BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Is it possible to clear check engine codes with Esys / an ENET cable?
      06-30-2016, 12:56 PM   #265
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by TURBO4DR View Post
Hey Shawn if you don't mind can you send me link for Tool32 as well for clearing codes.
PM sent.
      07-07-2016, 01:34 AM   #266
wildjeff
Drives: 2016 340i
Can i get the link too? I don't have any codes to clear but I'm interested none the less.
Thanks
      07-07-2016, 02:57 AM   #267
shawnsheridan
Thanks
PM sent.
      07-07-2016, 05:20 PM   #268
Davey78
Drives: 2014 328i
Shawn can you PM me the link also? Thanks!
      07-07-2016, 05:24 PM   #269
shawnsheridan
PM sent.
      07-15-2016, 06:03 PM   #270
Davey78
Drives: 2014 328i
CEL
Can someone read this results file (or point me in the right direction so I can read it myself) from Tool32 and tell me what the CEL is on for?
I had to remove the 2TB a few weeks ago so the dealership could update my car for a AC freezing issue. The update went fine and removed all of the other coding, but now my CEL is coming on. I used esys to remove it about a week ago, but it came back the same day.
I just don't want to recode it if I have to take it back to the dealership so soon.
Thanks!!!!
      08-06-2016, 12:49 AM   #271
polra
Drives: i3 Rex
Just bought a used vehicle this week and need to clear the CEL - would greatly appreciate a link to Tool32 Shawn.
Cheers!
      08-06-2016, 03:57 PM   #272
shawnsheridan
Cheers!
PM sent.
      08-13-2016, 07:20 PM   #273
stroker15
Drives: 2013 328I Sportline
Hi can I get the link to tool32. I cleared my cel with esys but it came back on. I want to find out what the problem is. Thanks.
      08-13-2016, 07:22 PM   #274
shawnsheridan
You cannot send or receive PM's yet. Send me one when you can.
      08-13-2016, 07:39 PM   #275
stroker15
Ahh thanks. SHAWN. is there a way to use esys to read the code and figure out what the problem is? I followed your instructions to clear it using external apps and transmit. I see theres an option to read codes but don't understand what comes up when I connect and send.
      08-13-2016, 07:40 PM   #276
shawnsheridan
No. If you want meaningful diagnosis in English, you need ISTA/D (Rheingold).
      08-13-2016, 07:43 PM   #277
stroker15
Ok I think I seen a torrent for that. Thanks.
      08-15-2016, 09:43 AM   #278
Jayphotoworks
Drives: 2014 F30 Xdrive
FWIW, I got ISTA/D (BMW NEXT ISTA/D 3.48.20 + ISTA/P 55.0.300).. what a huge difference and I recommend most people jump right to ISTA if they are troubleshooting, it not only gave me the fault codes in a nice tree diagram for each ecu, but it took me right into the problem, calculated a test plan with linked trouble shooting images and wiring schematics. Traced it back to a loose harness and blown fuse a few minutes later. The tests are all labelled in english and you can toggle indicator lights, switches, read off sensor values real-time, etc. After software like e-sys and tool32, I didn't expect BMW had something almost apple-like to use
Only thing is the installation takes over an hour with over 20+ steps, but it was definitely worth it.
      08-17-2016, 07:33 AM   #279
Blacktan
Blacktan's Avatar
Greece
38
Drives: BMW f32 428i mpack
Hello Shawn
It will be much appreciated if you send me tool32 for clearing codes.
Thanks
Haris
      08-17-2016, 04:32 PM   #280
shawnsheridan
Originally Posted by Blacktan View Post
Hello Shawn
Thanks
Haris
PM sent.
      08-18-2016, 08:09 AM   #281
CyclingBroStyle
CyclingBroStyle's Avatar
Drives: '19 330i xDrive M Sport
Hello Shawn
Thanks
Haris
PM sent.
So I did a big no no lol last night when coding I accidentally clicked "code" on the entire ECU tree let's just say 3min later (1 fault and 7 CEL messages stability, ABS, Fuel you name it )I was in a total panic. I didn't change anything in the VO but the engine was running and I corrupted my DME ... Fast forward 30 min (3 quarts of sweat, tears, and pulled hair) I'm frantically messaging Shawnsheridan, I reloaded the DME the errors went away and the car is back to normal! My 2 things I want to say.
1. Shawn I owe you
2. Any idea if I messed up any thing else or re wrote something I wasn't ?
Current: MY2019 330i xDrive M-Sport w/Lasers - Portimao Blue
Previous: MY2013 328i xDrive Sport Line - Sapphire Black | MY2016 428i xDrive M-Sport - Mineral Grey
BMW CCA #522637 use me as a referral for BMW CCA
      08-24-2016, 10:20 AM   #282
stroker15
update on check engine light.
Just a quick update. I couldn't figure out how to get ISTA/D so I went to Auto Zone and they read the code for me for free. Only took a couple minutes.
Turns out it was the thermostat that failed, and I know there's another thread for that common issue. Went to BMW they scanned my key and told me there is no recall or service bulletin for the thermostat, but they replaced it under my extended warranty. My gas mileage has improved and the car runs better now.
Good thing I had it checked because my temp gauge was showing normal temp, but the thermostat was sending a false signal, who knows what temp the engine was really running at. I gained about 5 to 8 mpg after having the thermostat replaced.
      08-24-2016, 11:05 AM   #283
shawnsheridan
Car is fine now. Back to normal. No concern.
      08-25-2016, 07:02 PM   #284
CyclingBroStyle
Thanks boss
      09-01-2016, 03:05 PM   #285
pgwave
Drives: BMW 320d 2016
Hi Shawn,
Could you pm me the EDIABAS / E-Sys / Tool32?
I would like to know which program is better to correct the airbag, ABS and so one error after the accident - ISTA/D (Rheingold) or IMPA?
Which version is best for F31 2016 rheingold 3.52.32 or 3.42.10
Thanks a lot
      09-01-2016, 03:16 PM   #286
shawnsheridan
Originally Posted by pgwave View Post
Hi Shawn,
Thanks a lot
