BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > HELP! coding cruise control removed HBA
proTUNING Freaks
      11-29-2020, 07:58 AM   #1
veyslaurens
Belgium
Drives: F31 320i
Hello,
I'm new to this forum. Today, after a lot of research, I found the courage to do my first VO coding. I had the LIM function and changed this with the cruise control buttons. I started up esys and added 544 to the VO. I didn't write this to the car but to a different file. I then opened this file in the coding section, activated fa and coded the FEM body, ICM and KOMBI ECU's.
Cruise control is working fine but my High Beam Assist is gone and the lights also don't move with the steering wheel input.
I really don't know what I did wrong as I tought the coding would only change parameters regarding to the added VO?
All the help is greatly appreciated!
      11-29-2020, 10:52 AM   #2
atzebmw
Drives: Tesla Model 3
That doesn't really make sense because the two things have nothing to do with each other.
But did you happen to remove the 5AC when you added the 544?
      11-29-2020, 10:57 AM   #3
veyslaurens
Belgium
Drives: F31 320i
Hi,
This is the same thing as I tought. I checked the FA list and everything was still there.
I just left the car sitting for a bit and it seems that the functionality is back. I can again enable the high beam assist, but I was not able to see in action again, I think it wasn't dark enough.
It's really weird but it seems to have fixed itself.
      11-29-2020, 11:05 AM   #4
atzebmw
Yes, that could happen sometimes.
Many error messages appear, especially when coding the ICM.
But after switching the ignition off and on again, everything should work normally again.
And yes, sometimes you have to let the car sleep for half an hour or so.
      11-29-2020, 11:07 AM   #5
veyslaurens
Belgium
Drives: F31 320i
Thank you for your reply!
I hope everything will work as before but as of now is seems like it is😌
      11-29-2020, 11:12 AM   #6
atzebmw
That's great.
Hopefully you haven't lost the joy of coding now.
      11-29-2020, 11:13 AM   #7
veyslaurens
Belgium
Drives: F31 320i
That's great.
I must admit, it's a really scary process😬
