BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Wiring diagram window/mirror block f31
proTUNING Freaks
      05-01-2021, 12:32 PM   #1
VeErik
Drives: BMW 320i 2014
Dear all,
Probably a short question for some of you. Could anyone help me with the following?
I'm looking for the wire diagram for the button switches on the drivers side of a European F31, 2013.
See the attached photos from the button which I mean, and the connector behind it.
If some one has the wiring diagram + functions that would be great. (Or just what which color does)
Thanks
      05-01-2021, 01:35 PM   #2
atzebmw
Drives: Tesla Model 3
Here for you…
      05-01-2021, 01:51 PM   #3
VeErik
Originally Posted by atzebmw View Post
Here for you…
Thanks dude, this helps a lot.
Probably you could also tell me this about this diagram.
If in the diagram there are 2 color codes mentioned.
For example white/Brown and directly under this, blue/yellow.
Does that mean it could be any of these 2 depending on your model?
      05-01-2021, 01:58 PM   #4
VeErik
Here for you…
Sorry, another one. The cables for the windows are on the same connector am I right? Could you also add that one?
I'm actualy looking for the positive wire that dims the light in this "button block"
I was installing retrofitted interior door lights (not standard in Europe). And for the 3 other doors I could use an Y-cable and tap a positive and negative from this window switch.
When I dim the lights next to my light switches (which also dims the cluster lights) this dims all 3 other lights, except this one from the drivers door.
      05-01-2021, 01:59 PM   #5
atzebmw
This is for other built years where the cable colors have changed.
I think the lowest cable colors apply to your built year, because I see a purple and yellow/blue cable, but no white/brown cable.
      05-01-2021, 02:17 PM   #6
atzebmw
There is no other wire diagram and there is also no single wire for the lighting, as the other things on the switch block are controlled via LIN.
      05-01-2021, 02:21 PM   #7
VeErik
Hmmm, that's a pity.
I guess I have to wire it to the inside of the car somewhere. I saw a youtube of someone using the wires behind the hazard switch.
I hoped to not have to go through the wire loom through the door into the interior 😊.
Thanks for your help Atze. (Sounds german btw..are you?)
      05-01-2021, 02:29 PM   #8
atzebmw
Ja, ich bin Deutscher.
I'll send you a link to my Source of the wiring diagrams.
Maybe you will find some other wires there.
