09-12-2017, 02:59 PM | #1 |
No 55mph
1622
Rep 8,476
Some New Interior Bling + Seat Belt DIY for the F32 435 MSport!
In my never ending quest to make each of my BMW's slightly more unique - I picked up some new interior bling for my F32 435 MSport
Just received a set of the M4 GTS M Stripe Front Seat Belts from Britney @ STBMW As usual, they had the BEST price going anywhere - cost was <$345 shipped for the pair When I purchased there were only (4) sets of these left in the U.S. - now there b only (3) >> Many thanx to Britney for her ongoing assistance in finding me hard to get parts at awesome pricing! << For anyone else interested - give her a shout - part numbers for F32 fitment are: UPPER BELT FRONT, LEFT M 72118058481 UPPER BELT FRONT, RIGHT M 72118058482 *There are no M Stripe Belts for the rear AFAIK Static pics for now - installed pics this weekend...
09-13-2017, 06:00 AM | #3 |
Schmollbraten
12515
Rep 1,985
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
09-16-2017, 11:01 AM | #4 |
No 55mph
1622
Rep 8,476
Installed pics:
Dang3r12515.00 |
09-16-2017, 12:19 PM | #5 |
No 55mph
1622
Rep 8,476
FRONT SEAT BELT DIY (F32 COUPE)
Install fairly simple, ran into no problems >>Firstly & most important - disconnect Negative battery post - you will be disconnecting/connecting wiring from the belt reel pyrotechnic belt tensioners (connector similar to airbag connector) Be sure to leave trunk open Tightening Torques: Seat belt to upper B pillar = 42Nm (31 ft-lb) Seat belt guide to B pillar = 4Nm (32 in-lb) Seat belt reel to lower B pillar = 42Nm (31 ft-lb) Seat belt anchor to floor = 42Nm (31 ft-lb)
Qty. (4) Fillister head screw M10x22 07149148299 Qty. (4) Sheet metal screw ISA M5X12 07149158177 I also bought new floor plastic trim pcs that go over belt floor bolts just in case - glad I did cause no matter how careful I tried, the trim clips busted off when removing Qty. (2) Covering cap SCHWARZ 72117284489
*Put seat bottom roughly in place at rear, locate rear seat belt thru hole in seat & lock into belt receptacle while it is still under the seat - then pull up on belts to pull belt receptacle up thru the hole in seat bottom* This method took 3min to get the receptacles thru the seat openings - last time i didn't do this & it took me 45min + lots of WTF's >>Reconnect Negative Battery Post - all done!
