BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > TTFS XDI-35 HPFP Upgrade + PS2 Turbo Build/Result Thread! 500+ whp
proTUNING Freaks
      02-02-2019, 07:04 AM   #89
Raymondo1234
Raymondo1234's Avatar
Drives: 2016 M235xi
Originally Posted by SeanWRT View Post
@Raymondo1234 I've seen and done many enough to know N55.
PS2+meth takes F20/22 to high 6s to 7s. Nothing else needed. I have a local Copenhagen buddy (M135i) does that just at 22psi. That car is incredible fast because it's lighter than many think.
Tuned a stock turbo FBO + meth M2, 430whp, 20psi taper to 18, high 8s in 100-200. This is our 'abuse car' we used to find M2 stock turbo limit.
Did one PS2 M2 on pump gas, STG2 OTS 400whp. Turn on meth and use Jb4 running 20psi, a high 7s car. Didn't dyno that setup, I'm sure it'd show 470+.
And countless middle 7s S55 car with just a BM3 OTS and 9.5s FBO M2 flashed.
My experience is that when you have octane limit, easy way is either to have ethanol (which require bigger pump or PI) or to install meth. But meth is much more effective because it's cooling IAT and supporting fueling as well.
From the bottom of my heart, I wish pump upgrade improves power on pump gas. I'd pay double, triple money XDI/TTFS ask. I even tell Halim that I want to burn 2k just to give a try, knowing it's not helpful in my case. He advised against my proposal.
Man this is commercial and someone has a dog in this business. I'm a car enthusiast and I speak with what I know. That's all.
I've seen your posts, I know you don't want to hear the pump works.
You are entitled to your opinion, and you obviously have a lot of experience, but it also seems your experience is making you put your head in the sand, and not willing to except some of the results people are getting on 93 with this pump.
Again, I appreciate your opinion, I too have many years modifying and tuning (albeit on a very amateur level and nothing like some of the geniuses can do) but I'm also very open minded.
If I see hard facts something is working, even if it's against my thought process, and my initial thoughts are it's bs, I am humble enough to accept I maybe wrong.
Good luck with your future efforts, and we will just agree to differ.
SeanWRT3179.00
ronanz1819.50
ceedawg467.50
      02-02-2019, 07:24 AM   #90
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
@Raymondo1234 you could be right except that I really wish pump works with pump gas, so that my personal car can improve. Good luck man, let's see.
Lemania 2320
      02-02-2019, 08:29 AM   #91
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
@seanWRT, so your saying the XDI upgraded fuel pump won't allow you to run pump gas??!??
According to OP he's hitting and holding 20-21psi with the just the upgraded HPFP!
I recently upgraded to PS2 and using MHD for my tuning with stock fueling. Tried to use the OTS map for PS2 but my stock HPFP kept dropping rail pressure due to the ethanol content in my area for 93 octane. After some map revisions my car runs much quicker and the rail pressure doesn't fall on its face, although it's a sacrifice in boost curve which really sucks!! But like OP, I also don't want to run meth or ethanol blends so once price drops for the XDI HPFP I'll be grabbing one and turning up the boost!!
      02-02-2019, 09:05 AM   #92
Marlinman
Drives: 2013 335i xDrive
Munchi, I know this sounds stupid, but I run the BEF right now and I'm curious about trying the MHD OTS map for the PS2. Is it located in the app because I can't find it for the life of me. Is it separate in the app store? When the OTS map didn't work for you, did you have someone customize it down a little? I'm running 15PSI right now and HPFP seems happy. I think market price and comp will drive the price down in the next few months. Just have to wait.
ceedawg467.50
      02-02-2019, 12:44 PM   #93
Munchi435i
Munchi435i's Avatar
I don't think the OTS map is available for BEF but I'm not sure and yes it's located in the app. Also, are PWG or EWG? Yes the map was revised by pureboost, they do all the OTS maps for MHD. The PS2 OTS map targets about 17psi but mine is dialed down to 15psi and now adding more timing to squeeze some more boost but might run a little leaner. Still testing maps to optimize my fueling and stock hpfp.
      02-02-2019, 03:03 PM   #94
Marlinman
Okay thanks Munchi. Nope I know I'd have to go full flash. I'll look for it. I'm PWG
      02-02-2019, 05:41 PM   #95
Munchi435i
Munchi435i's Avatar
Yeah Im guessing you'd have to go full flash to be able to use the PS2 OTS maps but it's only available for EWG vehicles.
Might want to send them a email to confirm they have a PWG OTS map for PS2 before purchasing
      02-03-2019, 06:33 AM   #96
ceedawg
ceedawg's Avatar
468
Drives: 2k15 335i xdrive MSport 6spd
1000%
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2
      02-03-2019, 09:41 PM   #97
Raymondo1234
Drives: 2016 M235xi
      02-03-2019, 10:23 PM   #98
theEZV
Russia
178
Drives: F30 335i; Looking for F80
Raymondo1234 Dang man can I come ride along for some pulls?
      02-03-2019, 11:17 PM   #99
SeanWRT
SeanWRT's Avatar
3179
Originally Posted by Raymondo1234 View Post
Raymondo, though these are not dynojet results, the number are legit with E30 based on the log. Congrats.
Lemania 2320
      02-04-2019, 10:42 AM   #100
harkes
harkes's Avatar
China
1076
Drives: M135i, E39 M5, NSX and AE86
Raymondo1234
Forgive me, just trying to learn here...
It looks to me that load req is set at a level that cannot be achieved unless overboost is presented. Why is that? I have been looking at a few OTS logs also - same thing.
The stock map (sort of) meet target - so is this not what we would want from a good tune?
SeanWRT pureboost
(A Dane in China)
      02-04-2019, 11:50 AM   #101
SeanWRT
SeanWRT's Avatar
3179
Originally Posted by harkes View Post
Raymondo1234
SeanWRT pureboost
Raymondo log is just one more example of the tuning approach I explained to you last week.
No such thing as definitive good or bad. There're tradeoffs, I thought I explained crystal clear...
Lemania 2320
      02-04-2019, 06:24 PM   #102
harkes
harkes's Avatar
China
1076
Yes, you explained your side of it. Setting load request to what ever and then use a boost ceiling instead of proper load control (the way I understand it). But with this log/tune neither load nor boost target is met. Not to the same degree as on the stock map anyway...?
Sorry Raymondo - I'll open another post around this subject.
(A Dane in China)
      02-04-2019, 08:14 PM   #103
SeanWRT
SeanWRT's Avatar
3179
I have no side of it, my approach is different. My map manipulates load with actual boost control, rather than brutally capping it.
Just to avoid more confusion - This is MHD channels you're seeing with Raymondo log, at least so it appears. It uses different terminologies than BM3. Namely, the load req in MHD means differently than in BM3. BM3 has a different name for the same thing.
The log of Raymondo is fundamentally the same as yours, just a more polished one. That EWG is much easier to get run right than PWG is why.
I have maps like yours and Raymondo's and they worked more than just fine. But at the boost level (18+ across) I want my car run, I'd fine tune the boost/load rather than use a cap to make target flat across. The latest logs I sent you, the boost curve is otherworldly smooth and ignition always extremely clean for pump gas. So much time spent.
Meeting the boost target or not is a matter of pre and post boost control. It's a lower level and a more direct parameter to control. Intentional overshoot (post throttle, not pre boost) actually requires more skill. Underboost is safe and easy.
Let's stop from here. For a topic like this, you'd better PM specific persons than open a new thread.
Lemania 2320
      02-08-2019, 01:32 PM   #104
BMW DIY Guy
BMW DIY Guy's Avatar
Drives: 2019 M2 Competition
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Originally Posted by JaredG_F30 View Post
This is very exciting. 500+ whp with FBO + PS2 + XDI-35 on a 50/50 mix sounds like a really clean way to get some serious reliable power out of the N55.
So who is going to be the first to create a DIY installation video? I've looked at the diagram at realoem and at the replacement procedure at newtis.info but still have a few questions about this installation.
My hope is to do a full DIY on this, and I hope soon.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy **
'Nimona' G87 M2 Build Thread
'Lillith' F87 M2 Competition Build Thread
ronanz1819.50
      02-08-2019, 01:47 PM   #105
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
Awesome man looking forward to it.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
      06-11-2019, 05:27 PM   #106
13blk335ix
13blk335ix's Avatar
Drives: 2013 BMW F30 N55 335ix 6mt
2013 BMW 335ix  [0.00]
im ordering an xdi hpfp for my 13 335ix. super pumped. they are very helpful and friendly.
that is why they got the sale the same day
      06-12-2019, 08:03 PM   #107
Marlinman
pump should be pretty explanatory, however there is a nice video showing intake manifold removal by kies motorsports. This should get most of us 95% of the way.
      06-15-2019, 10:18 AM   #108
13blk335ix
13blk335ix's Avatar
what ignition coils are you running on these builds?
      06-17-2019, 01:52 PM   #109
DreamerJoe
Drives: 2017 340i M.G. w red interior
the OTS PS2 map is still only for EWG right now, not PWG. at least it wasn't a month ago when I last flashed
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
      06-17-2019, 02:31 PM   #110
JaredG_F30
JaredG_F30's Avatar
1106
I thought PWG had the 2H maps first.
