10-04-2020, 08:39 AM | #1 |
Rep 35
Lambda error F30
Hi guys,
I have used bimmerlink to diagnose my car and found out 3 x errors regarding lambda. You can see them in attachment pic but just to be sure I'm writing them here as well: 284E00 Lambda probe to Kat, signal Nernst voltage: interruption 283400 Lambda probe to Kat, heating control: interruption 282E00 Lambda probe to Kat, heating control: short circuit to positive Should I avoid using the car until I fix the issue? What negative effects should I experience if I continue to drive the car? Car is a bmw F30 320d ED from 2015 (B47 engine) |
07-14-2021, 12:42 PM | #2 |
Rep 24
Did you have any recall for your car? I have a 2015 420d b47 same engine and there's a recall about EGR, doing it next week. I also have the same 284E00 lambda error and dpf getting blocked, regen error...will let you know if it was fixed.
If not, it's probably the oxygen sensor going bad. It's a known problem in these cars... |
11-21-2021, 09:24 AM | #3 | |
Rep 5
Hi George i`ve have the same problems,do you fix it? |
11-21-2021, 09:25 AM | #4 | |
Rep 5
What i need to do to see if my car need a recall to? |
11-28-2021, 04:53 AM | #5 |
Rep 35
Hi guys,
When I posted the topic here I also did it on the regional UK forum and provided the solution there but forgot to input it on this forum as well. Here you go: "Just to let you know, I have changed lambda sensor PN 13628570689 responsable for the error codes and the car behaviour has changed a lot. The fuel consumption has decreased and also dpf regeneration doesn't happen as often as before I changed the sensor." Cheers |
