04-10-2015, 09:46 AM | #1 |
Rep 1,107
Dinantronics (MPPK version)- Dyno Results
Well, I finally got my Dinantronics tune installed this past Monday. My car already had the "old" MPPK (mechanical wastegate) on it, so my Dinan tune is an MPPK "stackable" version. My initial driving impressions are that the car definitely pulls harder and feels more explosive. Furthermore, I did not experience any of the low end delay or lag that a few other members have mentioned with the Dinan tune. Instead, it actually feels more responsive with the slightest press of the throttle. Sport+ mode with shifter to the left feels phenomenal. It also continues to feel smooth and rather linear all the way to redline. There is no drop-off or any of the other issues I've heard experienced with other tunes.....no need to shift early or anything. As weird as this sounds, it feels almost as though the shifts are even faster (though that might be placebo effect because of the added power). It definitely makes the car feel more "M-ish"....although I'm sure it is still far from the feeling of a new F80 M3 haha!
To me, it is definitely worth the money, not only because of the peace of mind with the warranty aspect.....but also because I truly believe that the engineering involved with Dinan products makes a difference. Everything is smooth, snappy, and linear.....but now my organs are squashed against the seat even more so with every push of the throttle. I had it dynoed this morning on the same machine that I had my "before"results measured on (and very similar conditions.....65 degrees and rainy). Here are the #s: Before: 304 WHP and 308 lb-ft (wheels) After: 330 WHP and 352.2 lb-ft (wheels) Very impressive increases for a stage 1 tune in my opinion! Anyway, thought I'd share. Feel free to chime in if you're thinking of this tune and want further feedback/opinions. The Nerd |
04-10-2015, 10:23 AM | #2 |
Rep 939
Nice results but that's like $3000 for same performance of bms stage 1 for $379. I know that includes the BMW warranty on the Mppk and the Dinan rider warranty coverage on the stage 1 but hey, what ever make you sleep easy at night.
04-10-2015, 10:40 AM | #4 | |
Rep 1,107
The argument over Dinan vs JB4 has been beat to death (and each has its pros and cons). I merely wanted to chime in on my dyno readings since there's relatively little info out there on the Dinantronics and the power it puts out. |
04-10-2015, 10:45 AM | #5 | |
Rep 939
04-10-2015, 10:59 AM | #7 | |
Rep 1,107
04-10-2015, 11:03 AM | #8 |
Rep 2,210
Drives: '17 jackrabbit on crystal meth
BMS dyno'd Dinan stage 1 with aFe intake on an M235i (320 crank) and got only 313 WHP. So you can figure out what you'll get on your 300 crank x35i.
2017 BSM M2|6MT|Exec|black kidneys and gills|full alcantara wheel|CF spoiler|Dinan Stage 4|Dinan COI|Dinan free flow exhaust with resonator delete|Fabspeed sport cat DP|BMS clutch stop|465 bhp|4.75/5 stars
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
04-10-2015, 01:48 PM | #9 | |
Rep 467
Mustang is the most conservative of the bunch and is usually soul crusher with regards to numbers. |
04-10-2015, 01:50 PM | #10 | ||
Rep 1,107
04-10-2015, 01:54 PM | #11 |
Rep 1,961
Dyno Dynamics is the worst I've ever used. Read about 80whp lower than a DynoJet on my Jeep. Either must've been slipping or they're really, really, bad.
04-10-2015, 02:57 PM | #12 |
Rep 1,718
Any idea what the "new" MPPK numbers would be (before and after Dinan)? I have 2014 with the "new" MPPK (also came with the car as in your situation) and looking to stack something on top...
04-10-2015, 03:00 PM | #13 | |
Rep 467
I've been on every brand except a dynojet. Dyno Dynamics usually read in the middle from my experience. Perhaps the one you used wasn't calibrated or in need of service. Dynapack's read super high in torque. Mustang's just crush your soul with their low readings. If you hit 400+WHP on a mustang you're kicking lots of ass on the streets. |
04-11-2015, 05:39 AM | #16 | |
Rep 1,107
04-11-2015, 05:39 AM | #17 | |
Rep 1,107
04-11-2015, 08:17 AM | #18 |
Rep 158
I realize that horsepower is listed in various ways. You listed whp in your test.
According to the Dinan website when they added their Piggyback tune to a MPPk configured N55 they came up with 360 hp and nearly 430 foot pounds torque. Can someone tell me why such a big difference? I also had my MPPk installed at the port in December so I have no stock engine responses to compare. The plain MPPk is supposed to give me 330 hp with nothing added. Are you implying Dinantronics added nothing?
435i Imperial Blue 2015 /Luxury/Tech /Premium/MPPK/Dinan Stage 1/Dinan polished tip exhaust/HK/Driver Assist/Driver plus/M Sport Brakes/Side Cameras/Saddle Brown Dakota/Escort Max Radar
04-11-2015, 08:45 AM | #19 |
Rep 939
Depending on the type of dyno, dynojet, mustang(heartbreaker) etc results can vary greatly. Add in the other factors like temp, heat soak, density altitude, number of pulls, all effect the numbers. Finally switching from wheel horsepower to crank, again, changes the numbers. The reason dinan states crank numbers is because it's the bigger, more impressive number that has been corrected for drivetrain hp loss. It's a meaningless number. Rear wheel horsepower it the actual horsepoweR the car is putting down on the pavement.
In the end, a dyno is just a tool to have a before and after comparison to see how a tune or mod made a difference. Even then, it needs to be the same dyno, similar weather condition, and ideally, the same guy running the dyno to get an accurate result. |
04-11-2015, 09:45 AM | #20 | |
Rep 1,107
My torque is the only thing that seems to be a tad low compared to the Dinan claims (they claim 417 for my car)....but I'm very happy with the hp. The dip in torque could possibly be attributed to the fact that I have a catback exhaust, which sometimes causes torque to go down a hair. |
04-13-2015, 10:40 AM | #22 |
Rep 3,406
