10-17-2019, 10:50 PM | #705 |
Rep 1,407
Drives: 13' F30 328i 6MT
Hey Guys,
Just placed my order and see alot of people coming from the 6.5 side state they coded via bimmercode to 8.8 to improve the display.. Does anyone know how I can confirm this is possible? I have the 6.5" screen with Harmon Kardon Audio, There is no Combox and on the head unit it reads "Model : L7 ENTRY" can I code my Idrive to the 8.8 config so I have the nicer full display while on the Idrive side of things? Or am I stuck at 6.5 ? Thanks in advance....
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] |
10-17-2019, 11:03 PM | #706 |
Rep 399
8.8" is one of the sizes you can choose from:
model id = "1" client ="ALL" tips ="1">[01]NBT_F48/F49(6.5″,HalfScreen) model id = "7" client ="ALL" tips ="1">[02]NBT_F48/F49(6.5″,FullScreen) model id = "9" client ="ALL" tips ="1">[03]NBT_F48(8.8″,10.25″) model id = "4" client ="ALL" tips ="1">[04]CIC_E60(2012)/E83(6.5,HalfScreen) model id = "5" client ="ALL" tips ="1">[05]CIC_E60(2012)/E83(6.5,FullScreen) model id = "11" client ="ALL" tips ="1">[06]CIC_E60(2011)(6.5,HalfScreen) model id = "12" client ="ALL" tips ="1">[07]CIC_E60(2011)(6.5,FullScreen) model id = "6" client ="ALL" tips ="1">[08]CIC_X5(2009)/E60(2011)(8.8″,10.25″) model id = "8" client ="ALL" tips ="1">[09]CIC_7Series(2011)(8.8″,10.25″) model id = "2" client ="ALL" tips ="1">[10]CCC_E60(6.5″,FullScreen) model id = "3" client ="ALL" tips ="1">[11]CCC_E60(8.8″,FullScreen) model id = "14" client ="ALL" tips ="1">[12]CCC_E60(2010)(8.8″,FullScreen) model id = "18" client ="ALL" tips ="1">[13]CCC_E60(2008)(6.5″,FullScreen) model id = "13" client ="ALL" tips ="1">[14]18_EVO(6.5,HalfScreen) model id = "19" client ="ALL" tips ="1">[15]18_EVO(6.5,FullScreen) model id = "20" client ="ALL" tips ="1">[16]18_EVO(8.8) model id = "21" client ="ALL" tips ="1">[17]18_EVO_X1(8.8,1280x480) model id = "22" client ="ALL" tips ="1">[18]19_EVO_X3(10.25, 1440x540) |
10-17-2019, 11:03 PM | #707 | |
Rep 1,048
When you have Tel already set to Android but it still does open the HU`s Phone part, you have two possibilities. * Either your MCU/Android version have an inconsistence where the setting is working the wrong way, try to set it to "orignal" and test if android is opening. * or your MCU is one where the switching does not work at all, you need to update it, -> ask your vendor for a new file. i had already both issue`s. To the DAB / Music app function, it would be cool if it would be possible to have an selection between "original" function and own app, like it is with the MAP software. Just for fun, i already made an bugs/feature list if i will get in contact with an engineer of the original software somehow. Here is the list Code:
Tiles: * Music -> Option to change Music app default / other * File Manager -> Option to change Filemanager app default / other * Phone -> Option to change Phone app, default / other like Carkit,... * DVR -> rename / Selectable / free changeable for user, for example DAB+, * possibility of re-arrangement of the tiles Android: * free Bluetooth to Android, not only BMW Gui -> Possibility to add normal BT devices * Possibility to disable Bluetooth when not used(can cause interferences with BMW OEM BT) * Option to change Android Bootlogo (the screen before the Bootanimation) * Reboot option at Settings like at PX6 with Android 8.1 * Idrive Support at Apple Carplay like it was on PX6 with Android 8.1 MCU: * Bugfix Voicekey - not changeable * Bugfix Mode Key - no function * Bugfix beltwarning is always red at Dashboard app * Feature: selectable uptime after ignition off (1,3,5,10,15 min) * Feature: Option to select reverse parking sensor display between OEM and Android Last edited by Kri; 10-18-2019 at 12:42 AM.. |
DarkIrata9.00 |
10-17-2019, 11:19 PM | #708 | |
Rep 1,407
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] Last edited by QUiKSR20; 10-17-2019 at 11:24 PM.. |
10-18-2019, 01:26 AM | #709 |
Rep 51
in theory it would be enough to select a 6.5" setting. It will fill out the empty space with a simple display at the right side so it want be streched. At least my does that.
10-18-2019, 02:33 AM | #710 | |
Rep 29
Thank you so muck for this link !!! I also found the Intent to catch the steering wheel controls. I'll post it later. Now I can build a service application to control the dimming |
10-18-2019, 03:16 AM | #711 |
Rep 67
Can you share your final .apk for dimming? Mine is too bright sometimes and blends me, would be very great
10-18-2019, 03:36 AM | #712 |
Rep 280
Since we are discussing development, I could use some input (quite literally )
I wrote a small App that just starts as a foreground service and listens to incoming broadcasts. It checks which broadcast and content (the Integer) was received and translates it to proper KeyEvent values. E.g. KEYCODE_ENTER = 66. I am currently trying to figure out how to communicate that to the system, i.e. make the actual input. If you interact with your own view (say you make your own launcher) then it's fine. But if you want to interfere with other apps, it gets complicated. In general you need to be rooted. This is the simplest method: Code:
shell# input keyevent <code> A better function is hidden in the Android Hardware API. The class is 'InputManager' and the method 'injectInputEvent'. However, this requires the permission 'android.permission.INJECT_EVENTS' which is only granted to system apps. As far as I know, to make a system app it needs to be signed with the same signature/key as the OS (which we don't have). Is there any way around that? I tried to call the method using Xposed, but official development apparently stopped and now there is EdXposed, which has zero guides on how to develop. I couldn't get it to work yesterday, I will try again over the weekend. Bear in mind, I still don't have my unit and am developing on my phone at home. Any other methods I might have missed? |
10-18-2019, 03:42 AM | #713 |
Rep 55
Folks, I'm still going with my audio distortion problem.
Coika have now admitted that they know about this problem and they are manufacturing an "audio filter box" which will completely cure the problem. They can send this to me in a couple of weeks foc. Alternatively, they have offered me this intel based unit as a replacement which apparently doesn't have the problem, if I prefer. I've not seen any discussion on the intel devices here. What to do!? https://www.aliexpress.com/item/4000144842180.html |
10-18-2019, 04:30 AM | #714 | ||
Rep 29
I'm planning the use the steering wheel scroll wheel button (don't know if the term is right...) to adjust the brightness. When you'll start the car it will set the dimming to a stored value, lets say 50% then you will be able to adjust it with the scrool wheel button. It could also be done with a slider. But you would have to open the app and move the slider. Quote:
For my part I've used Automate to simulate gestures (swipe between screens). |
10-18-2019, 07:14 AM | #715 |
Rep 237
do you have a full list of integer sent by idrive intent in android?
10-18-2019, 07:20 AM | #716 | |
Rep 44
10-18-2019, 08:45 AM | #717 |
Rep 45
Guys,
when i do a OTA Update. For what reasons i have the factory xml file. Do i need to put it into my configuration in the factory settings? Or just let it on the usb flash while updating |
10-18-2019, 10:32 AM | #718 |
Rep 280
RaceX58
Alright, good news. After fiddling around with (Ed)Xposed for a while, I finally have it working with the InputManager. No lag whatsoever. Using Xposed, by hooking the android system process it is possible to give any package any permission. So I just gave my own App the system level INJECT_EVENT permission and can now inject inputs just fine. Now all I need is a list of all broadcasted Integers to do the mapping and in theory this should work. Can someone also compile a list of all apps where the iDrive controller already works by default? I included a little blacklist function to avoid duplicate inputs but need the package names. |
10-18-2019, 10:50 AM | #719 | |
Rep 190
10-18-2019, 11:52 AM | #721 |
Rep 190
10-18-2019, 12:48 PM | #722 |
Rep 399
10-18-2019, 01:07 PM | #723 |
Rep 280
If the button press ends up as a Broadcast aswell then yes, it can be intercepted.
But I don't know how much is hardcoded in the MCU. If it's only KswLauncher opening the App, that can be replaced with Xposed. |
10-19-2019, 07:43 AM | #724 |
Rep 220
Drives: MINI Cooper, 2020 X1
Would someone with a rooted px6 Android 9 unit be kind enough to back up (for example using the Official TWRP App from the Play Store) and post here or pm me recovery.img ? Thanks
10-19-2019, 09:08 AM | #725 |
Rep 15
Day 3 of failed install - reconnect all wires?
First post: been struggling (like some others) to install the Avin 10.25 Android 9 display for my CIC F30. Currently I get 'no signal' on the iDrive, no audio anywhere, and I can't eject my CD.
Today I disconnected the Avin unit and wiring harness, restoring the 'native' CIC display and wiring, and I just get a 'BMW' logo on the screen. Something is horked - it is all original wiring back in place. Question: do I need to re-connect ALL the wires to make iDrive 'connect', e.g. the hazard lights and the temp control? I just have the head unit and the display connected right now. |
10-19-2019, 12:07 PM | #726 | |
Rep 55
