01-29-2018, 09:46 AM | #45 |
Rep 1,348
Thanks for clarifying, as that's what my prior question was about.
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 01-31-2018 at 08:05 AM.. |
01-29-2018, 11:06 AM | #47 |
Rep 5,369
The gains look great; however, given the infancy of the OBD flash tune on the N55, how can AA offer a reliable OBD tuning option when MHD and others are still in the beta phase?
What's their support network like for those that might have issues? How are they addressing the OEM flash reinstall, flash counter, and other matters?
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
01-29-2018, 11:12 AM | #48 |
Rep 190,777
01-29-2018, 11:15 AM | #49 | |
Rep 190,777
You can call them with any questions about your map and you will get support from Carl, the guy who created all their maps not some customer service rep. I already addressed the flash counter question. OBD solutions do not reset flash counters.
01-29-2018, 12:23 PM | #50 | |
Rep 504
New Functions added: added Restore ORI function (restore to original FLASH, does not modify EEPROM) – for warranty purposes added Reading Secret key (ISN) for diesel engines* – useful function for recoding used ECUs added FLASH COUNTER LOCK function* – now you can write as many times as you want your car on the dyno. Flash counter will remain always ORIGINAL. source : https://www.magicmotorsport.com/bmw-...1-07-released/ |
01-29-2018, 04:32 PM | #51 |
Rep 1,348
This is the same with Bootmod3 as I was told I would have to send them my ECU. However this one posted above seems to allow you to reset flash counters thru OBD. Hmmmm interesting if its true.
01-29-2018, 04:33 PM | #52 | |
Rep 1,348
01-30-2018, 05:48 PM | #53 |
Rep 1,805
looks like a solid option!
Nice
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
01-31-2018, 05:27 PM | #54 |
Rep 125
Sorry if this has been asked/answered but I haven't seen it
Is this compatible with apple products? If so, that would be a huge plus for me rather then purchasing a device just for tuning purposes |
01-31-2018, 06:27 PM | #55 | |
Rep 190,777
That being said, you will only need a laptop once. After you upload the map, you are set you wont need to do any changes. Instead of buying a new laptop, borrow one from a friend for a one time 20 minute use
01-31-2018, 06:38 PM | #56 | ||
Rep 125
Thanks! |
01-31-2018, 11:18 PM | #57 | |
Rep 190,777
Not sure i can honor the price in a month, we are doing an intro price for the first batch of tunes sold
F30-XP-DM47.50 |
02-05-2018, 12:53 PM | #58 |
Rep 603
Hi Mike
I'm interested as well. please pm me if possible for Europe/Switzerland shipping of the ODB cable. Any impact to emission? Will the car pass the emission test (no DP, all stock, cat) thx
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
02-12-2018, 07:30 PM | #59 |
Rep 190,777
02-12-2018, 11:38 PM | #60 |
Rep 110
Hey I've seen a bunch of tuning options come up for the n55. What options are available for the Activehybrid 3? Would love to get more power. Currently run a downpipe, chargepipe, and intake.
02-13-2018, 02:23 PM | #61 |
Rep 70
My car has a catted dp, intake, mpe exhaust, and intercooler. I'm currently running jb4 map 2. What are the benefits as to running this flash tune as opposed to sticking with the jb4? Aren't power gains similar?
02-13-2018, 02:25 PM | #62 | |
Rep 190,777
Also burble tune, cold start delete, speed limiter removed Best would be to get run both at the same time
02-13-2018, 02:38 PM | #63 | |
No 55mph
1621
Rep 8,476
When I recently talked with Andrew I asked him if I could continue to run my current Active8 piggy back in conjunction with the flash tune (I know your reply to me earlier was that I could - that A8 would control boost & flash would control everything else) But his reply was that I shouldn't because the flash tune already increases & controls the boost - if I used both I would run into an overboost situation (boost would be effectively doubled i.e +4psi from A8 + whatever boost flash is calling out) & damage my engine Trying to understand the discrepancy
02-13-2018, 02:41 PM | #64 | |
Rep 190,777
With the Jb4 it is different since the Jb4 offers features that the flash cannot do on its own.
1QuikWS61620.50 |
02-13-2018, 02:49 PM | #65 |
No 55mph
1621
Rep 8,476
So next question is there a time limit to how long after I receive my cable that I request my flash tunes?
I would like to completely disconnect the A8 before flash, but it's pretty cold right now to be doing that outside I want to take advantage of your spring sale but wouldn't flash till 1 month or so till I had chance to uninstall A8 Unless it's good enough to temporarily disconnect harness from A8 brain and install Valet plug to harness - effectively bypassing A8???? Or I guess I could request tunes right away, download to laptop then simply wait to install
02-13-2018, 02:55 PM | #66 |
No 55mph
1621
Rep 8,476
I also understand that the new AA hi flow catted DP is in final test and will be released soon that according to Andrew is guaranteed No CEL as the Fabspeed, but at reduced price
This would be a nice combo deal DP+Flash to enable customers to go directly to Stage2 flash Any concrete availability on DP? Combo deal possible?
