BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Lane change warning failure after coding F36
proTUNING Freaks
      10-12-2023, 09:36 AM   #1
StefanAnton
StefanAnton's Avatar
Romania
Drives: Bmw G30 540I
I have done some codind with Vgate trough BimmerCode and now after a few minutes driving it shows me this and it deactivates the button. It also disables cruise control and I think the blind assist(i am not sure). If i press the button it works again for some time.
Can you guys please help me to reverse what I have done?
I have wrote most of the coding, I attached the picture.
      10-12-2023, 06:56 PM   #2
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
What are your error codes?
      10-12-2023, 09:20 PM   #3
eff32fl
eff32fl's Avatar
1284
Drives: 2019 440i M Sport THP MPPSK
Bimmercode backs up each module before applying the coding. Restore the backup for I'd assume FEM and see if that fixes it.
      10-13-2023, 04:58 AM   #4
StefanAnton
Romania
Those
      10-14-2023, 03:14 PM   #5
fe7565
fe7565's Avatar
If you cannot undo your coding as suggested above, may want to check with ISTA+ the actual BMW specific error codes, as they not only provide better details but also suggest a fix.
The error codes you posted are hard to make out, but seems like your radar sensors and the (associated?) LIN signal in the side mirror have issues. Do you have Lane Change Warning? Was it working before? It is working now or only at times? Does your warning triangle in the mirror(s) work? Can you check (example: with Bimmercode), if your LIN-options coding for your mirrors is correct for your car?
      10-14-2023, 03:28 PM   #6
StefanAnton
Romania
I resolved the problem. I coded the blind spot assist to start at 10 km/h and that seemd to be the problem.
Thanks!
      12-12-2024, 05:20 PM   #7
Izz
Izz's Avatar
Drives: BMW F82
Thanks!
What did you change it back to? Having the same issue after coding it to that
      01-07-2025, 03:46 PM   #8
StefanAnton
Romania
I ran the backup like somebody said above and it solved the problem.
