04-03-2018, 07:27 AM | #1 |
Rep 201
My tips
My tips look like they stick out a little too far. I had my dealer install a dinan midpipe before I picked up the car so I've never seen it with a stock exhaust setup. What do you think? Do they look right?[IMG][/IMG]
04-03-2018, 10:26 AM | #2 |
Rep 1,170
Look's right to me. Also be aware exhaust tip's can protrude more when they are warmed up vs cold. Compare where the tips are at the start of the video in this thread with where they are at the end.
http://f30.bimmerpost.com/forums/sho....php?t=1480783 edit: also possible the camera was getting ready to fall off, looks like it may have moved during the video?
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. Last edited by Beek; 04-03-2018 at 10:31 AM.. |
2turboBMW115.50 |
04-04-2018, 09:36 AM | #6 |
Rep 96
Its true when exhaust is hot the tips protrude more. My observation as well because I installed midpipe myself. Your case the muffler is hanging little bit low. You have to adjust the midpipe counterclockwise so tips move upward you can also push the muffler in if you find its sticking out too far. Call the dealer to sort it out
2turboBMW115.50 |
04-04-2018, 10:26 AM | #8 |
Rep 200
Drives: 2017 330i M Sport
If you fitted the exhaust on yourself then try adjusting the point where the exhaust attached. If it's stock then you can unbolt the exhaust hanger brackets and try adjusting them
Thatf30.com
2turboBMW115.50 |
04-08-2018, 09:40 PM | #10 |
Rep 1,452
Side note: where are you in NYC that you have a driveway? I didn't bring my 340i b/c parking garages in the city are hella expensive lol.
2022 CT4-V Blackwing 6-speed
04-09-2018, 08:18 PM | #11 |
Rep 201
Recently moved to Long Island, but I used to rent someone's driveway when I lived in Queens. It was a lot cheaper than a parking garage.
04-10-2018, 09:29 AM | #12 |
Rep 115,980
