BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > 3/7/20 NoFlyZoneArizona 1/2 Mile Event
      03-15-2020, 11:59 AM   #1
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
Sooooooo.....good time, but not happy with final results. Although the last two runs, she matched or out MPH'd MUCH higher "listed" HP cars, I was limited to only 3 runs.
I'll be reviewing some of the video footage I was able to get, then splice it together...hopefully there's something there I can use
Trap Speeds:
1st Run: 106.3327mph
This run was an absolute shit show, lost traction, hooked in fourth and coasted to the end to regroup for 2nd run
2nd Run: 141.5985mph
MUCH better rolling launch
3rd Run: 144.0461mph
Good run....until the end. Cool down taxi back after run, car started hesitating/misfiring pretty bad. Pulled back to camp to look it over (No Codes).
IAT’s are most likely the culprit...were 150+ degrees (ambient temp was around 72 degrees) Plugs may also be gapped too high for e40 (.22) Going to pull plugs and take a look, if plugs are fine...I may just re-gap to .20 and do a few 4th-6th gear pulls.
I'm certain I left higher trap speed on the table.... I should've seen 150+mph.
My Build Thread can be found HERE
n55david1295.50
