08-04-2024, 11:36 PM | #1 |
Rep 9
Battery Discharging While Stopped
Hello Beamer community.
Some background before I even start with the issue that started happening with my car: Purchased a 2014 BMW 335i in 2017, never had issues. A couple months ago when I went to turn on my car, a message popped up on the display which said, "Battery Discharging While Stopped". I asked the mechanic that I have taken my car to since I have gotten it, and he said to come in. There weren't any faults that showed up so I figured that I just needed a new battery (keep in mind, I have never had it replaced). I went to the BMW dealership in my area, and purchased a new battery. Got it installed, and registered with the vehicle, and there were no issues for a few weeks... I woke up one morning to head to work, and I noticed that when I put my hand on the handle, the door knobs barely went up, and then my alarm started BLASTING. I quickly tried to turn the alarm off by pressing every button on my key fob, but no luck. The alarm eventually stopped so I tried to turn on my car and absolutely nothing worked. My wipers started going for some random reason, my bluetooth turned on for 5 seconds and then turned off. I have resorted to jumping my vehicle 2 times in the last week in order to get to work, and every morning I get the message saying that there was a battery discharge. Do you guys have any ideas on how I can figure out what is draining this brand new battery? I am at a loss. |
08-04-2024, 11:38 PM | #2 |
Rep 9
EDIT: I had my mechanic look at the car last night, and there was under voltage detected in the roof function center. I'm assuming that is the sun roof in the car?
08-05-2024, 10:18 AM | #4 |
Rep 716
My 2012 F30 335i started to have the same issue around 3 years ago. In my case, it's very sporadic. It happened in October 2023 and everything was fine until this weekend. The battery has been dead two days in a row (Saturday and Sunday).
I already took the car to 2 different shops and they could not find an explanation. They asked me to bring the car when the issue is happening. I plan to do that sometime soon since the problem is back. Luckily I have an extra car that I can drive for now. |
Ermin3353.00 |
08-05-2024, 12:54 PM | #5 |
Rep 9
Ahhh got it, thanks. I was thinking about switiching out the FEM module, but don’t want to spend the money yet since the issue hasn’t been pinpointed
08-05-2024, 12:57 PM | #6 | |
Rep 9
Hopefully we can both find out what’s going on with our cars |
08-05-2024, 09:14 PM | #8 |
Rep 1,644
More than likely parasitic discharge. I had a similar issue and traced to the water pump electronic module (on top of the pump assembly). Pump was continuing to run after the normal 5 min period when the car electronics are suppose to go to "sleep". I could see the drain continuing after that time via my multi-meter and finally traced it to the pump (could hear it still running).
08-06-2024, 12:00 AM | #9 | |
Rep 716
1 ) At 8 AM, the warning "battery discharging while stopped" showed but car still started fine. Drove 10 miles to work. 2 ) At 5 PM, the car started fine. I remember the same warning showed again. Drove 10 miles back home. 3 ) At 6 PM, the battery was totally dead. I needed to use my jump pack. |
08-06-2024, 01:40 AM | #10 | |
Rep 9
08-06-2024, 01:43 AM | #11 | |
Rep 9
Not a mechanic so don’t take my word for it |
wilbur_the_goose362.50 |
08-06-2024, 08:09 AM | #12 |
Rep 17,077
A must have. When the engine isn't running it shows the battery state of charge. When it is running it shows the alternator output. Mine is always plugged in to my console socket.
https://www.amazon.com/Battery-Charg...%2C102&sr=1-27 |
Ermin3353.00 |
08-06-2024, 04:00 PM | #13 | |
Rep 716
I compared the results when the engine is not running between my 335i (which has the issue) and my wife's 2011 X3: 335i = 10.20 volts, red indicator X3 = 12.06 volts, yellow indicator |
08-06-2024, 05:28 PM | #14 |
Rep 17,077
It would only discharge the battery if the power to the outlet remained on with the engine off. It does stay on for about five minutes after the car has been locked, ten minutes or so if the engine is shut off but the car isn't locked.
10.2 volts indicates the battery is at only 10% charge. I'd be surprised if the car would start. If you fully charge the battery after a long drive it should show at least 12.5v when you turn the engine off. If it drops to 10.2v either something is draining the battery or the battery is toast. You can check that by fully charging the battery and then disconnecting the battery negative terminal, so nothing can drain it. If it's down the next morning you know it's the battery. If not it's something else. 12.06 volts is 60% charge, which is probably OK, but you don't want to see it going much lower. |
Fredo327.00 |
08-06-2024, 07:42 PM | #15 | |
Rep 716
08-20-2024, 01:45 PM | #16 |
Rep 716
Two weeks ago, my battery was dead on 2 consecutive days. I stopped driving the car at that point. I checked the battery last week and it had only 8 volts. I assumed my jump pack was not going to work so I bought a CTEK MXS 5.0 Battery Charger & Maintainer on Amazon.
I connected the CTEK on Friday night and the car started fine on Saturday morning. It appears to be ok for now. My plan was to bring the car to the shop on Monday morning for troubleshooting, but now that makes no sense because the issue is gone. I will continue to monitor the battery while the car is parked in the garage. |
08-20-2024, 03:45 PM | #17 |
Rep 364
Last winter I had an issue with an E83 X3. In my case, if I didn't start it for a few days it would be weak starting. A week and it would no longer start. I was bringing it into the dealer for other reasons, so I thought I'd have them check the electrical system. They had a device that they plugged into the car that monitored all kinds of things over time. In my case, the combox was waking up every 20 minutes with high current draw for a short time and then would go back to sleep. This was even when the car was supposedly in it's lowest power state. $250 flat charge at my dealer. I never would have found that and I'm a decent diagnostician.
1986 Delphin 528e - Roof rack equipped lumber hauler.
2008 Platinum-Beige X3 3.0si - Current project 2012 Alpine White X3 xDrive35i - My new snowmobile. 2020 Estoril Blue 440i xDrive cabrio w/MPPSK - This car is a blast to drive. |
08-20-2024, 03:58 PM | #18 | |
Rep 9
I might follow in your footsteps and take my car to the local dealer to see if they could find the issue. |
Fredo327.00 |
11-11-2024, 06:28 PM | #19 | |
Rep 8
My friend, I have the same problem as yours right now, after turning off and closing the doors, the water pump works and turns off and I can hear it. I remove the negative clamp every night so that my battery does not run out. Did you replace the water pump and the problem was solved? I'm not sure if it's the water pump, could it be the sensor or something else? Please share your experience with us. |
11-11-2024, 10:57 PM | #20 |
Rep 1,644
In my case, it was the electronic module that is part of the water pump assembly. It was running the pump long after the 5 min window after which the car "goes to sleep". I could watch the discharge on my meter as I was listening to the pump continue to run.
11-13-2024, 07:12 AM | #21 | |
Rep 8
Thank you for the advice. |
Fredo327.00 |
11-13-2024, 09:35 AM | #22 |
Rep 17,077
Before you pay to have the water pump replaced see if you're covered by the water pump recall. https://www.caranddriver.com/news/a6...e-risk-recall/
Fredo327.00 |
