BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 6WB upgrade worth it?
      12-08-2024, 11:04 AM   #1
amancuso_
Drives: Z3 3.0i 330iT M3 740i
Been thinking about upgrading the cluster in my F31 recently, but the $2K sticker price seems like a lot for a mostly aesthetic upgrade. My car has the base cluster, but I already upgraded the infotainment to the NBT EVO 6 NAV upgrade which wasn't cheap either. Should I take the plunge or nah?
      12-08-2024, 11:11 AM   #2
eff32fl
eff32fl's Avatar
1286
Drives: 2019 440i M Sport THP MPPSK
Do it. I love the 6WB makes the interior look much more modern. Plus if you drive in Sport/+ mode the display stays red and doesn't turn amber at night like the analog cluster. You can get a used one for around 1k.
Skyhigh2054.50
      12-08-2024, 12:22 PM   #3
im_an_alien
im_an_alien's Avatar
1354
Drives: 2016 340i
Wasn't long ago that the brand new ones were 1k
      12-08-2024, 02:54 PM   #4
space_2001
space_2001's Avatar
197
Drives: F80 M3, E46 M3, G30 M550i
2014 BMW 328ix  [9.50]
2018 BMW M3 ZCP  [10.00]
I would just swap gauge faces. I love analog gauges and these look so much better when you change out the faces.
I’ve gotten the Venoxy ones and I like them on both of my cars. They also have more colors to chose. Although you’ll need some patience for install.
Here are some pics:
      12-08-2024, 03:52 PM   #5
amancuso_
Here are some pics:
You have the 6WA, I have the base. I can't get any nav instruction on the screen, and the lag time when changing radio stations is annoying. I don't think the base cluster was made to interface with the NBT EVO6 infotainment system.
      12-08-2024, 04:20 PM   #6
eff32fl
eff32fl's Avatar
1286
I believe you are correct. I've only seen later models with 6WA or 6WB. The digital portion of the base screen appears to only be for basic car status messages.
      12-08-2024, 05:12 PM   #7
Wires
Drives: 2016 340i xDrive
Lets be honest, how often does one actually look at the gauges? I'll glance at the tach on occasion, speed comes from the HUD.
For me, it isn't worth it to make it look more modern.
Billfitz8889.00
      12-08-2024, 09:37 PM   #8
space_2001
space_2001's Avatar
197
That’s fair lol, unfortunately I have no HUD so I HAVE to look at my gauges.
      12-09-2024, 09:02 AM   #9
Wires
Ridiculous! You have a BMW. I thought we didn't need to observe speeds, signal, park across lines, etc?!?!
      12-09-2024, 09:07 AM   #10
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Not with one of these: https://www.amazon.com/Yaouzicn-Cons...zcF9hdGY&psc=1
      12-09-2024, 09:14 AM   #11
Skyhigh
Skyhigh's Avatar
2055
Drives: BMW F36
6WB is definitely worth it. It was on my "must-have" list when buying the car as well. Makes a huge difference in modernising the cockpit. From the good old orange analogue clusters from the 80s straight to 2020 (or at least 2010, if you compare to Audi).
This said, its functionality is pretty limited when compared to e.g. Audi's Virtual Cockpit. Still worth it nevertheless.
And I do have a HUD as well, but it is also so limited in functionality that it does not replace an instrument cluster. I can happily live without it, but not without the fully digital cluster.
      12-09-2024, 04:34 PM   #12
oshrizak
Drives: 2015 BMW 328D
A bit off topic here but since there are a bunch of guides out for NBT to EVO do you mind sharing which one you used? Did you have to upgrade from TCB. To ATM?
      12-10-2024, 03:26 PM   #13
Solenoidal
Drives: 2017 BMW 440i Gran Coupe
I have the 6WB and HUD. I wouldn't have it any other way. The dials make it so much more modernised inside compared to the analogue dials.
Like someone mentioned above, the HUD is pretty basic in terms of functionality, just displays speed, cruise control information, speed limit signs (if you have the sensor), directions (if using stock bmw navigation) and media control.
I just wished it would display the directions if using Waze or Google Maps via Apple CarPlay.
2017 440i F36 LCI - Individual Ferrari Red | ZF8 | M Sport Plus | HUD | Icon Adaptive Headlights | Driving Assistant | Digital Dash | Sunroof | Comfort Access
      12-10-2024, 05:00 PM   #14
Skyhigh
Skyhigh's Avatar
2055
Drives: BMW F36
It has a compass too, if you code it in that‘s an increase of functionality by 20%
But seriously - 6WB changes the interior big time!
      12-10-2024, 08:42 PM   #15
Djphonics
Drives: MK7 GSW - E91 - 5th gen VFR
I've got the 6wb, and disabled the sport mode in it to keep the gauges 'analog'
The center screen only shows a car when you're too close to another car, but is otherwise a screen of nothingness.
It also drives me nuts that there are two fuel gauges on it. The standard 'analog' gauge, and then the gauge under the speedo. You can also add the 'countdown' in the middle for the ultimate trifecta of fuel level information.
I'd miss it because I am used to it, but I wouldn't pay to 'upgrade' to it. BAVMODS does a knockoff of the newer cluster that I'd suggest if you want to modernise the cabin.
      12-11-2024, 06:57 AM   #16
Skyhigh
Skyhigh's Avatar
2055
Drives: BMW F36
You do realise that one is a fuel gauge, the other a range gauge, right? Not the same thing at all….
      12-11-2024, 08:01 AM   #17
Runner340
Runner340's Avatar
381
Drives: F30 340i xDrive
I upgraded to the 6WB cluster because it's backlit during the day where the 6WA is only backlit when the headlights are on. I have no idea why BMW choose not to backlight the 6WA for daytime driving. Sunlight glare or while wearing dark sunglasses the 6WA cluster gauges don't show up well. As an added bonus the 6WB does have a more modern look. One of my favorite upgrades.
BMWCCA Member #132862
Prak903216.00
      12-11-2024, 10:02 AM   #18
amancuso_
I paid the $$$ and used Bimmer-tech. ConnectedDrive works, but I can't get RTTI because of the combox. Use Apple CarPlay for traffic anyways.
      12-11-2024, 10:05 AM   #19
amancuso_
I have had experience with "aftermarket" components and do not feel they offer the same stability and reliability as factory components. Maybe the 6WA might be the way to go at a lower cost. I had that in my previous 4 series cars and had absolutely no problem with them. The base cluster is just so slow/lagging response time when navigating through the menus/media.
      12-12-2024, 01:56 AM   #20
tturedraider
tturedraider's Avatar
Drives: 2018 340i M Sport
Well, I’ll just start out saying I’m an old fart and I prefer iconic BMW with as much analog as is reasonable. I’m not totally against “digital” when it actually adds worthwhile functionality. But, I don’t think the 6WB is worth it at all. The fact of the matter is it will eventually fail and have to be replaced. I have the Executive pkg, so I have it, but if I had the choice I would have analog gauges. Yes, I know the analog gauges are run electronically. Fortunately it hasn’t happened to me with my current 2018 F30, but on my first 2018 F30 with the Executive pkg the 6WB went black on me at least three times and possibly four during the 21 months I had that car. It never lasted more than a few seconds, but it’s unnerving when it happens, especially at night. I think it’s pointless and just adds something expensive to fail and require replacement.
https://youtu.be/-ay-8p2p29w
www.bmwcca.org
member #388003 - Use me as a referral
& you could win a one day ///M Driving School!!
___________________________________________
Wires1973.00
      12-12-2024, 05:19 AM   #21
Skyhigh
Skyhigh's Avatar
2055
Drives: BMW F36
«It will fail» is the most bizarre logic I often read for not getting (meaningful) extras on a car. That you don’t find it meaningful is a separate thing.
Everything fails eventually, including your engine, gearbox, windshield wipers and HiFi. Do you not have an Aircon because it will fail?
Since I am involved with avionics, I can tell you that components whose function is essential are designed to have a Mean Time Between Failure (MTBF) as high as possible. This is also why they are so expensive to srart with. Which doesn’t mean they don’t fail, ever. Just rest assured that there is a good reason why an instrument cluster from Ali Express costs a fraction. It will last a fraction.
      12-12-2024, 08:14 AM   #22
Wires
Being in the electronics industry, I can guarantee that the reason the 6WB is expensive is because people will pay the price tag if they want the feature. That price has zero to do with it being designed to be reliable.
There is zero risk that if the dash went dark that you would die driving -- it's just an annoyance. Fully different paradigm than the aviation industry where the bird can fall from the sky if a critical item fails.
Our Audi has the full virtual cockpit. It looks awesome (better than BMWs implementation BTW since it is basically a screen that can toggle between Nav maps, gauges, etc. into different layouts.) But to tturedraider's point, I cringe with the thought when it is no longer being produced as a replacement part and it fails.
