09-21-2016, 11:53 PM | #23 | |
not good, but bad
333
Rep 361
This is the first intake I've ordered for my BMW so I have no comparison. I'd like to see the housings on other intakes, maybe that would explain more.. Logically it makes sense to me, perhaps the circular MAF housing creates some sort of turbulence that affects readings? I don't know but I would love to hear your input. And on the weight thing, c'mon dude, I'll take a dump before I go for a ride to make up for the added weight.
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
09-21-2016, 11:58 PM | #24 | |
2093
Rep 43,350
By using a cast aluminum MAF housing you're adding more heat to the intake tract as well. A thick slab of aluminum is going to conduct and retain significantly more heat than a thin tubed aluminum or even stock plastic intake. |
09-22-2016, 12:02 AM | #25 |
not good, but bad
333
Rep 361
Thanks! Very valid point there about the MAF housing. I plan on logging the IAT with both stock and CTS intake tomorrow. Curious to see how much of a difference there will be now especially with the cast aluminum point you made.
Thanks again!
09-22-2016, 04:31 PM | #27 |
Rep 210
I just took a look at my stock housing, and it sure could be hexagonal. I didn't reach underneath to count the sides, but it sure is irregularly shaped.
Looking forward to IAT measurements as this one may be at the top of my list.
Mineral Gray - Active Autowerke Stage 2 - MPerformance Suspension - VRSF CP - CTS Turbo IC - Catted Fabspeed - Akrapovic - HRE FF15
FSociety3807.00 |
09-22-2016, 11:05 PM | #29 |
not good, but bad
333
Rep 361
Just got mine today, finally got to the garage to start installing it. No install instructions at all. The intake part is pretty self explanatory but the brackets it comes with I can't figure out... Nothing on their website about installing this thing...
*** EDIT *** That was fun last night, finally got it installed. It was sort of a PITA without any instructions. Before I pass judgement/review it fairly I'd like to get the install instructions from CTS. I did some testing of IAT but I need to redo it properly. I've included the data on my site that uses a nice graph. The ambient air temps were different by about 10-20 degree's F so it's not a fair comparison at the moment. The initial testing of Torque and it's logging feature was done in the afternoon. Then testing of the CTS intake installed was done late at night when the ambient air temp was way different. The sound is crazy, this thing is going to get me in trouble with the wife. She took my son to school in it this morning and not even 5 minutes into the ride I get the "WHAT DID YOU DO TO THE CAR" call.... You can see the full review, install log, IAT charts on my site here [IMG]http://i1.wp.com/*************/wp-content/uploads/2016/09/IMG_0396.jpg?resize=768%2C512[/IMG] There is the stock MAF housing [IMG]http://i1.wp.com/*************/wp-content/uploads/2016/09/IMG_0388.jpg?resize=768%2C512[/IMG] And the CTS MAF housing Nearly identical.
BreadsBMW on Youtube Last edited by badbread; 09-23-2016 at 01:02 PM.. |
FSociety3807.00 |
09-23-2016, 02:19 PM | #30 |
not good, but bad
333
Rep 361
Here's a couple links to a couple more charts on Datazap.me
Stock Airbox IAT vs Ambient CTS Intake IAT vs Ambient Some quick data I extrapolated. Using the areas where my average speed was around 68MPH Stock the ambient temp averaged 71.6F (22C) and the intake 100.4F (38C) a difference of 28.8F CTS the ambient temp averaged 59F (15C) and the intake 77F (25C) a difference of 18F Once again, I'm very unsure of the validity of this data so please take this with a grain of salt. I would really be grateful if someone with knowledge and experience could chime in and validate or invalidate the significance and accuracy of this data. Also maybe even a little guidance on what to test and how. Thanks again!
BreadsBMW on Youtube Last edited by badbread; 09-23-2016 at 02:36 PM.. |
FSociety3807.00 |
09-23-2016, 02:36 PM | #31 |
2093
Rep 43,350
Looks like it's vastly different in diameter alone. Issues with intakes on MAF cars are due to the diameter of the tubing used, not the general shape of the surrounding area.
09-23-2016, 02:51 PM | #33 |
not good, but bad
333
Rep 361
Not yet, but I've actually been brainstorming a way to get an accurate representation of the sound. I'm going to experiment a bit with an external mic tonight I hope, stay tuned.
09-23-2016, 02:57 PM | #34 | |
Rep 210
It appears you are going out of your way to criticize another manufacturer's product. First you stated that the stock MAF housing wasn't shaped the way CTS Turbo claimed. Then, when that was shown to not be the case you claim that the MAF housing is vastly different in diameter, even though the only person to compare the two so far said they are pretty much identical. As someone who purchased your charge pipe shortly after it was introduced, and who also posted the solution for the issue with the vacuum connection not fitting properly, I have to wonder why you are choosing to criticize the CTS Turbo product before anyone has had any hands on experience yet. If you have purchased one of the CTS Turbo intakes and have found a problem with the product, some firsthand experience would of course be appreciated.
09-23-2016, 03:05 PM | #35 |
2093
Rep 43,350
I'm not going out of my way at all, I'm just making sure people are aware that the cast maf housing is in fact a gimmick. It's not identically shaped to the OEM nor is it the same diameter. It certainly won't have a different effect on your idle/cruise vs a standard round tube like the BMS or Injen offerings.
We don't even make a F30 intake, I have no skin in the game. I'm giving my unbiased opinion which is backed by over 15 years of personal experience with MAF based cars so folks don't get duped by the hype. It's your car and you're free to modify it however you'd like. Honestly I hope it works out for you. |
09-23-2016, 03:07 PM | #36 | |
Rep 210
FSociety3807.00 |
09-23-2016, 03:07 PM | #37 | |
2093
Rep 43,350
09-23-2016, 03:10 PM | #38 | |
Rep 210
09-23-2016, 03:13 PM | #39 | |
not good, but bad
333
Rep 361
Thanks for the tip! Exactly the type of info I'm looking for. Unfortunately it doesn't look like Torque logs WGDC (Waste Gate Duty Cycle?) or gear. I've added the others to my what to log list for future logs.
FSociety3807.00 |
09-23-2016, 03:21 PM | #40 | |
2093
Rep 43,350
The cast aluminum part is definitely an easier/less expensive option unless you're making thousands of pieces. |
09-29-2016, 12:45 PM | #41 |
not good, but bad
333
Rep 361
So after a few more days with the intake I'm still not sure what to think.
I've reached out to CTS through email, phone and through the other company they are affiliated with when you call them and have received no response at all. The sound has definitely grown on me, it's loud but it's fun. It's really cool to hear all the inner workings of the turbo. As far datalogging, IAT and the like. Last night I was driving around quite a bit and it was finally a regular bay area night (temps in the low 60's.) The difference between the IAT and the ambient temp was around 50-60F, not sure why it was so different from my initial logging but being such a cool night I would expect IAT to be a bit lower and closer to the ambient. [IMG]http://*************/wp-content/uploads/2016/09/datazap-chart-3.png[/IMG] Link to interactive chart on datazap: http://datazap.me/u/lpfake/ambient-v...data=1-2-3-4-5 There is a WOT from a roll in there as well. ~10MPH to 100MPH (according to the graph) in 11 seconds. I don't remember going that fast but I guess it's possible. Not sure if that data is helpful, it's towards the end of the graph. I guess my question is, is it normal for ambient and IAT to be that far apart? Colder air is better air right? Hence having an upgraded IC. Using something like Dinan's CAI or even the stock intake just seem to make more sense logically but what do I know. I understand the restriction argument but from what I've read, the stock air intake system isn't all that restrictive.
10-03-2016, 01:26 PM | #42 | |
Rep 9
You're right in saying that colder air is better and an upgraded IC is the best at getting that job done. The function of the intake is to maximize the potential air flow to your engine... not suck the coolest air possible, because... the air still has to flow through a red hot turbo before it reaches the engine. |
