      11-18-2024, 08:20 PM   #16919
wo335
wo335's Avatar
Drives: 2014 BMW F30 335i RWD
Hi Shawn, would you be able to share the link to PSdZData? Thanks!
2014 F30 335i MPPK RWD EWG, IC, DP, CP
Black Sapphire Metallic with M Performance Carbon mirror caps & boot lid
Continental SportContact 7
      11-19-2024, 07:59 AM   #16920
shawnsheridan
shawnsheridan's Avatar
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      12-08-2024, 12:05 PM   #16921
Harunlee
Drives: bme f30
ı from turkey. n11 buy enet. I ordered to test.
      12-08-2024, 12:11 PM   #16922
shawnsheridan
      12-10-2024, 05:00 AM   #16923
llSimsll
Drives: 320d F31
Possible to share e-sys and needed files to code a F31? Im trying to enable footwell light, this is not standard in my case.
      12-10-2024, 01:15 PM   #16924
shawnsheridan
PM sent.
      12-13-2024, 09:24 PM   #16925
memo651
Drives: BMW F10
Hello Shawn, can you send me the newest file-link for PSdZData (full)? Thank you!
      12-14-2024, 12:26 AM   #16926
shawnsheridan
PM sent.
      12-24-2024, 10:51 AM   #16927
pantsos
Drives: 328i Xdrive
Hello,
Can I please have the files as well?
Thank you
      01-08-2025, 10:10 AM   #16928
moddmw
Drives: 2015 BMW 428i
Hello, my private message functionality is not enabled yet, I will message again when it is enabled. Had a quick question.
I have a 2015 F36, what version of PSdZData should I use ?
      01-08-2025, 10:20 AM   #16929
shawnsheridan
Originally Posted by pantsos View Post
Hello,
Thank you
PM sent.
      01-08-2025, 10:20 AM   #16930
shawnsheridan
Use latest v.4.50.40_PSdZData.
      01-11-2025, 11:53 AM   #16931
genio7781
Drives: BMW 335DX
F30 Removed 524 Adaptive Headlight from VO now errors
Hi,
I have after market headlights which were plug and play direct swap with no issues. The only error I had was adaptive led headlight failure as they were no longer adaptive like the originals. I used my scanning tool (bit more than just a scanner) to remove number 524, adaptive headlight out of the cars vehicle order. As that was shown to be the fix to remove the error popping up. Now it doesn't recgonise my headlights what so ever despite them working. Still have day time running lights, dipped beams, full beams. Indicators now flash fast on the front as if they have a failure like most indicators when there is an issue. which is the most annoying at the moment but it tells be both dipped headlights failure, both full beams and both indicators (plus high beam assist no longer works). Do I need to just code back in the 524 into my VO or something anyone can recommend? Thank you
      01-11-2025, 12:12 PM   #16932
shawnsheridan
Originally Posted by genio7781 View Post
Hi,
I really have no idea on Aftermarket hardware. On normal OEM hardware, you can remove 524 the Adaptive Fucntion Coding so long as car is still coded for Head Light, such as 522 Xenon Light. I also have no idea on Scanning Tool, but any FA Change requires VO coding affecting Modules afterward.
      01-12-2025, 12:47 PM   #16933
genio7781
Drives: BMW 335DX
Thanks Shawn, do you think it would be worth to flash/reset everything back to normal (I've not actually made any changes other than this) It's possible the car did a full recode based on this and appears that it no longer thinks any headlight modules are equipped or files found while scanning
If so would I need the full PSdZData or lite?
      01-12-2025, 12:55 PM   #16934
shawnsheridan
I really do not know exactly what you have done, so I have no idea. Coding can be done with psdzdata Lite. Flashing requires psdzdata Full. That said, I don't see how flashing an aftermarket light module with OEM firmware would be applicable, but I could be wrong.
      01-14-2025, 04:59 AM   #16935
genio7781
Drives: BMW 335DX
I've followed this
. With same tool. The aftermarket light was a direct plug and play so worked on the OEM firmware, no coding or anything required. That is why I was thinking reinstating the OEM firmware and setting the FA back to what it was before I did this change could work
      01-14-2025, 08:11 AM   #16936
shawnsheridan
I've followed this...With same tool. The aftermarket light was a direct plug and play so worked on the OEM firmware, no coding or anything required. That is why I was thinking reinstating the OEM firmware and setting the FA back to what it was before I did this change could work
Try it. It can't hurt.
      01-15-2025, 05:42 AM   #16937
genio7781
Drives: BMW 335DX
Thank you, I know its a random question and no one really knows. Appreciate your time and responses on this. As you can tell I'm new!
      01-19-2025, 06:39 PM   #16938
klex545
klex545's Avatar
France
Drives: F31
Hello shawnsheridan ,
I need old psdzdata for a F31 from 2013 to able to do a recover if something goes wrong.
File is F020_13_07_506 from ISTA/P 2.50.4, could you send me the full version if you have this one ?
Thanks by advance !
      01-19-2025, 06:43 PM   #16939
shawnsheridan
Thanks by advance !
No, sorry, I have always only the latest, no older versions.
      01-19-2025, 07:10 PM   #16940
s1500
Drives: F22 2 Series M Sport Coupe
Hi Shawn. Could you please pm me the links for eSys and anything else needed for f22 2 series 2018.
I have an M2 macbook using Parallels for windows 11 virtual machine, will eSys work with this?
