01-30-2018, 01:58 PM | #133 |
Rep 189,818
01-30-2018, 08:26 PM | #134 |
Rep 115,955
01-31-2018, 09:25 AM | #135 |
Rep 100
I'm about to install my VRSF Chargepipe Set before also installing the JB4.
Does anyone of you know about Boostpipe Failures? (I mean the Turbo to Intercooler Pipe) Thanks! |
01-31-2018, 10:11 AM | #137 | |
Rep 115,955
Mike |
01-31-2018, 11:45 AM | #138 | |
Rep 189,818
I recommend only changing it if you are upgrading your turbos
zapp177.00 DrivenByE30578.00 |
02-02-2018, 06:35 AM | #139 |
Rep 3,870
That's interesting, one would think the combination of higher pressure and heat is much greater (therefore more destructive) on the pipe from the turbo to the intercooler, than the pressure after (out of) the intercooler...
02-03-2018, 07:04 AM | #140 |
Rep 775
Agree with Mike, and don't think i've seen anyone break/pop a stock TIC. Did it in the 435i because, heck, once you're in there doing the uprated turbo, IC, etc you may as well.... i would suggest installing a GFB DV+ tho.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
02-05-2018, 12:57 PM | #141 | |
Rep 115,955
Mike |
02-05-2018, 12:58 PM | #142 | |
Rep 115,955
Its more a better flow install then a preventive failure install like the Charge Pipe.. If doing the full FMIC and charge pipe I usually recommend doing the TIC, but I wouldn't do the TIC on its own. Lots of work for install.. Mike |
02-05-2018, 02:10 PM | #143 |
Rep 206
It doesn't break because it's built completely different than the charge pipe. The TIC is made with flexible rubber hose material (similar to a rubber radiator hose) with metal collars on each end that attach to the turbo and intercooler. The only plastic on a TIC pipe is the piece that holds the C clip in place. Perhaps with enough boost one could blow out the rubber though no one has ever reported that....but it can't fail the way the CP does since it's metal on each end instead of plastic. The two aftermarket TIC pipes I'm fmailiar with for the F3x models are slightly larger in diameter which may or may not gain you anything...at it's smallest point, the OE TIC pipe is almost 1 inch in diameter smaller than the ER and FTP TIC pipes.
02-26-2018, 01:07 PM | #144 |
Rep 571
Now I am getting paranoid about my charge pipe breaking. Can someone give me some help.
If I go with a catted pipe and I do get CEL's is there a permanent fix or do I have to keep clearing them? Does MHD provide the permanent fix or do I need different coding? Last, I assume the dealer won't change it to an aftermarket part, what does it usually cost to get it installed and any suggestions in the DC are? Thanks in advance. |
02-26-2018, 01:18 PM | #145 | |
Rep 115,955
CP install should be one hour labour charge. Mike |
El Conquistador338.00 |
03-09-2018, 12:54 PM | #146 |
Rep 14
I bought my 2014 335i with 34,434 miles previous owner was a mom, never drove it hard. 2 days after buying the car, chargepipe blew in the same way as the picture above. the C clamp snapped off, found it sitting in the catch pan. Let alone my car is bone stock. I upgraded to a VRSF CP and had no issues since. It did throw a CEL and Drivetrain Malf. after it blew.
02-25-2019, 08:04 PM | #147 |
Rep 4
CEL due to failed CP
I was pulling out of a Wendy's parking lot the other day and went WOT and next thing I know, boom my CP comes off with a Drivetrain malfunction error code and a check engine light. I just got an ER CP and plan on installing it myself on Friday. Would the CEL automatically go off when I install the new(and a million times better) chargepipe?
02-25-2019, 08:16 PM | #148 | |
Rep 189,818
02-26-2019, 04:56 AM | #149 |
Rep 4
02-26-2019, 05:21 AM | #150 | ||
Rep 129
120308 Low charging pressure 121531 Pressure to low 120408 Charging pressure control deactivation 102002 Air mass to low 121533 Charging pressure to low |
02-26-2019, 07:32 AM | #151 |
Rep 373
100% i got all those codes when i incorrectly installed my new charge that popped off.
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
02-26-2019, 09:08 AM | #152 |
Rep 189,818
Looks normal for a broken CP, let us know if you get any codes once the new charge pipe is installed
02-26-2019, 12:25 PM | #153 | |
Rep 129
