BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED**
proTUNING Freaks
      03-27-2018, 06:58 PM   #265
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
Originally Posted by raichean View Post
*laugh* No pressure.. I want/need logs, want to run video, you name it. I had something come up that same afternoon that I cannot miss, so I am trying to get a morning dyno slot rather than the afternoon.
side note, with my gauges now at 480/480, I hit it BRIEFLY and quickly coming out of my neighborhood and easily saw the needle hit 370ish.. *grin*
      03-29-2018, 01:56 AM   #266
Quiet_Riot
No Longer on Here
Quiet_Riot's Avatar
Drives: Mercedes C63S
Do they have an obd flash tune for the 435d x? Thanks
      03-29-2018, 06:04 PM   #267
mike@x-ph.com
They offer bench flash for 435D , no OBD flash yet
Quiet_Riot5547.00
      04-01-2018, 12:19 AM   #268
BMW DIY Guy
Drives: 2014 435i
2014 BMW 435i  [0.00]
Here you go guys.. my summary analysis is up from my 3/31 dyno run:
http://f30.bimmerpost.com/forums/sho...0&postcount=70
Check out my BMW DIY Channel on YouTube! F32, F80, E39, E46, E53, and E83 projects from Active Autowerke, TuningTechFS, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** ** Facebook BMW DIY Guy **
'Furiosa' F32 Build Thread
Seba77W291.50
      05-05-2018, 05:45 PM   #269
Masterongear
Drives: 15 M235i Black Saph Metalic
Got my dyno completed but my 1:1 6th gear ran out their dyno max speed so whp came in low at 320whp at 5krpms but my wheel torque was at 462 at 4200rpm. Comparing torque pro performance and perfexpert they all state at or above the same torque but I get a range of 400-480whp using torque pro and perfexpert apps. I'm trying to set an appointment up near me for a dynojet session and will post when I can get a proper euro car tuner who knows how to dyno with the zf8. I'm now running a JB4 with the AA stage2+ at 22-25psi. The JB4 helps a lot with keeping fuel pressure and AFR and timing in check. Using map 1 and map 5, tried map 2 and almost misfired with 95 octane so I'll be saving that map for 100 octane or higher. The JB4 has actually smoothed out the powerband on the custom flash.
      05-05-2018, 10:24 PM   #270
ceedawg
ceedawg's Avatar
436
Drives: 2k15 335i xdrive MSport 6spd
22 to 25 psi,stock fuel pump? How?
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, ACS springs. FBO BM3 Stg 2
      05-07-2018, 06:14 PM   #271
ceedawg
ceedawg's Avatar
436
AA tuned M2 with their new Catted DP
http://f87.bimmerpost.com/forums/sho...8#post23160588
      05-10-2018, 12:05 PM   #272
ceedawg
ceedawg's Avatar
436
Hey guys vote in this pol if you have the AA tune Select "other" then post your tune
http://f87.bimmerpost.com/forums/sho...7#post23173797
