BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > LED DRL Dim when Turn Signal Active *** SOLVED ***
      05-10-2018, 11:50 AM   #67
stu14t
stu14t's Avatar
Scotland
398
Drives: 335d MSport+
Originally Posted by GuMiMoRo View Post
Someone with F20/F21 of 2014 , take a look on files they do this by default... can we copy it to f30 modules ?
Unfortunately, the headlight units from a F20.F21 are different models to F30 and you are correct the do dim but that's not coding and I think it's only F20 with adaptive LED. They will use TMS
New - 2017 F30 335d M Sport + in San Marino Blue
Gone - 2015 F30 LCI 320d M Sport+ Step Auto
Gone - 2012 F30 320 ED
Gone - 2011 E87 118d
      05-15-2018, 07:48 PM   #68
daMANiack
daMANiack's Avatar
Australia
Drives: BMW F26 X4 35d
Hi,
Any chance the DRL Dim when turn signal active would work on my 2016 F26 X4 35d with XENON head lights?
Cheerz
      05-15-2018, 08:13 PM   #69
doodlebro
Drives: '17 X3 35i
Originally Posted by daMANiack View Post
Hi,
Cheerz
If it works on my '17 F25, then you should be able to work it out. Use the second post which codes TMS modules, that's what you should have if you have LED angel eyes.
      05-18-2018, 05:51 PM   #70
daMANiack
daMANiack's Avatar
Australia
Hi,
I can't find either FLE or TMS ECU's in my 2016 F26 X4.
Does that mean dimming DRL's with turn signals isn't doable?
Cheerz
      05-19-2018, 07:35 AM   #71
stu14t
stu14t's Avatar
Scotland
398
Hi,
Cheerz
Unfortunately, this thread is for FXX series with LED only. There may be a way to do the same on cars with Xenon but that will be done in the FEM module and I'm not sure anyone has tried this yet.
      05-23-2018, 10:58 PM   #72
doodlebro
Drives: '17 X3 35i
I did some digging and found that StandlichtModus1 does not matter at all. StandlichtModus2 does the setting for both extremes of the light switch (All the way to the left & all the way to the right).
I'm trying to figure out how to get my angel eyes to soft on, can we be sure that the other variables are for timeOn and timeOff? It's the last thing my car needs before I can honestly say I've coded everything
      05-23-2018, 11:19 PM   #73
doodlebro
Drives: '17 X3 35i
Well, looks like I confirmed it tonight by screwing around with it.
At least for Welcome Lights 1, I changed the timeOn and timeOff for the angel eyes to 64, which means they take 10 seconds to fully illuminate (Hex 64 = Decimal 100). I'm going to experiment in the coming days with values that get close to the "soft_on_led" timing in the FRM module that controls the other lights.
I'm also going to try and figure out a ramping soft on/off when we program the turn signal DRL dim... I think it's possible but it's going to take a greater understanding of how timeOn and timeOff interact between modes.
All in all I'm super excited as this has been a need of mine for 10+ months. SATISFIED.
      05-24-2018, 11:15 AM   #74
GuMiMoRo
Drives: F31
No, they also dim with xenon headlights... strange why BMW did not put this on F30/F31...
      05-25-2018, 09:45 AM   #75
doodlebro
Drives: '17 X3 35i
Did some more digging. The timeOn and timeOff values for Tagfahrlicht can be adjusted so that when you enable/disable angel eyes, they dim slowly rather than instantly. This also affects when low beams are turned on and controls the dimming, I think it's because Tagfahrlicht has such a high priority (23 hex) that it takes precedence over everything else.
Still can't figure out how to make the angel eyes dim slowly on Blinken... If anyone has insights I'd love to hear them.
      05-25-2018, 12:01 PM   #76
stu14t
stu14t's Avatar
Scotland
398
You may need to make up your own LmmIdxXX (LCI F30 with FLE)
I've not really tried those values but just thinking of some options that may work, if you are just modifying the existing ones. Try using small values in the TimeOn and TimeOff values and also the RampType may also influence speed too (Again small values)
I assumed that priorities worked the other way round, the lower the number the higher the priority (on LCI with FLE modules)
      05-26-2018, 02:14 AM   #77
daMANiack
daMANiack's Avatar
Australia
Hi,
Any idea what settings I can try, I don't have TMS or FLE Ecu's?
Cheerz
      05-26-2018, 03:27 AM   #78
MSport_Jon
Drives: X3 F25 LCI /// F80 M3 (SOLD)
i think the other hex setting control the entry and exit gates delay... I have seen a 2 series active tourer that came with the feature and there is a small delay between when the blinker is activated and deactivated and it makes it look cool. not sure what 64 and 0 represent time wise but as soon as i get a minute i will try modifying these values and determine(hopefully) what these are...
      07-20-2018, 03:18 PM   #79
egrimisu
Drives: BMW 420xd 190HP
Is this possible to code with bimmercode expert mode or I need ISTA?
Do you know what settings do I need for a adapive led f36 2016?
      07-21-2018, 12:28 PM   #80
stu14t
stu14t's Avatar
Scotland
398
It may be possible to code using Bimmercode but it would be much easier using Esys to follow the instructions in this thread.
      07-28-2018, 03:59 PM   #81
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
94
Drives: BMW 320d
I had a F21 today with Xenon, the function of dimming while turn signals was available on this model!
There is NO TMS ECU.
2014, F21.
If someone has the patient, and want to search for answers. I can upload the file.
I just can't find it.... Tried everything.. Even compared but can't seem to find it.
      07-30-2018, 01:22 PM   #82
doodlebro
Drives: '17 X3 35i
2014, F21.
Upload it and I'll have a look when I can.
atzebmw384.50
      07-30-2018, 05:20 PM   #83
atzebmw
Drives: BMW 335XD F30 LCI
I also have to ask now.
My F30 LCI from 07/2015 (german car) with adaptive LEDs has some other values.
I have both FLE ecus and cafd CAFD_000024C3Ö
LM_ID_LT01 F020Wert = 01 LM01 ?
LM_ID_LT02 F020Wert = 02 LM02 ?
LM_ID_LT03 F030Wert = 03 LM03 ?
LM_ID_LT04 F020Wert = 00
LM_ID_LT05 F020Wert = 05
LM_ID_LT06 F020Wert = 06
LM_ID_LT07 F020Wert = 07 LM07 ?
LM_ID_LT08 F020Wert = 08 LM08 ?
LM_ID_LT09 F020Wert = 00
LM_ID_LT10 F020Wert = 00
BLINKEN_Idx
F030Wert
Werte=03, 03, 03, 03, 03, 03, 03, 0F, 03, 03
BLINKEN_PO_Idx
F030Wert
Also i donít find LM01 value.
Next to the LM_ID_LT01-10 i only find LM01_Name.
What should i have to code?
      07-31-2018, 01:56 AM   #84
stu14t
stu14t's Avatar
Scotland
398
I have both FLE ecus and cafd CAFD_000024C3…
BLINKEN_Idx
F030Wert
BLINKEN_PO_Idx
F030Wert
Also i don’t find LM01 value.
Because you have adaptive the mappings to each module will be slightly different to the ones shown previously but the principal should be the same as in THIS POST. You need to find which bit that controls the DRL rings (I suspect it's the same as in the non-adaptive). However, your LmmIdx-- Values are different to non-adaptive and you will need to map out what each value means in the LmmIdx (second excel table in THIS POST.) You may not be able to use 0A for the custom value as it may already be assigned.
Without seeing the CADF or NCD file it's difficult to say exactly but it should be possible.
atzebmw384.50
      07-31-2018, 09:28 AM   #85
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
94
Drives: BMW 320d
Code:
https://mega.nz/#!OQwnTCzD!scF4vLNvqPBiEZUbvAcl9fblpvulKltTmOfugMJ9RrI
Here you go.
I already tried "Depedency and PWM2" codings, didn't do anything.
So I assume it's more than that.
      07-31-2018, 03:17 PM   #86
atzebmw
https://mega.nz/#!VCp2wCgS!aVcotXlSj...Njn6RQC8EE7lNE
I also uploaded my ncd-cafd-file now.
Maybe someone wants to look at it.
Thanks in advance
      08-10-2018, 08:24 AM   #87
donavo
Drives: 440i
i have a 2018 f32 and it does this from the factory....and i want to get rid of it lol. i looked at the codes you guys messed around with and it doesnt change anything for me. i dont want it to dim.
      08-10-2018, 10:52 AM   #88
atzebmw
Maybe you can also upload your ncd/cafd files and we can compare it.
