02-29-2016, 08:31 AM | #1 |
Rep 67
b58 engine replacement recall
I just brought in my 340i xdrive for service about a week ago and they tell me it has a recall. Turns out there was a recall on the engine. Supposedly the bearings are either scratched or cracked or something and they have to replace the engine. Anyone going through this?
Updated with official bulletin: B58 Engine Recall - BMW Service Bulletin SI B11 26 15 Engine B58 Engine – Check and Replace Crankshaft Guide Bearing Model F30 3 Series Sedan with B58 engine and manual transmission. Situation The upper crankshaft guide bearing may wear out prematurely. The wear on the upper guide bearing can cause the clutch pedal to malfunction during shifting. The Engine Malfunction warning may be illuminated and a fault will be stored in the DME memory for the crankshaft sensor. Noise may be heard from the lower engine and transmission bell housing area. If the crankshaft guide bearing or crankshaft is found damaged during the inspection then the engine must be replaced. Engine damage is a rare occurrence. Affected Vehicles This Service Action involves F30 vehicles produced from July 2015 to November 2015. Vehicles which require this Service Action to be completed will show it as "Open" when checked by your local BMW dealership. Affected Vehicle VINs WBA8B7G57GNT70413 WBA8B7G58GNT70405 WBA8B7G51GNT70410 WBA8B7G56GNT70404 WBA8B7G55GNT70409 WBA8B7G54GNT70403 WBA8B7G5XGNT70406 WBA8B7G52GNT70416 WBA8B7G51GNT70407 WBA8B3G59GNA92609 WBA8B7G53GNT70411 WBA8B7G58GNT70419 WBA8B7G50GNT70401 WBA8B7G56GNT70421 WBA8B7G59GNT70414 WBA8B7G59GNT70400 WBA8B7G50GNT70415 WBA8B7G56GNT70418 WBA8B7G52GNT70402 WBA8B3G53GNA92606 WBA8B7G55GNT70412 WBA8B7G53GNT70408 WBA8B7G5XGNT70423 WBA8B7G5XGNT70440 WBA8B7G53GNT70439 WBA8B7G53GNT70425 WBA8B7G59GNT70431 WBA8B7G57GNT70430 WBA8B7G54GNT70434 WBA8B7G52GNT70433 WBA8B3G50GNA92613 WBA8B7G58GNT70436 WBA8B7G56GNT70435 WBA8B7G55GNT70426 WBA8B7G51GNT70441 WBA8B7G51GNT70424 WBA8B7G58GNT70422 WBA8B7G50GNT70432 WBA8B7G5XGNT70437 WBA8B7G55GNT70457 WBA8B7G51GNT70455 WBA8B7G53GNT70456 WBA8B7G5XGNT70454 WBA8B7G57GNT70458 WBA8B7G56GNT70466 |
02-29-2016, 08:37 AM | #2 |
Rep 421
Hmm. That's a little crazy if true. I have been hearing an odd whining/winding noise from the engine. It's been driving me crazy. It sorta sounds like bad alternator bearings judging by clips of that issue I've listened to but could potentially be bad bearings from some other location. Of course when I took it in they said they don't hear anything abnormal. I've been waiting until I switch out my winter wheels/tires to address it again since it otherwise drives ok with no warning indicators. I now obviously wonder if it's related to whatever this recall is about.
2016 340i xDrive, msport, estoril/saddle/anthracite, blk kidney grills, 400m mixed summer, adaptive m, technology, lighting, cold weather, drivers assistance, enhanced usb
02-29-2016, 08:42 AM | #3 |
Rep 67
well I never noticed anything wrong with the car or even any noticeable noise. My service rep said it's a VIN specific recall. I'm not all that knowledgeable on cars but he said they had to drop the oil pan to take pictures of the bearings so that BMW could determine whether or not to replace the engine. Now I'm waiting on them to receive the engine and install it
02-29-2016, 08:47 AM | #4 | |
Rep 903
edmfperez11.50 |
02-29-2016, 09:05 AM | #6 |
Rep 421
dtl1125 - do you know when your car was manufactured? Mine was early Oct.
02-29-2016, 09:08 AM | #8 |
Rep 1,342
Wow, that sucks. I was pretty bummed when the tranny had to be swapped on my car, but this is another level.
See if they'll add the MPPK for your inconvenience. |
02-29-2016, 09:11 AM | #11 |
Rep 67
and I've been thinking about what they can do for the inconvenience. they did put me in a 535i X drive executive package as a loaner. The service rep keeps pushing how it's a better car and I should be happy I get to cruise around in it for the price of my 340 but if I had it my way I'd be driving my car and not theres. so it seems to me he wants me to feel that they're doing me a favor as to not ask for anything else.
02-29-2016, 09:23 AM | #14 |
Rep 67
the interesting thing is they didn't contact me about it. I went in bc I had a bubble and bent the rim. also the driver side window was having an issue and I believe they replaced the regulator. I wasn't due for actual service for another 3-4k miles. the service rep said they did the service anyways so I wouldn't have to come in later. However I don't know why that matters bc they're putting in a new engine anways.
02-29-2016, 09:31 AM | #15 |
Rep 1,056
Shouldn't you (and us) be getting a letter in the mail for the recall as well?
02-29-2016, 10:32 AM | #17 | |
Rep 10,210
The oil pan was also dropped to examine connecting rod bearings and take oil samples (excessive metal shavings present). Could you please learn from the dealer what specific bearings were the root cause? |
02-29-2016, 10:54 AM | #19 |
Rep 1,056
Just checked my VIN for recall but shows nothing.
Does it show anything for you guys? http://www.bmwusa.com/recall
02-29-2016, 11:09 AM | #20 | |
Rep 326
02-29-2016, 11:10 AM | #21 |
Rep 421
Entered mine with no listed recall as well.
dtl1125 - Does your VIN show up as a recall on this site?
