BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 403M to VMR's - Simple swap?
      05-24-2018, 10:00 AM   #1
johnnybforbacon
johnnybforbacon's Avatar
Drives: F20 M135i
Hey guys (and girls)
I've recently noticed my wheels start to corrode on my 403M's 19" and after doing a quick search found this to be quite a common problem. I have contacted BMW and have a date to pop down and get some photos done and hope to get it sorted through warranty (12 month used car warranty).
I've never really taken to the wheels though and after doing a bit of research found the VMR V710's which I absolutely love. I contacted the EU store and been suggested to order two 8.5 x 19 and two 9.5 x 19. (Is this the wheel width? I've no idea?!)
My tyres have only recently been changed so I've got the Bridgestone Potenza's 225 40R 19 BY and 255 35R 19 YB fitted.
Is this simply a straight swap? Is anything else needed other than taking the new wheels to the tyre shop and getting them swapped over?
Just want to make sure before I start ordering....
(tyre size edited)
      05-24-2018, 10:41 AM   #2
azuritschwarz
azuritschwarz's Avatar
Drives: 2017 440i 6MT with MPPSK
2006 BMW 330i  [0.00]
2017 BMW 440i Coupe  [0.00]
2007 BMW 335i  [0.00]
yes, the 8.5" & 9.5" are the width of the rim. I'm pretty sure your fronts will be fine, but I don't know if the 225 for the back will fit around a 9.5" rim without being stretched too badly.
is your car xDrive? if so, you need to take into account the rolling diameter of the wheels; there cannot be more than a 1% diameter discrepancy from front to back.
2016 F80 M3 6MT Azurite Black over Sakhir Orange Full Leather
2007 E90 335i 6MT Black Sapphire Metallic over Terra Brown Leather
2017 F32 440i xDrive 6MT Alpine White over Coral Red Leather (SOLD)
2006 E90 330i 6MT Arctic Metallic over Ivory White Leather (SOLD)
      05-24-2018, 11:21 AM   #3
MacklinUSOB
Drives: f30 328i 6MT Sport
My tyres have only recently been changed so I've got the Bridgestone Potenza's 225 40R 19 BY and 225 35R 19 YB fitted.
It's such a shame because the 403's are good looking wheels. For reference wheel sizes are always listed as this Diameter x Width, with et being offset.
If you just purchased a square set of tires and intend to keep a square stance (which I personally reccomend) you should get four identical sized wheels. Stock size is 8 inches, 8.5 can work with 225 section tires (although I'm confused why you have 40R and 35R tires ???) and will allow you to fit on larger tires in the future. What is important is the offset, width is the easy one. I believe VMR designates 8.5 et35 as their "direct fit" F30 size.
Add 5 horsepower for every M logo
328i RWD | CRed on MW | 6MT | BM3 STG 1 | MPE | GPlus FMIC | Millway Camber Plates & Monoballs | KW V2 | F80 LCA/TS | APEX SM-10 | R-S4 | Hawk HP+ | RBF600 | SS Lines |
Past: E36 328is & E38 740i
      05-24-2018, 11:23 AM   #4
johnnybforbacon
Drives: F20 M135i
I think they've done a typo in their reply to me. I was thinking the 9.5 would be too much.
Yes it is xDrive. I'm guessing it should be 8.5 x 19 all round then?
      05-24-2018, 11:31 AM   #5
azuritschwarz
xDrive is confusing to buy things for, you're not alone haha I've been there done that.
the WIDTH of the tire (8.5", 9.5") is essentially irrelevant to the xDrive system, all you need to worry about there is whether they will rub the inside of your fenders when turning.
the DIAMETER of the tire (225) is where it matters. try this link: https://tiresize.com/comparison/
if you put your front sizes in slot 1, then rears in slot 2, it'll tell you the rolling diameter difference from front to back. this is the number that matters as it must be less than 1%.
it is much easier to run a square setup (same size on all 4 corners), but if you're more of a spirited driver like myself, you may wanna put the extra time & money into getting a staggered setup. I did, & I have no regrets!
Good Luck!!
ps: for reference my setup is 20x9 235/35/20 on the front, & 20x10 275/30/20 on the rear. the rolling diameter difference on this setup is exactly 0%
      05-24-2018, 11:36 AM   #6
johnnybforbacon
Drives: F20 M135i
Good Luck!!
I've just really confused myself I think between all the communication with wheels/tire companies and looking on forums.
I've just pulled the car out and checked the tires, to make extra extra sure because I actually measured the widths and the backs were definitely wider...
The actual sizes are:
Front - 225/40R19 89Y
Rear - 255/35R19 92Y
Does this sound right for an xDrive?
Sorry for all the confusion!
      05-24-2018, 11:37 AM   #7
MacklinUSOB
In the interest of clearing up typos, in your original post you said:
"My tyres have only recently been changed so I've got the Bridgestone Potenza's 225 40R 19 BY and 225 35R 19 YB fitted."
Just to let you know, this is not a safe combination for xDrive vehicles and can damage your transfer cases. BMW says not to deviate more than 1% in diameter between axles/tires, the 35's are 3.4% smaller in diameter.
Are the tire sizes you listed accurate?
EDIT: Saw the post above, 255/35 is the OE spec and only .4% smaller in diameter than the 225/40. Perfectly safe.
      05-24-2018, 11:39 AM   #8
azuritschwarz
yes those sizes are correct, they're exactly what came on my 440i.
& no worries, xDrive is nit picky & these are expensive cars, it's always best to take your time & ask any questions you have so you don't mess up & regret it all later!
cheers!
      05-24-2018, 11:44 AM   #9
johnnybforbacon
Drives: F20 M135i
cheers!
Thanks for all the help guys and apologies for the confusion.
      05-24-2018, 12:44 PM   #10
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
I think your original post had a typo as well. It's most likely 225/40/19 fronts and 255/35/19 rears to match OEM sizing. In which case those new wheel sizes would work. It would be better to go wider with tires down the road.
Instagram @kern417
403m, f31, v710, vmr, wheels
