10-14-2019, 04:53 AM | #2 |
Rep 173
Drives: BMW 340i Touring, Aston Martin
10-14-2019, 11:10 AM | #3 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
Yes, I'm in the process of doing it at the moment. At a minimum you'll need:
* DSC pump * ICM * ACC radar (plus bracket(s)) * front and rear wheel speed sensors * front bumper wiring harness I've installed everything and coded my car, the only thing left is to build a custom harness that connects from the bumper to the ICM and power. Cost so far is probably around $1800. I drive in stop and go traffic everyday and it is so sweet in my X5... |
10-14-2019, 11:25 AM | #4 | |
Rep 5,997
10-14-2019, 11:26 AM | #5 |
Rep 51
Oh Wow! I didn't realize there would be so much to it. I knew it was a $1,500 option from the factory but I thought it would be a matter of adding sensors to the front of the car.
Thanks for the answers guys. Right now I'm not driving much, but my situation could change forcing me to drive to Boston daily. If that happens I'll consider this, but until then I think I'll follow others progress and cross my fingers for them |
10-14-2019, 11:51 AM | #7 |
Rep 3,748
The things we do for something we don't want on our car to begin with and then want to add later....lmao
I'm not doing that at all... I just drive this car as-is until i decide to buy another new/used car that probably have all this or thing I want most. |
10-14-2019, 12:04 PM | #8 |
E36fiend
285
Rep 637
DSC is dynamic stability control, aka the ABS brake pump which is responsible for the automatic braking that occurs. ICM is the integrated chassis management module which controls many aspects of your cars driving dynamics including safety features like the airbag. You'll need both of those from a car that already has ACC, I found them for about $400 each. Did the wheel speed sensors at the same time which took like 5 minutes per wheel.
I gladly would have paid for this option had I purchased my car new but I saved a grip buying it used and I'll have it for many years so it's very worth it to me. ICM took about 2 hours to replace (have to remove the center console) and the DSC was pretty straightforward, took about two hours along with brake bleeding. I installed the radar last night which again took about 2 hours because the front bumper comes off but I also installed a splitter at the same time. I've spent much more time doing research and finding parts than actually installing them lol. |
otay826.00 |
10-14-2019, 12:11 PM | #9 |
Rep 4,210
Back when I lived in a southeastern Boston suburb and commuted to Cambridge the traffic was horrendous. You might be better off taking the train from Providence or South Attleboro if you live north of Providence. Then you won't have to try to add adaptive cruise control.
If not, consider a commuter car (something relatively basic with adaptive cruise control; you won't be able to use the power of a 340i on congested highways anyway) and save the 340 for other times and weekend use. |
10-14-2019, 05:00 PM | #10 |
Rep 906
not worth it. i estimate $3-4K in costs and labor. i miss is dearly on my new 440i, first time buying off the lot and not just ordering to spec.
2016 X3 35i M-Sport
2019 440i Coupe M-Sport - Retired 2018 330i Sedan M-Sport - Retired 2015 428i Gran Coupe M-Sport - Retired |
10-14-2019, 06:46 PM | #11 |
Rep 1,452
I’ve said this before.i tried to find ACC on a convertible. I must have looked at 100 cars. None had it. Apparently Germans are not big fans. On Bmw,it’s a stand alone option. On MB and Audi it’s only available on the top option package.
10-14-2019, 07:14 PM | #12 |
Rep 776
And on most Hondas and Toyotas it is standard equipment and not optional....
10-14-2019, 10:58 PM | #13 | |
Rep 10,473
10-14-2019, 11:06 PM | #14 |
E36fiend
285
Rep 637
It's about $1800 for parts alone and that's with a used DSC, ICM, and radar. I bought the steering wheel switches, wheel speed sensors, brackets and bumper harness new. I only need to build the last harness now, I should have it running in about a week
10-16-2019, 09:43 PM | #16 | |
Rep 257
Here's mine. It works fairly well.
2021 i3s AC Schnitzer BMW CCA #67486 |
10-16-2019, 11:43 PM | #17 | |
Rep 776
10-17-2019, 01:10 AM | #18 | |
E36fiend
285
Rep 637
I just ordered the connectors I need to build the last wiring harness, should be here on friday. I'm not happy about having to expose the ICM again to run wires but removing the center console wasn't really that hard. Second time should be much faster |
10-24-2019, 01:51 AM | #19 |
E36fiend
285
Rep 637
I just completed this retrofit! Finished the actual hardware installation over the weekend, ran the wires from the radar to the ICM last night, then performed the ACC start-up routine in ISTA tonight. Everything completed successfully, took the car out for a drive and voila, it works!
I don't know how feasible a full write-up would be, the hardware portion of the install is pretty much all in the TIS. I definitely would have some pointers for people who want to do it themselves but a fair amount of the process is just being able to figure out what goes where. You'll need to know your way around e-sys and ISTA, I doubt a single step-by-step process would be the same between two cars when it comes to the software. |
12-15-2020, 09:52 PM | #20 | |
Rep 950
05-05-2022, 08:55 PM | #21 |
Rep 22
I’m interested in doing this!
Not sure what parts I may need but my car is a 2019 440 I already have active blind spot detection, side and top view cameras, speed limit info (everything listed in the drivers assistance plus package except Active Driving Assistant). Have the drivers assistance package and parking assist. My car also has collision warning so if I have the sensors, radars, etc what else would I need? Was hoping it was just a coding issue or maybe a part are two. Any advice/help would be appreciated! Thanks |
05-05-2022, 09:15 PM | #22 | |
Rep 44
Drives: 1997 Ford Probe GT
This is the thread you are looking for "Adaptive Cruise Control Retrofit?" |
