BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > REM module failure
European Auto Source (EAS)
      08-10-2018, 08:26 AM   #1
airbug1009
Thailand
Drives: F30 330e M Sport
REM module failure
After parking my 330e for 4 days at home, I started my car and got a light system warning.
Below are the symptoms:
1. Trunk doesn't open by using remote fob or the button near the driver seat and I don't have the valet button in the glove compartment
2. Light on the trunk does not work at all but the brake lights on the side body are working
3. Turning light signal on the rear doesn't work. But when I press the emergency light, the signal light on the rear body lights do light up but the light section on the trunk still doesn't work
4. Reverse camera and PDC doesn't work at all
I took the car to BMW dealer and they said the system showed the REM is in sleeping mode and not functioning. For 8 hours, they are still unable to open the trunk to check the REM module.
The dealer told me they have never encounter this problem before. This is a real joke by BMW. Does anyone else had this issue before?
      08-10-2018, 11:34 AM   #2
cfm56d7b
Very unusual problem, including spending 8 hours and not being able to open the trunk. What about lowering the rear seat (or even removing) and opening the the trunk from the inside?
      08-10-2018, 09:59 PM   #3
airbug1009
Thailand
I told them to lower the rear seats, which they did, but my car is not equipped with trunk release so they are still trying to figure out how to open the trunk so they can work more easily and check the problem with the REM module.
      08-10-2018, 10:43 PM   #4
cfm56d7b
Hmm ... could the trunk release mechanism be disassembled from the inside? Again - one of the most unusual repair challenges.
      08-10-2018, 11:11 PM   #5
airbug1009
Thailand
As you said, after 8 hours, they told me that they are still trying to figure out how to open the trunk. Which doesn't sound assuring at all. I'm a loyal bmw guy and trust the brand and all their work put into their cars but this is unacceptable. I hope they don't pop the trunk open like a soda can.
      08-24-2018, 07:57 AM   #6
airbug1009
Thailand
The dealer managed to open the trunk to investigate the problem. At the end, they determined to be a faulty REM module and it was replaced within a day. The programming took half a day. So the problem was resolved. However, I hated that every time a programming is involved, it will wipe out my driver profile seat position memories.
      08-24-2018, 09:52 PM   #7
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Programming the REM shouldn't affect the seats, as they're not controlled by the REM. The only devices controlled by the Rear Electronic Module are in the rear of the car.
      10-14-2019, 09:27 AM   #8
Staffy233544
Drives: BMW F30 330D M Sport
Hey
Did you get this sorted? I know have the same issue, loose rear lights, indicators, heated seats and rear window operation..... very strange and im keen to get this resolved
      10-14-2019, 10:59 PM   #9
vsasesse
Drives: 2014 335i xDrive 6speed
Hello I have had this happen to my 14 335xi. My dealer did a reset and it's been fine. I did a thread on the a while back... I'll take a look.
      10-14-2019, 11:01 PM   #10
vsasesse
https://f30.bimmerpost.com/forums/sh...light=Vsasesse
      10-15-2019, 08:58 AM   #11
Polo08816
Drives: 2014 335i M Sport
How did they end up opening the trunk?
      10-15-2019, 12:26 PM   #12
Billfitz
Billfitz's Avatar
Probably by removing the rear seat, then climbing into the trunk to pull the emergency release.
