levels because the intake manifold on the B58 is filled with coolant and these cars have a documented history of loosing coolant. Some are underfilled from the factory, but others we know were consuming coolant in some fashion, whether at the turbo or the motor itself. There have been reports of replaced turbos and one M240 owner just had his B58 motor replaced because of coolant consumption. A coolant leak in the intake manifold could: 1) Cause hydrolock the motor. This would be the result of a larger leak and would kill the motor immediately. This isn't what happened with your motor. 2) A smaller leak could create potentially cause a misfire and/or worse, wash the cylinder and wreck a piston ring(s). This could cause a misfire and due to reduced compression (leakage). Also on the 2 series forum, someone just had their VANOs system replaced on their M240 because of misfire issues. Like others noted, I have a hard time believing your mods were source of the problems. However, BMW does have a lot of lawyers and will usually point their finger at the modifications even if the cause of the failure is a known issue on stock cars.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
ceedawg467.50 |
01-29-2018, 12:10 PM | #47 | |
Rep 5,372
01-29-2018, 02:17 PM | #49 |
Cheapskate
4450
Rep 4,993
this, but only if the dealer will let you leave it there.
Option A: Swap downpipe/Remove piggyback and leave it at the dealer. If you can't do that Option B: Leave it at the dealer and let the field engineer look at it If they void the warranty Option C: Buy a motor online either from ebay, a junkyard, or a partout on the forums and take it to an indy shop to get it replaced. Or if you're feeling lucky, you could pay the dealer to diagnose the issue and then take it to an indy to have the specific component replaced. If it's just a bad bearing, VANOS, etc it may be worth replacing the component instead of the whole block. It all depends on price and your comfort with a shop tearing into a new motor. It can be kind of dicey because little to no shops have dug that deep or have experience tearing down our engines. if you say so. i have yet to see anyone use the warranty. |
eluded3041.50 |
01-29-2018, 03:24 PM | #50 |
Rep 1,127
any down pipe could easily be a piece of junk , clog up, hold in extra exhaust heat and start melting stuff in the engine. :-\
Happened on some of the earlier GM LSJ OEM catpipes when I was into that car. Last edited by zinner; 01-29-2018 at 07:23 PM.. |
01-29-2018, 03:51 PM | #51 | |
Rep 3,211
but he was also using meth .. dont know if that was a factor |
01-29-2018, 07:59 PM | #52 |
Rep 1,127
Should be pretty easy to pull it off and see the state of the cat matrix, I am sure the dealer will do just that diagnosising. Hopefully if it's fine they won't attribute it to the cause. I don't think meth injection would hurt the cat, it's usually metals in the fuel/oil like zinc or lead that do them in.
01-30-2018, 05:58 PM | #53 | |
Rep 1,454
Meth wasn't the direct cause, but by running meth, it allowed him to run more boost. More boost = higher temps, and it melted the cat.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 Last edited by G.Newt; 01-31-2018 at 06:20 PM.. |
01-31-2018, 07:55 AM | #54 | ||
Rep 413
340i M Sport Track Package | JB4 | Dinan Exhaust | BMS intake | CG catted 5" DP | HR sport springs | WMI | Zito Zf01 |
kern4174449.50 |
01-31-2018, 09:47 AM | #55 |
520
Rep 1,026
Drives: 2018 Shelby GT350
I'll chime in on this thread because it's filled with excessive misguided information, which is exactly why forums are never the place for appropriate answers but rather are filled with responses from those that are clearly one sided... The OP admittedly said he ran a non emissions legal downpipe(catted or not), to simply add insult to injury he ran a Dinan piggyback tuner which is the WRONG thing to do. The Dinan piggyback was engineered with the OEM catalytic converter in mind, Dinan products are generally speaking designed to optimize performance safely, so in essence what the OP did was counter intuitive. In short I am positive that by adding a catted DP w/ the Dinan piggyback threw off the AFR's/fuel trim because it's more than likely they were working against each other and not with each other. With that in mind it's more than likely that it threw off the firing order of the injectors and ultimately threw off the amount of fuel that combusts in the combustion chamber for cylinder #1(arguably flooding the combustion chamber with excessive fuel which could have compromised that cylinder).
The B58 is a uniquely designed engine, thus far I have not seen any go bad, IMO it's far more advanced compared to it's predecessors(ex: N54/N55). A lot of consumers have to revert back to the age old saying, "you have to pay to play" otherwise why modify your vehicle in hopes that when things go bad that the manufacturer is going to back you? I can personally speak for myself in the past where I've built engines and there have been a few times where the engines I built went south. Never was there a time it crossed my mind to take it to the dealer to have them do warranty repairs because I knowingly invested into my vehicles performance whether it was minor or major, it's irrelevant... We all see threads like this and it's just over flooded with toxic information, like most of you had said, all the OP could do is cross his fingers and hope for the best...
Instagram: cboy1
01-31-2018, 10:44 AM | #56 | |
Cheapskate
4450
Rep 4,993
1. A high flow cat will not affect AFR, only emissions. The o2 sensor reads AFR before the cat on a stock downpipe, so catted or not you will get a good reading in the stock location. If anything, the piggyback is what would put a strain on AFR and could cause the fuel system to struggle to keep up (read my previous post, that's my opinion). 2. The piggyback bumps up boost and the car should adjust appropriately. This isn't a subaru. You don't need a tune for every mod you do to keep the car in safe parameters. You can put upgrade intake/exhaust piping on the car without affecting the engine. 3. The fact that you think you can 100% say anything without even seeing the car is part of why I hate dealing with dealerships, and just increases the misguided information on the forum. If they take the engine apart and find a spun bearing, dropped valve, broken tensioner, etc. then it very likely could have nothing to do with the power mods. That's why a good mechanic properly diagnoses an issue before throwing parts at the car to try and fix it. |
01-31-2018, 10:49 AM | #57 |
Rep 2,639
Personally, most people complain about the smell of catless, Ive been running catless for about 2 years now and dont smell anything unless im behind the car, it actually doesnt even smell bad, I like the smell
I would say anything over 16psi, you should go catless as the cat will either melt or clog later on, might not be now, but later for sure.
01-31-2018, 10:52 AM | #58 | |
520
Rep 1,026
Have yourself a read my friend. I am positive what I was contributing was correct.
Instagram: cboy1
eluded3041.50 |
01-31-2018, 11:17 AM | #59 | |
Cheapskate
4450
Rep 4,993
If you think that you can't add a downpipe on your car without a specific tune, or that something was wrong because OP was in stock mode, then you don't fully understand how our car's engines and tuning works. Personally i think running our AFRs through the roof is why we are seeing scattered issues, like the melted catalytic converter that was mentioned a few posts back. That should not happen on a properly tuned car. But the downpipe is not what caused the failure. If anything, it would allow the car to breathe better and operate more efficiently. |
02-01-2018, 10:04 PM | #60 | |
Rep 32
kern4174449.50 |
02-04-2018, 08:57 AM | #61 |
Rep 462
A downpipe especially a catted downpipe will never make that much of a difference to afr ever, and to the point where the ecu can’t adjust the tiny change from the Downpipe this isn’t a ecu from the e90s and even Ecu’a from the 90s can account for the small changes
02-05-2018, 11:20 AM | #62 | |
Rep 1,348
2k15 335i Msport xdrive 6spd
B58togo808.50 |
02-05-2018, 11:21 AM | #63 | |
Rep 1,348
02-05-2018, 11:23 AM | #64 | |
Rep 1,348
02-05-2018, 12:19 PM | #65 |
Rep 703
lmao
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
340i, b58, engine |
