BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > help needed: problem of coding
      09-20-2019, 12:36 PM   #1
evanni
Drives: BMW425i
Hi experts,
My BMW connected drive expired for a while. Today, when I use BMWAiCoder, I tried to added two VO code. When I use E-sys to edit FDL code, I met the following issues:
CAFD_00000794_012_037_100 Fehler:
CPS read from ECU "ECUId:FEM_BODY_0x40" failed! [C070]
openECUConnection for link FEM_BODY_40_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name FEM_BODY_40_ETHERNET doesn't map to an item [1694]
CAFD_000016EE_113_109_005 Fehler:
CPS read from ECU "ECUId:IHKA3_0x78" failed! [C070]
openECUConnection for link IHKA3_78_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name IHKA3_78_ETHERNET doesn't map to an item [1694]
CAFD_000007A1_005_036_014 Fehler:
CPS read from ECU "ECUId:REM_0x72" failed! [C070]
openECUConnection for link REM_72_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name REM_72_ETHERNET doesn't map to an item [1694]
CAFD_000000B5_012_004_015 Fehler:
CPS read from ECU "ECUId:SM2_0x6D" failed! [C070]
openECUConnection for link SM2_6D_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name SM2_6D_ETHERNET doesn't map to an item [1694]
Even after I deleted the added 2 VO code, the same issues are still there.
I try to fix it by myself. I use e-sys to calc. the car FA file, I found in FP, item 15 listed as "unknown" which does not exist if I do the same from previous FA backup. However, I am not able to write preivous FA back, it just does not work in VCM.
Does anyone could give me some hints how to fix it? My car is 328GT/2015. Thanks in advance.
      09-20-2019, 03:18 PM   #2
atzebmw
Drives: BMW 335XD F30 LCI
It seems like you did not choose the right connection type or car model or the ignition was not switched on.
      09-21-2019, 01:16 AM   #3
evanni
Drives: BMW425i
Thanks, you are right. I forget to select F020. Now the issues are gone.
