09-15-2020, 12:15 PM | #111 |
Rep 5,364
Replaced the overflow coolant line on my 2016 M235 with 47K miles last weekend. It was completely fine with absolutely no signs of fatigue. Same thing held true for my OEM charge pipe when I replaced it 4 months ago. Oh well, better safe than sorry I suppose.
I do find it interesting that many people that have these fail have aftermarket intakes. Makes me wonder if some are leaning on the pipe joint when installing intakes.
09-15-2020, 12:21 PM | #112 | |
Rep 7,591
I think some break due to operator error, other's might become brittle more quickly if for example someone lives in a cold climate and they frequently cycle from freezing to boiling temperatures. |
09-21-2020, 07:57 AM | #113 | |||
Rep 10,346
"Drive more, worry less. "
09-21-2020, 10:42 AM | #114 | |
Rep 7,591
New one is the one that is more 'curled' from shipping and has the tag on it. |
F32Fleet3566.00 |
11-29-2020, 07:40 PM | #115 |
Rep 31
My connector just broke off as well. Sorry I didn't see this thread before it happened. 2014 f32 with 80K....
I do have a question, what is the hose running right over top/ next to the connector that is breaking ? |
12-14-2020, 05:53 PM | #116 |
not good, but bad
333
Rep 361
Well mine broke as well and it took the thermostat with it somehow... Funny thing is, I bought the part months ago but never got around to installing it.
After I replaced the above hose, I got a CEL and it was "thermostat stuck open". I topped off the res when I got home and replaced the tube, but I'm guessing the thermostat died because I lost a fair amount of coolant when it cracked, engine temps never went high or anything but maybe that's why it went. Ended replacing the thermostat myself, what a PITA... Seriously, it sucked. I've never had a BMW project where I hit that point of no return and say "do I just pay for someone to do this." The friggin' fan shroud is a mega b*** to remove. You know where to find my blog/DIY if you want to read about my pain.
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
Pussiwillow521.00 |
01-22-2021, 05:33 PM | #118 |
Luxury at the redline :)
9103
Rep 7,563
Well, this coolant tank expansion hose exploded on me a few mins ago, while I just sitting in the car, with the engine still idling, just simple running the heater, when smoke just started bellowing out from the hood, where it left a mess of sprayed coolant all over the engine bay.
However, thanks to this thread, I had bought a backup hose and just kept it in the same garage the first hose blew.. #Irony Valuable head-up here guys, heed the warning and purchase a replacement hose all you N55 owners because trusts me, its eventually going to give up.. Last edited by Poochie; 01-22-2021 at 11:04 PM.. |
QuarterMileJoe9.00 |
01-22-2021, 10:24 PM | #119 |
Rep 285
Drives: 2014 335i 6MT MSport
I've only got 32K miles* on my 2014 but seeing these pics and posts make me pleased that I've got a spare hose in my garage for this eventuality. The unusually-rigid plastic seems doomed to break with time and heat. Maybe I should throw it into the trunk...
*pre-COVID I was traveling 80% and my car would sit in the garage for weeks at a time, and when I do go into the shop it's four miles...
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE 2001 E53 M54 5MT peeling green/black, well-optioned |
01-23-2021, 07:32 AM | #120 |
Rep 35
Guys don't forget the mickey mouse flange, when I replace my overflow hose hse was stilll in good shape but when I remove the mickey mouse flange it felt into piece.
https://f30.bimmerpost.com/forums/sh...hlight=coolant |
Poochie9103.00 QuarterMileJoe9.00 |
01-24-2021, 08:01 PM | #121 | |
Rep 285
Has the OEM coolant pipe been improved, or is the replacement going to break eventually? If so, seems like another opportunity for aftermarket. — off to FCP... what the hell, that's where I get my Volvo 240 parts anyway!
01-25-2021, 08:42 AM | #122 |
Noob
70
Rep 254
Poochie are you saying you've replaced this hose twice now? yikes thats not good news, I just replaced mine before it broke and was hoping this would last a while but I suppose now I should buy another backup lol smh.
FBO, MHD Stage 2+ E20, Xhp Stage 3
01-25-2021, 10:54 AM | #123 |
Rep 643
if you already bought a replacement... i would just go ahead and install it instead of leaving it as 'backup'. you can keep your old one as 'backup'
M235i rwd 6mt
01-29-2021, 03:35 PM | #125 | |
9103
Rep 7,563
In that photo, I just put the old (broken) and new hose together to juxtapose them.. I will concurs with other members that they new OEM hose feels a lot more flexible. The the old pipe, when I was removing the other side that was still attached to the overflow tank, it just crumble into brittle pieces, like the plastic gave up, as I was removing it.. I'm at 4 years and 36,000 miles, so I figure constant heat and cool cycles, give or take, I would say you would need to replace it roughly every 30,000 miles or 3 years.. |
01-30-2021, 02:04 PM | #126 | |
Rep 285
OK, adding that to my weekend project... I'm 32K miles but almost 7 years. I also ordered the aluminum "mickey mouse" fitting from FCP but they sent me the wrong part, so that will have to wait.
02-03-2021, 11:45 AM | #127 | |
9103
Rep 7,563
BTW, the OEM part Number is: 11537598234 It certainly looks like it was the next piece that was on its way out.. Last edited by Poochie; 02-03-2021 at 11:51 AM.. |
03-16-2021, 08:34 PM | #128 |
Rep 161
Another one bites the dust! Mine broke down, got the part and will replace tomorrow. Thanks for all the write-ups.
What do you guys do to wash off all the coolant that splashed everywhere? Also, i wish i saw this post earlier... are there other common issues i should already look into? I have 435i, F32 2014. Thanks! Maz |
03-17-2021, 11:53 AM | #129 | |
Rep 7,591
mazen22226.50 |
03-18-2021, 12:08 PM | #131 |
Rep 7,591
03-22-2021, 10:25 PM | #132 |
Rep 98
Drives: BMW 335i xDrive
Ordered a replacement from Amazon to be safe (335xi, ~57k), and unfortunately it came today and is bent in half with a hard crease...
