BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Weird dash lines on instrument cluster
      10-20-2019, 01:57 AM   #1
drdonuts
Taiwan
Drives: E92 F20 F82
Hello, after some play around with KOMBI and HU_NBT FDL editing, I found my instrument cluster's screen show up this dash line as shown below.
Initial thought it's probably speed limit info, but isn't SLI logo has a red circle around the dashes? If anyone know, please help. Many thanks!
Name:  Screen Shot 2019-10-20 at 2.55.12 PM.png
      10-20-2019, 04:33 AM   #2
IAmATeaf
IAmATeaf's Avatar
Drives: 2015 F30 335i
2015 BMW 335i  [0.00]
What car is that from?
      10-20-2019, 04:38 AM   #3
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
That’s indeed for speedlimit info, since you don’t have it, it doesn’t show up in a red circle.
      10-20-2019, 09:36 AM   #4
drdonuts
Taiwan
Drives: E92 F20 F82
This one is from 2018 1series F20 LCI.
      10-20-2019, 09:49 AM   #5
drdonuts
Taiwan
Drives: E92 F20 F82
Got it! Thanks! I'm getting a module. Hopefully there is no additional coding needed and everything show up properly.
Here is the code that I input earlier, please let me know if I'm doing anything wrong:
VO added 8TH
HU_NBT2 EXBOX, SPEEDLIMIT_INFO = aktiv
KOMBI Anzeige_Konfiguration, SPEED_LIMIT = aktiv
KOMBI KI_PIA_SPEED_LIMIT = aktiv
KAFAS2 SLI_ON_OFF = F20 F30...
      10-20-2019, 10:52 AM   #6
IAmATeaf
IAmATeaf's Avatar
Wow that looks so much better than the blank black area under the speedo.
      10-22-2019, 05:16 AM   #7
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
VO added 8TH
You also need an adapter for enabling speedlimit info, coding alone won’t do the job.
      10-22-2019, 06:56 AM   #8
drdonuts
Taiwan
Drives: E92 F20 F82
I'm getting one on Ebay, FSC code option is just way too expensive. Hope the changes I randomly added didn't mess up anything. Thanks a lot to clear this out!
Yea, indeed it's really eye catching on an entry car like this F20.
      10-22-2019, 02:24 PM   #9
IAmATeaf
IAmATeaf's Avatar
Oh I thought you had fitted it to an f30?
      10-23-2019, 09:56 AM   #10
Mikef30335
Drives: BMW F30 335xi
I thought only M models can have the current speed displayed, or does it come with newer cars or some adaptive cruise control package. Mine is an F30
      10-23-2019, 12:38 PM   #11
drdonuts
Taiwan
Drives: E92 F20 F82
No, it's from a F20 LCI. My bad came to F30 asking for coding on a F20 causing confusion.
Adaptive cruise control sounds way too fancy that I really never seen F20, F80/82 around equipped. I believe newer F-series cars all equipped with this newer instrument cluster. By the way, I saw bunch of F30s went for all digital instrument cluster upgrade which is way cooler.
      10-23-2019, 05:54 PM   #12
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
F20 LCI’s get this by standard when ordered a pro navigation.
F30’s get the full digital or the 6WA.
      10-24-2019, 07:07 AM   #13
drdonuts
Taiwan
Drives: E92 F20 F82
Module came in earlier, I had it installed and only coded KOMBI and HU_NBT's SLI option.
Because when I try to code KAFAS's SLI related options I found out the circle start blinking. I'm gonna try to have it tested and see actual speed number will come up or not.
