BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ***DIY: bootmod3 OBD Agent build with RPi 3 B
Studio RSR
      09-18-2018, 07:16 AM   #221
wjjkoevoets
Bright Sky
wjjkoevoets's Avatar
Netherlands
1164
Drives: BMW M235i (8AT)
2014 BMW M235i  [0.00]
Originally Posted by stlb5 View Post
I take it back, I'm getting freezing on just the ENet cable too. Never had this prior to the update. I submitted a ticket.
Have the same issue. Scanning for codes seems to fix it. If you find a solution, please let us know!
@ OP: Thanks for the DIY guide. Installed mine just like you did and it works great!
BMW ///M235i (EBII) - BM3 (+TCU) - Wagner DP - ER CP - ER TIC CP - CSF FMIC - GFB DV+ - Pure Inlet - K&N Drop-in AF - MPE
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive.
JaredG_F301106.00
      09-18-2018, 07:49 AM   #222
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
I just flashed a map revision yesterday (reduced my cold start idle speed) with my wifi agent and the new firmware is very quick in flashing a new map. bm3 just gets better and better.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
BunkerJ1032.00
      09-18-2018, 08:23 AM   #223
M2Rush
Drives: 2014 BSM 335i x-drive
Anybody else having issues with the 'Download now and flash later' option? My agent works fine; it connects, logs, diagnose/reads codes and is fine with a regular flash but just doesn't like it when I try to download, it just gets stuck and crashes the app on my iphone. Mind you, if I do the regular flash, it would download fine and then under My Maps, it shows downloaded in green. Works perfectly otherwise.
      09-18-2018, 11:25 AM   #224
JaredG_F30
JaredG_F30's Avatar
1106
That is odd. What phone are you using?
      09-18-2018, 11:31 AM   #225
M2Rush
iphone 6 plus, kinda old but gets the job done and with the current selections/new features, I'm not urged to upgrade.
You think it's the phone? Maybe I'll try another.
      09-18-2018, 12:15 PM   #226
M2Rush
Nevermind... I updated to ios 12 and it worked fine(or maybe I got lucky, will have to test at a later time).
JaredG_F301106.00
      09-20-2018, 07:08 AM   #227
wjjkoevoets
Bright Sky
Netherlands
1164
Solution: Update to the just released agent update
      09-20-2018, 01:07 PM   #228
stlb5
stlb5's Avatar
217
Drives: '19 M2C MT, '15 X5 Msport
Yep, didn't know if they were going to make an announcement. I didn't want to steal their thunder. Mine still pauses for a fraction of a second, but Dzenan said it does not affect logs. My data logs looked clean.
Their customer service has been spectacular! Very quick responses.
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers)
2014 M235i MT, BSM, MPE, Dinan Springs (Sold)
      09-21-2018, 03:19 AM   #229
wjjkoevoets
Bright Sky
Netherlands
1164
Yep, much better now! Support has been solid so far.
      09-25-2018, 08:35 AM   #230
mdmay
Drives: e91 325i n52
Will the DIY device work with android devices as i am not an apple user
      09-25-2018, 08:58 AM   #231
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Yes. Works with Android much better and with fewer issues.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      09-29-2018, 04:02 PM   #232
Djdnav
Drives: F80 M3
Thanks for the post! I only found out from a youtube video that you need to connect your phone via a cable to the RPi device as well. The OP never specifically says that.
///M3
      09-29-2018, 08:26 PM   #233
stlb5
stlb5's Avatar
217
Because you don't have to. You can, but hotspot works too.
      10-01-2018, 01:57 PM   #234
bm3nyc
bm3nyc's Avatar
Drives: F90 M5,F85 X5M, F15 X5, F80 M3
2019 BMW M5  [0.00]
2015 BMW X5 50i  [0.00]
2017 M3 ZCP  [0.00]
2017 BMW X5M  [0.00]
FSociety just notified me that PTF has released the latest and greatest OBD Agent 10.34 that fixes all freezes.
Contact US @bootmod3nyc on IG
CTS Turbo Intakes/Downpipes/Chargepipes N55/B58/S55 | Lusso F90 M5 Downpipes/Intakes/Midpipes| Bootmod3 N55/S55/N63TU/S63TU Dealer !
      10-02-2018, 10:20 AM   #235
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
Looks like I just got version 10.35, can you confirm?
      10-02-2018, 11:32 AM   #236
n55silverado
mercenary
n55silverado's Avatar
Drives: 2021 X5
- Followed OP's instructions, except powering agent through rear cigarette lighter.
- Everything was a success.
- Using hotspot from iPhone X on iOS 12
Noelified228.00
      10-02-2018, 12:43 PM   #237
Noelified
Noelified's Avatar
Drives: 2016 F36
It's certainly the way to go for flashing.
◊ 2016 F36 xDrive N26 ◊ Black Sapphire Metallic ⁞ Dakota Black ◊
║ VRSF HD FMIC ║ ER DP custom paint ║ AWE cat back Exhaust Suite ║ NGK Plugs ║Bootmod3 Stage 1 93 ║ GFB DV+ ║ BMS 10mm Front ⁞ 12mm Rear Spacers ║ P Style BSM Rear Spoiler ║ Smoked Front Reflectors ║ Madico Onyx 20 Tint ║ LCI Lighted Trim Bezel ║ Opti-Coat Pro+ ║
      10-04-2018, 09:48 AM   #238
Djdnav
Drives: F80 M3
The firmware link is 404'd
///M3
      10-04-2018, 02:40 PM   #239
Noelified
Noelified's Avatar
Drives: 2016 F36
Working on this end...did you try again?
https://www.dropbox.com/s/bd0yqkh25n...35.img.gz?dl=0
      10-05-2018, 09:35 PM   #240
doodlebro
Drives: '17 X3 35i
Thanks for the write-up Jared. Got my OBD agent up and running today with no issues at all. Definitely worth it as I don't need to lug my laptop around anymore
JaredG_F301106.00
      10-10-2018, 01:09 PM   #241
r0wr
Drives: Beater
Originally Posted by BunkerJ View Post
Originally Posted by Noelified View Post
I think what BunkerJ meant was 12V "sockets" supply 12V to a USB "adapter" that supplies 5V. We need to remember these are nominal numbers to categorize these devices by a Standard. As your documentation points out a properly functioning 12v socket can actually range from 9v to 16v and be called a 12v socket. Thus a 12v categorized device matches up with a 12v categorized supply socket. This is not to say if the voltages are above or below exactly 12v they brick. This is just a standard for us to know what it is safe and intended to match up with. And a 12v adapter that is made to USB standard is designed to take the range of 12v from the socket and supply it's USB outlets with the nominal 5v. That being said, current is the more important factor in damaging electronics than voltage is. Its luring to think voltage damages a device, and it kind of does, but in the end voltage only encourages the current flow which is always what actually causes the damage. Current is the electron flow, and only that flow does the work whether its functioning or damaging work. So simply speaking, all damage in a circuit is caused by current.
In the end we should be safe to assume a 12v rated device, plugged into a 12v rated supply are made to work together, therefore should not be able to overload or overdraw and cause damage. Does it happen yes, by why worry so much especially since these Pi boards are under $30. We're not talking about a $3,000 electronics board. Our car also circuit fuses designed to fail if an improper current is flowing through the line. So IMO it's safest to a cheap 12v device into a protected 12v source. That way if the cheaply made device is out of spec or standard and over or under draws it will simply blow a fuse or fry itself. At least that's my take on the Pi and plugging it in. When I get around to it, I'm tapping a 12v socket into the 12v socket line under the dash center. I'll report back if sparks fly
Precisely. That's my fault for assuming I would be understood.
My current setup is a 12v cigarette socket adapter (the one under the dashboard) that outputs 5v to two (2) USB Micro B cables that run immediately under the radio/A/C controls. One comes out on the opposite side of the trim to charge the tablet while the other stays within the trim and goes to panel below the steering wheel. There I have my Pi plugged into power and also the OBD2 port.
There are boards to convert 12v to 5v that you could slap on top of the Pi as well.
Can you show pics of your set up and where you're running everything?
      10-11-2018, 09:26 AM   #242
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
View post on imgur.com
r0wr589.00
