11-27-2020, 04:51 PM | #1 |
Rep 37
URO Parts 24118612901PRM Transmission Oil Pan & Filter Kit
anyone using this URO Parts 24118612901PRM Transmission Oil Pan & Filter Kit?
Aluminum with a replaceable filter instead of a plastic one. |
11-27-2020, 04:57 PM | #2 |
Rep 16,082
Considering how often the filter needs replacing I don't see that feature being all that useful. The advantage to aluminum is that it sheds heat, while plastic doesn't, so it should lower the operating temperature of the tranny.
airwolf090.00 |
11-28-2020, 04:16 AM | #3 |
Rep 160
And takes longer to warm up the oil. Unless you suffer from temperature issues with the gearbox, I don’t see any advantage of this aluminium pan over the plastic one. Indeed when you replace the oil, usually you replace the pan as well, since it has an integrated filter. It’s not too expensive as well (plastic one)
11-28-2020, 05:34 AM | #4 |
Rep 172
Drives: 2015 328i
Just to chime in, URO has been absolute garbage for Mercedes, probably BMW, too.
