BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Charging module
proTUNING Freaks
      12-12-2024, 12:37 PM   #1
Ruster82
England
30
Drives: 2011 320d Efficient Dynamics
Charging module
My dad has a 2012 320d efficient dynamics with a charging fault that has been to a garage. They believe it is charging module fault but told him it needs to go to BMW.
My question is does the charging module need to be programmed to the car or can I just buy one and fit it to see if they are right?
      12-13-2024, 02:55 AM   #2
Ruster82
England
30
Is there even a charging module? I am finding it hard to get any info. Possibly they mean the power module?
      12-13-2024, 09:29 AM   #3
Wires
Drives: 2016 340i xDrive
What do you mean by a "charging fault"? The car will adjust the alternator charge and typically maintains a 70-80% battery charge, allowing the efficiency dynamics to take it higher when coasting.
      12-13-2024, 09:35 AM   #4
Ruster82
England
30
It is saying:
"Increased battery discharge when stationary"
"Electrical consumers were temporarily switched off"
I have tried searching and it is not the usual water pump or dash board etc. I caved and got it taken to a garage under warranty.
They said they are 90% sure it is the charging module but I would need to take it to BMW to know for sure.
The battery died after 3 days so it has had a new battery to eliminate that as an issue, but i am still getting the warning.
      12-13-2024, 01:35 PM   #5
Wires
That is telling you that there is something that is draining current when it shouldn't be.
My car used to do that when it was stupid cold outside and it was the iDrive. There was a SW update that fixed that for me, but it was also mentioning "iDrive running when the car is off".
You'd need to find what is causing a high current drain when the key is off.
      12-13-2024, 03:15 PM   #6
richardodn
Drives: '12 X3 35iX/'20 440ix cabrio
Note that you can also get that error on a marginal battery. I started seeing that message one winter when I would come out on a cold morning. The cold temps would reduce the battery voltage too low and the computer would think there was something draining it while off. Eliminate the battery as an issue before you start swapping out parts.
1986 Delphin 528e - Roof rack equipped lumber hauler.
2008 Platinum-Beige X3 3.0si - Current project
2012 Alpine White X3 xDrive35i - My new snowmobile.
2020 Estoril Blue 440i xDrive cabrio w/MPPSK - This car is a blast to drive.
Wires1968.50
      12-14-2024, 04:35 AM   #7
Ruster82
England
30
Yes it is a parasitic drain and the battery is new but the garage said it was the "Battery charging module" my issue is i can find no info on where this is in the car.
Any search i do just brings up a "power module" not sure if this is what they meant or where that even is. So many modules on this car.
      12-14-2024, 06:25 AM   #8
Ruster82
England
30
Paracitic drain
My Foxwell 530plus arrived today. I read and cleared codes these are what comes back instantly.
Front electronic module FEM:
804124 - Permanent - Outside door handle electronics, front passenger door: Short circuit of DAT line to earth.
804246 - Permanent - Exterior mirror, left: Exterior mirror heating or electrochromic left faulty.
Rear electronic module REM:
0301A0 - Permanent - Window regulator on passenger side door, rear: System is not normalised.
Looking at these I think the rear regulator might just need resetting, the mirror glass replacing but the door handle is most likely to be my battery drain issue.
Anyone had this before? is it fixable or is it a new door handle?
Can i just pull the fuse to test the drain stops before paying out for a handle? If so which fuse is it?
      12-15-2024, 06:33 AM   #9
Ruster82
England
30
Just an update for anyone with the same issue i unplugged the comfort access door handle and the battery didn't drain over night so problem solved. New handle needed is the correct solve for me.
Thanks to all.
Wires1968.50
