BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - California > FS: GTS style aluminum hood - professionally painted white (top and bottom) perfect
      09-27-2021, 12:09 PM   #1
chenry
Drives: BMWs (current:M340)
SOLD
exE36M3392.50
      10-06-2021, 08:24 PM   #2
chenry
Exclamation
      10-18-2021, 06:31 PM   #3
chenry
      10-22-2021, 01:52 AM   #4
e_b_d_i
Drives: 340i
Any idea what an install would run me? This does not strike me a project I'd try to tackle myself.
2018 340i
      10-23-2021, 02:32 PM   #5
chenry
So the install was about 20 mins at a body shop (I was surprised how easy it was) - there are two bolts on each of the hood brackets (one you simply loosen and one you remove) and then the black plastic washer tubing etc just pop out and into the new hood (holes are the same) - the hood latches easily unscrew.
So the actual install is quite easy - what takes a little more time is the subtle adjustments to the hinge bolts etc to get the gaps the way you want them. In the photos the hood was simply bolted on with no further adjustment so it is very good just the way it is
Hope this helps
      10-30-2021, 02:12 AM   #6
ScottyBeam
ScottyBeam's Avatar
Drives: 2009 M3 Convertible
How much?
