BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > What did you do to your F3X today?
proTUNING Freaks
      12-05-2024, 10:25 PM   #15115
co_440i
Drives: 440i
Installed a dry carbon stereo trim (got on amazon from a China seller and the quality is actually pretty good) and wrapped my dash trim in carbon fiber vinyl
      12-06-2024, 02:23 AM   #15116
plsdntrply
____________
plsdntrply's Avatar
128
Drives: 2018 330i xDrive Wagon
got my car back from pnw race tonight. with it nearing 60k miles, they fully serviced it, changing filters, fluids, and spark plugs. i also had them install 12mm traklite spacers, a cts turbo charge pipe upgrade, an afe power momentum gt cold air intake, and an afe power dynamic air scoop. additionally, they sent my dme to kies for unlocking. huge thanks to stefan and paxton at pnw race for their help. tomorrow, i’ll set up bootmod3 and xhp.
Appreciate 6
_ObiJon404.00
WagonHo704.00
co_440i214.50
toxik2959.50
      12-06-2024, 09:26 AM   #15117
moppity
moppity's Avatar
154
Drives: 340i Touring
Not exactly done yet, but WIP come spring (19" 442Ms going up for sale &#128075
sbst0.00
jnj2455435.00
      12-06-2024, 11:34 AM   #15118
pnwwagon
Drives: 2019 F31 AW MSport
How did you end up with a locked dme on a 2018?
I just did bootmod3 over Thanksgiving and really like it so far.
I'm over in Kitsap and have been happy with MaxRPM, but good to know of other good performance shops.
      12-06-2024, 01:19 PM   #15119
_ObiJon
_ObiJon's Avatar
Drives: 2017 440ix F36
My 2017 DME is locked also. Apparently, if you've been to a dealership recently for certain services, they've been locking them. From what I've read.
      12-06-2024, 02:01 PM   #15120
Skyhigh
Skyhigh's Avatar
2055
Drives: BMW F36
Correct. In the US only though, not in Europe.
      12-06-2024, 02:04 PM   #15121
pnwwagon
Wow - glad I lucked out
      12-06-2024, 02:10 PM   #15122
toxik
toxik's Avatar
Drives: 2017 340i xDrive 6MT
anytime in the last 3 years that a dealer updated a car’s istep version, they would also lock the DME. they’d do this while you’re there for other services too.
i think i read that 2018s came locked from factory, but I couldn’t verify that.
      12-07-2024, 09:07 AM   #15123
Tatanka1961
Drives: BMW 430i F33
Upgraded my Soundsystem
Although I have the HK sound system, I felt it was lacking. So I decided to upgrade all speakers & Subwoofers.
Even though BMW charge a hefty supplement for the HK System, the quality still has a lot to be desired.
I didn't want to buy a specific BMW upgrade set, as they are also overpriced imo (as are most brand-specific upgrades)
So I went for Focal speakers as I have very positive experience with this brand. I designed (& 3D printed) some adapters for the subs and speakers to fit in the original locations, which turned out to be quite the challenge due to the limited space.
While everything was disassembled, I used the opportunity to install soudproofing to the doors and panels:
The end result was better than I expected. The sound is much deeper and more detailed even with original amp. Personally, I don't feel the need to upgrade the amp as it's more than enough for me.
It took many hours to design the adapters and install everything, but the result was well worth it!
co_440i214.50
Dagstar440.00
      12-07-2024, 12:06 PM   #15124
dunsmod
dunsmod's Avatar
Drives: F31 320D
Washed it, checked it over using ISTA👍
      12-07-2024, 12:07 PM   #15125
dunsmod
dunsmod's Avatar
Drives: F31 320D
Also taken front two wheels off ready to put non run flats on, to match up with rear 😄
      12-07-2024, 03:35 PM   #15126
thatgarrett
thatgarrett's Avatar
Drives: 2012 335i Sport
2012 BMW 335i  [8.58]
Did spark plugs, not bad for 60k miles on them, all were still between 0.030-0.032! Honestly this took more time and effort because of those stubborn coils than the CV axle I swapped on my Forester just before doing this! But wasn’t a bad job overall. Noticed a slight leak at the rear of the valve cover, which is honestly a huge relief as I noticed some oil that was leaking down the back of the engine head the rear main seal and I was hoping it wasn’t that. Couldn’t see it until the cowl cover and all of that stuff was removed though. Once it gets warmer I’ll likely swap the gasket and cover since it’s original and has 12 years and 120k on it
Now, time to tune!
      12-08-2024, 11:11 AM   #15127
amancuso_
Drives: Z3 3.0i 330iT M3 740i
Washed it and went on a little drive. It has been sitting at the back of the driveway for about a month since we picked up our i4.
Appreciate 6
toxik2959.50
Boznien453.00
jnj2455435.00
co_440i214.50
      12-08-2024, 05:37 PM   #15128
disintegrator66
disintegrator66's Avatar
Drives: '18 340i M-Sport 6MT THP MPPSK
Originally Posted by disintegrator66 View Post
Pre-hibernation wash after filling up the gas tank. Need to burn off the rotor rust, detail the wheels and then she'll be ready for 5 months of slumber......
Wheels & body detailed w/Griots Speed Shine, battery tender connected and car covered..... See you in April........
toxik2959.50
co_440i214.50
moppity154.00
Dagstar440.00
      12-08-2024, 05:42 PM   #15129
Alarbus
Drives: '15 F30 & '19 F36
My first 2019 440xi GC was not locked. The replacement 2019 440xi GC has a locked DME. First one started in NJ and ended up in PA, second one started in NJ but went to AZ for a while, and ended up back in NJ. No idea.
I did wash and wax the 335 today, I wasn't expecting to be driving it in December, but a deer hit the 440 and it's still at the shop. =/
(Yes, the deer hit me. The fucker.)
      12-10-2024, 01:27 AM   #15130
Onizukachan
Great Teacher
Onizukachan's Avatar
1770
Drives: 06 E91ix & ‘15 F31d
2015 F31 328d  [0.00]
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
Bought it back and drove it home from LA to El Paso on a tank and a half of diesel.
500+ miles between fuel stops is a whole new level of endurance driving.
‘06 E91 manual 325ix BarriqueRot
over Terra (one of 1)
‘15 F31 320dx M-Sport Mineralgrau
over Black (one of 94)
Appreciate 6
Boznien453.00
co_440i214.50
krith158.00
      12-10-2024, 07:55 PM   #15131
pnwwagon
I love your wheel choices on both of those. And the color of that E91 - damn.
      12-10-2024, 09:30 PM   #15132
Onizukachan
Great Teacher
1770
Thanks! She’s the only XI manual trans in that interior + exterior color combo.
      12-11-2024, 02:25 AM   #15133
space_2001
space_2001's Avatar
197
Drives: F80 M3, E46 M3, G30 M550i
2014 BMW 328ix  [9.50]
2018 BMW M3 ZCP  [10.00]
Finally cleaned my new coupe.
co_440i214.50
Boznien453.00
      12-12-2024, 10:03 PM   #15134
thatgarrett
Have about a week of driving after my tune and have some initial thoughts:
N55 PWG MHD Stage 1 91 Octane
-I was surprised by how much harder it pulls, especially in sport mode. Very noticeable shove and I can really feel the boost come on- it’s still very smooth and not really laggy but when I floor it I can feel the shove come on and stay on.
-I was surprised by the additional torque- I could easily do a burnout (not that I was in the habit of roasting my nice tires mind you) from a standstill, but I can floor it while going 30-40 mph and the DSC has to step in a bunch, so it breaks traction way easier. There’s also a few roads I frequent that if I stomp on it on a straightaway I would get up to 60 or so and now it’ll get up to mid 80s (and that’s with me backing off it earlier than I used too). When pulling a log on the interstate I substantially passed my previous top speed accidentally too- all that to say, it’s really woken up the car.
-Maybe my favorite change is in comfort mode though- I read a few threads where the car feels lighter and peppier overall, and I’d have to agree. It’s not twitchy or jumpy, but it goes with less provoking (but not in a throttle tuning way, just an extra torque way). Very smooth on and off throttle transitions, and I would say that the shifting feels smoother too at all speeds
-But the biggest plus is what it did to my exhaust- I have an M2 Axleback on, and I have loved it- but, with an 8AT the engine likes to sit really low and almost lug itself when cruising around town for the MPG (low RPM with a higher load). If you listen with a stock exhaust, you can barely notice it. You notice it more with the valve opened on the stock one too. On the M2, it was noticeable when going up hills in the 55-65mph range more, never droned or made unpleasant noises otherwise. But with the tune, that lugging characteristic is either gone or vastly diminished and the exhaust feels pretty much as quiet as stock at those speeds and conditions now, and still opens up and sounds nice when flooring it, crushing in sport, or with the transmission in S to let the OEM burbles do their thing.
I think the exhaust refinement alone was worth the money for me, but overall I have been very impressed with what just Stage 1 has done, and a conservative octane level at that. I just have an ER CP on right now, but my next move is an IC, and after that I’ll probably go up to Stage 2, looking forward to seeing that difference too!
Boznien453.00
      12-13-2024, 10:11 PM   #15135
Jetboater
Drives: BMW 640GT, 440ix vert, X3
Car cover
Like your car cover—looks like it fits like a glove,
I’m looking for one—what brand is it?
Thanks!
      12-14-2024, 12:17 AM   #15136
eff32fl
eff32fl's Avatar
1286
Drives: 2019 440i M Sport THP MPPSK
Nice ride! Not usually a fan of silver/chrome accents but the silver kidney grills really works with that color. I think the 20's help make it balance out.
